Why is Cv used instead of Cp for calculating the internal energy of a gas?
The equation ΔU=mCvΔT represents the change in internal energy of a gas, where Cv is the specific heat at constant volume. Cv is used instead of Cp because, at constant volume, all energy input goes into increasing internal energy without performing external work. In contrast, at constant pressure, additional energy is required to account for the work done during expansion. This distinction is crucial for understanding energy changes in gases compared to liquids and solids, where expansion work is negligible. Thus, Cv is the appropriate choice for calculating internal energy changes in gases under constant volume conditions.
freshjunior
internal energy of a gas :(
Hi all! I have a problem with this equation ΔU=mCvΔT, where ΔU=change in internal energy, m=mass, Cv=specific heat of air/gas at constant volume,ΔT=change in temp. Although this expression is true for all processes which can be applied to a gas e.g polytropic, adiabatic, why is Cv used instead of Cp, which is specific heat of air/gas at constant pressure?:confused:
Hello freshjunior,
If the volume is kept constant the gas is unable to expand and none of the energy input is used to do external work all of it being used to raise the internal energy.If the pressure is constant you need the same energy input as above to raise the internal energy but extra input is needed to account for the work done.
Cv for gases is similar to the specific heat capacities of liquids and solids.The expansion of liquids and solids is so small that usually we assume that the work done during expansion is negligible.Gases can expand a lot but this expansion can be prevented by holding the gas in a container of fixed volume
oic. Thanks alot!
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
