Integral of $\frac{1}{x\sqrt{4x + 1}}$: Solutions and Explanations
  • Thread starter PhysicsinCalifornia
  • Tags
    Integration
In summary, the integral of $\frac{1}{x\sqrt{4x + 1}}$ can be solved using substitution, where $u = 4x + 1$ and $du = 4dx$. It is undefined at x = 0 due to a singularity and the domain of the function is all real numbers except for 0 and $\frac{-1}{4}$. While other techniques such as partial fractions or trigonometric substitutions can also be used, substitution is the most efficient method for solving this integral.
PhysicsinCalifornia
58
[tex]\int \frac{1}{x\sqrt{4x + 1}}dx[/tex]
I let [tex]u= \sqrt{4x+1}[/tex], [tex]u^2 = 4x+1[/tex]
So [tex]\frac{1}{2}u du = dx[/tex]
[tex]\int \frac{\frac{1}{2}u}{(\frac{u^2-1}{4})*((\sqrt{u})^2)}du[/tex]
[tex]\int \frac{2u}{(u^2 - 1)*(u)} du[/tex]
[tex]\int \frac{2}{u^2 - 1} du[/tex]
[tex]2\int \frac{1}{u^2 -1}du[/tex]
Can anyone help me anti-differentiate what the integrand is?
Isn't it related to the inverse hyperbolic tangent of u?
Try u=sinθ.
I'd suggest partial fraction decomposition...
Expanding that fractions gives:
[tex]\frac{1}
{{u^2 - 1}} = \frac{1}
{{2\left( {u - 1} \right)}} - \frac{1}
{{2\left( {u + 1} \right)}}[/tex]
Partial fractions work. So does u=tanh t.
What is the integral of $\frac{1}{x\sqrt{4x + 1}}$?
The integral of $\frac{1}{x\sqrt{4x + 1}}$ is $-2\sqrt{4x+1} + C$, where C is the constant of integration.
What is the technique for finding the integral of $\frac{1}{x\sqrt{4x + 1}}$?
The technique for finding the integral of $\frac{1}{x\sqrt{4x + 1}}$ is substitution. Let $u = 4x + 1$, then $du = 4dx$. This leads to the integral becoming $\int \frac{1}{x\sqrt{u}}du$ which can be solved using the power rule and then substituting back for x.
Why is the integral of $\frac{1}{x\sqrt{4x + 1}}$ undefined at x = 0?
The integral of $\frac{1}{x\sqrt{4x + 1}}$ is undefined at x = 0 because the function has a singularity at that point. This means that the function is not continuous and therefore the integral cannot be evaluated at that point.
What is the domain of the function $\frac{1}{x\sqrt{4x + 1}}$?
The domain of the function $\frac{1}{x\sqrt{4x + 1}}$ is all real numbers except for 0 and $\frac{-1}{4}$, since these values would result in a denominator of 0.
Can the integral of $\frac{1}{x\sqrt{4x + 1}}$ be evaluated using other techniques?
Yes, the integral of $\frac{1}{x\sqrt{4x + 1}}$ can also be evaluated using partial fractions or trigonometric substitutions. However, substitution is the most efficient and straightforward method for solving this integral.
  • Calculus
