Integration by substitution ((sin(x))/(1+cos^2(x)))dx
sapiental
evaluat the indefinite integral ((sin(x))/(1+cos^2(x)))dx
I let
u = 1 + cos^2(x)
then du = -sin^2(x)dx
I rewrite the integral to
- integral sqrt(du)/u
can I set it up like this? should I change u to something else?
I also tried it like this by rewriting the original equation to:
indefinite integral ((sin(x))/(1+cos(x)cos(x)))dx
u = cos(x)
du = -sin(x)dx
then
- integral (du)/(1+(u^2))
Also, can somebody give me directions on how to format equations in this message board to make my questions somewhat clearer.
Thanks alot!
I let
u = 1 + cos^2(x)
That's not right. The derivative of \cos^2{x} is NOT -\sin^2{x}.
u = cos(x)
du = -sin(x)dx
then
Yes you can. The final integral is pretty straightforward.
Download the pdf docs here
https://www.physicsforums.com/showthread.php?t=8997
neutrino's right - you can't differentiate \cos^2{x} as -\sin^2{x}. If it helps, think of \cos^2{x} as cos{x} * cos{x}. You can then use the chain rule.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
