Integration by Parts Homework Help - Q2
12 replies · 2K views
Goldenwind
In preparation for an exam next week, I'm solving some of the end-of-chapter questions. There are 30 questions. I've solved a few on my own, but here's one I'm getting stuck on.
Question 2)
[tex]\int x5^x dx[/tex], problem here is I don't know how to deal with [itex]5^x[/itex].
The correct answer should be: [tex]\frac{x}{ln5}5^x - \frac{1}{(ln5)^2}5^x + C[/tex]
To avoid spamming the forum with many threads, I'll just post in this one whenever I hit an integral I'm unsure of. For now, it's just the one above.
[tex]\int u*dv = uv - \int v*du[/tex]
Did another one here:
Question 4)
[tex]\int x log_{10}x dx<br /> = \int x \frac{ln(x)}{ln(10)} dx[/tex]
[tex]= \frac{1}{ln(10)}\int xln(x) dx[/tex]
[tex]= \frac{1}{ln(10)}\int D(\frac{x^2}{2})ln(x) dx[/tex]
[tex]= \frac{1}{ln(10)}\left(\frac{x^2}{2} * ln(x) - \int \frac{x^2}{2} D(ln(x))dx\right)[/tex]
[tex]= \frac{1}{ln(10)}\left(\frac{x^2}{2} * ln(x) - \int \frac{x^2}{2} * \frac{1}{x}dx\right)[/tex]
And yeah, getting too lazy to TeX it all. Question is, when I finally get rid of all integrals, the +C will be inside the 1/ln(10) bracket. Do I write C/ln(10), or do I assume that whatever C is will already have that applied, so I just write C?
Dick said:
It might look a little easier if you write 5^x=exp(ln(5)*x). Put the exp into the dv part.
So, 5^x = exp(ln(5^x)) = exp(xln(5)) = e^(xln(5))... I see that much.
I also know the derivative/antiderivative of e^x = e^x.
What is the derivative/antiderivative of e^(xln(5))??
e^(ax) / a, methinks... 'cause then taking the derivative of that would pull down another 'a', canceling out the division. Makes sense.
Why is [tex]\int \frac{D(1+x^2)}{1+x^2}dx = ln(1+x^2)[/tex]?
I know [itex]D(ln(x)) = 1/x[/itex], however I don't see how my book did this calculation.
It is from the more general rule that
[tex]\int \frac{f'(x)}{f(x)}dx = ln|f(x)| + C[/tex]
which comes from the chain rule. If you think about substituting u for 1 + x2, then what is du in terms of dx?
If u = 1 + x^2, then du = 2x.
Thanks for the ln|blah| tip! I remember being taught it, but had forgotten.
One final question for tonight.
I'm in the middle of integrating arcsin(x), and as a segment, I need to compute the antiderivative:
[tex]\int \frac{x}{\sqrt{1 - x^2}}[/tex]
From looking up the answer, I see that this integral is equivalent to [itex]\sqrt{1 - x^2}[/itex]. Why would this be? I see how it can be broken up into [itex]\frac{x}{1} * (1 - x^2)^{-\frac{1}{2}}[/itex]. Does this help me, or am I missing another rule?
Yes, you are right, although the division by 1 is not really necessary. Think chain rule again, and see if you can separate one part of the integral as a derivative of another part, then substitute.
Derivative of the top = 1
Derivative of the bottom = [tex]-2x * (1 - x^2)^{-\frac{3}{2}}*-\frac{1}{2}[/tex]
= [tex]x(1 - x^2)^{-\frac{3}{2}}[/tex]
Sorry, but I still don't see it >.<;
I see how the chain rule was used to find the derivative of the bottom, but otherwise...
