Integration - Determine Maximum height - HELP
ayrestaurant
A baseball is thrown upward from a height of 2m with an initial velocity of 10m/s. Determine its maximum height.
S(0) = 2m
S'(0) = 10m/s
S'(t) = -32t + 10
S(t) = -16t^2 + 10t + 2
I know that if you equal s(t) = 0 you get time, but how do I get maximum height?
Thanx in advanced!
S(0) = 2m
S'(0) = 10m/s
S'(t) = -32t + 10
Thanx in advanced!
The easiest way would be to use energy conservation. Are you familiar with the equation:
TE = PE + KE (total energy is equal to potential energy plus kinetic energy)
What is the KE at the top of the object's travel?
hey thanx!
yepp.. in fact its better using physics, but its calculus; I have to use the integration method
btw ... the answer is 7.1m... i just don't know how to get there
ayrestaurant:
You should read your original problem again more carefully.
The distances, velocities, etc. are given in the metric system.
If you use formulas derived for Imperial units, you will never solve this problem.
If the acceleration due to gravity is 32.2 fps2 in Imperial units, what is the equivalent acceleration in m/s2?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
