Integration using natural logs, help (beginning of my calc 2 class)
Vagabond7
Ok, so I have the problem, and I have the answer, but I don't know how they arrived at the answer. I'll show you the problem, and what I tried and maybe somebody can point out where I am going wrong, or some hints to put me on the right path.
(2x-1)/(x+1) being integrated on ∫ 0 to 6
this lesson is supposed to be demonstrating how to integrate using natural log.
The answer I was given was
12-3 ln 7
I tried a variety of things, none of which led me to the given solution. I tried breaking it up into (2x)/(x+1)-(1)/(x+1) and then integrating each piece (which I'm not sure is a "legal" move) getting x^2 ln (x+1)-x ln (x+1), or trying it as x^2-x ln (x+1) neither of which gets me to the final answer.
Now there was a hint to use "U substitution" but I had in the past been told that I can only do "u substitution" if the derivative is found elsewhere in the function or the derivative is off by a constant factor. the derivative of neither expression is the other off by a constant factor (they would both be off by a variable x), so I'm not sure how to do a "u substitution" in that case. Halp?
12-3 ln 7
Put u=(x+1). Then du=dx and x=(u-1). Substitute that into 2x-1 to get the numerator in terms of u.
$$\int_0^6 \! \frac{2x-1}{x+1}\, \mathrm{dx}=\int_0^6 \! \frac{2(x+1)-3}{x+1}\, \mathrm{dx}=\int_0^6 \! \left(2-3\frac{1}{x+1} \right)\, \mathrm{dx}$$
Oh, I forgot to thank you guys. That totally cleared up that problem and helped a lot with methods for a couple of other ones. Thanks gentlemen!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
