Interference for for N slits formula
The discussion focuses on the mathematical understanding of intensity in interference patterns for a lattice with N slits. The key point is that maximum intensity, denoted as I_max, occurs when both the numerator and denominator of the intensity formula approach zero simultaneously. This is illustrated by analyzing the behavior of the sine functions as the angle approaches specific values. The limit shows that as the upper term approaches zero, the lower term must also approach zero, which is linked to the integer nature of N. This insight clarifies the conditions for achieving maximum intensity in the interference pattern.
Nikitin
Interference for a lattice with N slits
OK, so check out the first formula (the one for intensity) in the following pdf:
http://folk.ntnu.no/magnud/OvLf/bolge/oving11.pdf
It's the formula for Intensity as a function of angle from the interference for a lattice with N very thin slits.
Mathematically, why is ##I_{max}## found only when BOTH the numerator and denominator are approaching zero?
I agree that the intensity is largest when the ratio between the numerator and denominator is biggest, but why does this only happen when both approach zero?
Science news on Phys.org
Replaces previous post, which was misleading.
Consider when \theta is close to n\pi. Put \theta = n\pi + \epsilon.
Then \frac{sin N\theta}{sin \theta} = \frac{sin (Nn\pi +N\epsilon)}{sin (n\pi + \epsilon)} = \frac{cos (Nn\pi) sin(N\epsilon)}{cos (n\pi) sin\epsilon} = ± \frac{sin N\epsilon}{sin \epsilon}
The limit of this as \epsilon approaches zero is simply ±\frac{N\epsilon}{\epsilon} = ±N.
Likes 1 person
Oh I just figured it out. When the upper term approaches zero, then so must the lower turn because N is just a whole number.
thanks
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
After my surgery this year, gas remained in my eye for a while. The light air bubbles appeared to sink to the bottom, and I realized that the brain was processing the information to invert the up/down/left/right image transferred to the retina. I have a question about optics and ophthalmology. Does the inversion of the image transferred to the retina depend on the position of the intraocular focal point of the lens of the eye? For example, in people with farsightedness, the focal point is...
