How Thick is the Mica in the Double-Slit Experiment?
So, as you wrote, you can use the equations above (specifically 2nt = mλ) to solve for the thickness of the mica. Does that make sense?
kreil
Insights Author
68
1. The problem statements, all variables and given/known data
1) A think flake of mica (n=1.58) is used to cover one slit of a double-slit arrangement. The central point on the screen is now occupied by what had been the seventh bright side fringe (m=7) before the mica was used. If the wavelength=550nm, what is the thickness of the mica?
2)The reflection of perpendicularly incident white light by a soap film in air has an interference maximum at 600nm and a minimum at 450nm, with no min inbetween. If n=1.33 for the film, what is the film thickness, assumed uniform?
[tex]2nt=m \lambda[/tex] (for destructive interference)
[tex]2nt=(m+ \frac{1}{2}) \lambda[/tex] (for constructive interference)
[tex] d sin(\theta)=m \lambda[/tex] (condition for bright fringes)
[tex] d sin(\theta)= (m+ \frac{1}{2}) \lambda[/tex] (condition for dark fringes)
1) What confuses me here is that the mica only covers one slit. How is this taken into account? Can I just use the equations above?
2) Very lost on this one. Do I use the fringe equations to solve for m, which can then be used in another equation to solve for thickness.
Any other info on these questions is more than welcome.
Thanks,
Josh
Let's get one of these before we try doing two of them.
An important concept in interference is that of the "optical path" of light. The optical path is the number of wavelengths light must travel between two points. So the optical path of light in a material with index of refraction > 1 is greater for a given physical length than it is in air or vacuum. In your first problem, before the mica is put in place the optical path difference between the rays from the two slits is zero at the central maximum, one wavelength at the adjacent maximum, then two at the next, etc. At the seventh bright side fringe (m = 7) the optical path difference is 7 wavelengths. If that fringe is moved to center by the addition of the mica to one slit, then the optical path difference between the ray through the mica and the ray that bypasses the mica must be 7 wavelengths.
I don't understand exactly how that relates to the question. Could you explain?
Because the index of refraction of mica is > 1, the light that goes through the mica covered slit has to travel additional wavelengths compared to the light that goes the same distance through air to the uncovered slit. In your problem you are being told that the number of additional wavelengths in the mica path is seven.
Related to How Thick is the Mica in the Double-Slit Experiment?
1. What is an interference question?
An interference question is a type of question that asks about the impact of one variable on another in a scientific experiment. It is often used to determine the relationship between two variables and whether one variable affects the other.
2. How is an interference question different from other types of scientific questions?
An interference question is different from other types of scientific questions because it specifically focuses on the relationship between variables, rather than just asking for information or data about a particular topic or phenomenon.
3. What are some examples of interference questions?
Examples of interference questions include: "How does temperature affect plant growth?", "Does exercise impact heart rate?", and "What is the relationship between caffeine consumption and sleep quality?"
4. How are interference questions useful in scientific research?
Interference questions are useful in scientific research because they allow scientists to investigate the cause-and-effect relationship between variables. By understanding how one variable affects another, scientists can make predictions and develop theories about natural phenomena.
5. How can one ensure the validity of an interference question?
To ensure the validity of an interference question, it is important to clearly define the variables being studied and to use appropriate methods to measure and manipulate these variables. It is also important to consider other factors that may influence the relationship between the variables and to control for these factors in the experiment.
