Internal Enery, heat and work/HELP
  • Thread starter Thread starter SAT2400
    Heat Internal
The discussion revolves around a homework problem involving an ideal gas in a cylinder with a movable piston. The user has provided initial and final pressures and volumes, along with a heat transfer value, seeking help to find work done (W), change in internal energy (ΔU), and initial and final temperatures (Ti and Tf). The user calculated W as 200J and ΔU as 700J but is uncertain about their accuracy and how to determine the temperatures. A participant suggests using the ideal gas law (PV=nRT) to find the temperatures, emphasizing the need to clarify the relationship between work done and changes in internal energy. The conversation highlights the importance of understanding the equations connecting pressure, volume, and temperature for ideal gases.
SAT2400
There's .1 mole of an ideal gas trapped in a cylinder with a movable piston.
If Pi= Pf= 5000Pa, Vi= .04 m^3, Vf= .08m^3, Q=500J,,,Find W, change in (U), Ti and Tf.
change in U = Q+W
W= -p change in V
W= 200J
change in U = 700J
Ti=
Tf= i don't know how to get Ti and Tf... I am not sure whether 200J and 700J are right either..
PLease help me!
Thank you!
You certainly know an equation connecting P, V and T for an ideal gas.
The gas expands, is the work done on the gas positive or negative? Will this work increase or decrase the internal energy?
ehild
PV=nRT
Could you please explain more in detail? I don't get what you're saying:(
THanks.
You know P, V, n for both states of the gas, don't you? Can you calculate the temperatures?
ehild
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
