Inverse function of a two variable function
The discussion revolves around finding the inverse function of a two-variable function, specifically f(x,y). Participants are exploring the implications and requirements of defining such an inverse.
  • Some participants question the clarity of the original problem, asking whether the goal is to find the curve of (x,y) values for a specific constant c or something else. Others discuss the need to treat different cases based on the sign of y and the implications of mapping from a plane to a line.
The discussion is ongoing, with participants seeking clarification from the original poster regarding the specifics of the question. There is recognition of the complexity involved in defining an inverse function in this context, and some participants suggest that the problem may not have a straightforward answer.
There is mention of the need to separate cases based on the sign of y and the challenge of mapping from the entire plane onto a line, which raises questions about the existence of such an inverse function.
misterau
I'm wondering how to find the inverse function of some f(x,y)?
misterau said:
I wondering how to find the inverse function of some f(x,y)?
You need to define the question better. Do you want the curve of (x,y) values that give f(x,y) = c for some given c, or what? Typically, there will be many points, or no points, that give f(x,y) = c.
I need to show that f(x,y) = x/y has a right inverse that is a function f-1: R → R2 \ { (x,0) |x ∈ R} so that f . f-1(x) = x
The first, obvious, thing you will have to do is treat the sets {(x, y)|y> 0} and {(x, y)| y< 0} separately. For a given x, you want (u,v)= f^{-1}(u) such that u/v= x. Even requiring that v be positive, there area an infinite number of such pairs. The point is that your function, f, maps an entire plane onto the line (x, 0). The inverse function has to map that line onto the plane. No function can do that.
If the question as posted does not have an answer, let's let the OP, misterau, provide some clarification or correction.
misterau, please post the question in its exact words.
  • · Replies 17 ·
