How Does Spring Compression Relate to Ramp Angle and Friction in Equilibrium?
The discussion centers on the equilibrium of a block on an inclined ramp, influenced by friction and a spring. Key forces include the frictional force acting away from the spring and the gravitational force component acting towards it. Participants clarify that the spring's compression depends on the balance of these forces and the mass ratio of the block and ramp. The system remains in equilibrium, meaning neither the block nor the ramp moves. Understanding the forces and their components is crucial for determining the spring's compression in this scenario.
hello95
A block of mass M rests on a ramp inclined at an angle z. there is a coefficient of friction s between the block and the ramp. The ramp itself rests on a horizontal, frictionless surface and is held away from the wall by a spring with spring constant k. What is the compression of the spring if the system is in equilibrium? (Hint: This is a conceptual problem; there is a visualization that eliminates the need for an equation.)
The way I see it, there are two horizontal forces acting on the inclined plane:
1: The component of the force due to friction (acting at angle z from the horizontal - or along the surface of the plane) on the block parallel to the horizontal (exerted by the block). The way I visualize this is if one were to have a small inclined plane on a table, one could push it along by pressing a finger on the plane's surface at an angle to the table. (this force acts away from the spring)
2: The component of (the component of the force due to gravity exerted on the block that is perpendicular to the surface of the block (i.e: opposite to the normal force)) that is parallel to the horizontal, frictionless surface. (this force acts towards the spring)
Now, it could be that with the right angle or coefficient of static friction, the plane would not move at all according to these assumptions, however whether the spring compressed or not would depend on which force was greater - force 1 or force 2.
Am I visualizing this correctly?
I apologize if I haven't explained myself well enough, if any clarification is needed please let me know.
I think no compression at all, since the CM remains.
Sorry, what do you mean by CM?
Sorry I'm was wrong on the compression since the block moves away from the center of mass.
This follows by the ramp moving in opposite direction according to conservation of momentum and compressing the spring.
The compression must be the ratio of the 2 masses.
Correct.
If you meant the horizontal component of the normal force between body and ramp then it is correct.
The system is in equilibrium, so both parts, block and ramp, are in equilibrium.
I think you are on the right track, but you have to consider the forces (gravity, normal force, friction) acting also on the body. You have two equations there, both for the components parallel with the slope and normal to it.
Write up all the three equations of equilibrium (one for the horizontal components of the forces acting on the ramp and the other two for the body and figure out the relations between them and see at what compression can be equilibrium maintained with the condition that the force of friction can not be greater than the normal force times coefficient of friction.
ehild
The system is in equilibrium: neither part is moving.
ehild
