Integrating $\frac{dv}{dt}=g-kv^2$ from $v=0$ to $v_t$
  • Thread starter Thread starter Locrian
    Integration
The discussion focuses on integrating the differential equation $\frac{dv}{dt} = g - kv^2$ from initial velocity $v=0$ to terminal velocity $v_t$, and from time $t=0$ to $t=t_f$. The user seeks guidance on achieving the correct integration result, which involves the hyperbolic tangent function. They realize that separating variables and integrating leads to the expression $\int_{0}^{v(t)}\frac{dv}{g-kv^2}=\int_0^t t'dt'$, which simplifies the problem. The user corrects a previous mistake regarding the inverse hyperbolic tangent function, clarifying its correct formulation. The conversation highlights the integration process and the realization of the hyperbolic function's role in the solution.
Locrian
I'm missing something simple here:
\frac{d\mbox{v}}{d\mbox{t}} = g - k\mbox{v}^2
I'm integrating from v=0 to v=v_t (where v_t is a known constant independant of velocity and time) and from t=0 to t=t_f, where t_f is the variable I wish to solve for in the end.
I'd rather not embarass myself by giving out the answer I produced. The actual answer has a hyperbolic tangent and I honestly am not sure how to get that. Could someone nudge me in the right direction?
The inverse of the hyperbolic tangent, the Artanh function is given by:
Artanh(x)=log(\frac{1+x}{1-x})
You can separate the variables and integrate:
\int_{0}^{v(t<br /> )}\frac{dv}{g-kv^2}=\int_0^t t&#039;dt&#039;
Aha! And the derivative of that is:
\frac{1}{1-x^2} Which should take care of the problem. If only it had seemed more obvious before I had to ask! Thank you for your time arildno.
Thank you too for helping Galileo. I'm afraid this seems rather obvious in retrospect, which I thought it might be.
Have a good friday.
I'm sorry, I made a mistake:
We should have:
Artanh(x)=\frac{1}{2}log(\frac{1+x}{1-x})
This can be seen by solving for "y" from the following equation:
x=Tanh(y)\equiv\frac{e^{y}-e^{-y}}{e^{y}+e^{-y}}
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
