Intensity Level of 76 trombones
  • Thread starter Thread starter Coushander
    Intensity
The intensity level of one trombone is 70 dB, and when calculating the intensity level for 76 identical trombones, the correct approach involves recognizing that each doubling of intensity increases the level by 3 dB. After recalculating, the intensity level for 76 trombones is approximately 89 dB, considering the logarithmic nature of sound intensity. Initial calculations led to errors due to arithmetic mistakes, but the consensus confirms that the final intensity level is around 88.8 dB. The discussion highlights the importance of careful calculations in sound intensity problems.
Coushander
If the intensity level at distance d of one trombone is 70 dB, what is the intensity level of 76 identical trombones, all at distance d?
β = (10 dB) log10(I/I0)
I0= 1.0 x 10-12 W/m2
I = power/area
70db = 10db log10(I/I0)
7db = log10(I/I0)
107 = 10log10(I/I0)
107 = (I/I0)
I = 0.00001 W/m2
Then I multiplied that by 76 and put it back in the general equation to generate β = 98db, which is wrong. β = 89db.
I = power/area
7db = log10(I/I0)
107 = 10log10(I/I0)
107 = (I/I0)
I = 0.00001 W/m2
Your argument seems sound, but you arithmetic must have gone astray.
For each doubling of intensity, we increase 3 dB [10*log102 = 3]
1 trombone = 70dB
2 -> 73 dB
4 -> 76 dB
8 -> 79 dB
16 -> 82 dB
32 -> 85 dB
64 -> 88 dB
128 -> 91 dB
so 89 dB seems quite possible
indeed 10*log1076 = 18.8,
so final intensity is 70 + 18.8 = 88.8, or perhaps 89 dB
[must be annoying to see it is that simple to calculate]
You're right, it was an arithmetic error.
Working it through again gave me 88.57dB this time (did it twice to make sure).
You actually should be getting 88.808 dB. Not sure why the discrepecy? your figure is the sound of 72 trombones!
