So, for tanh(ax),y = tanh(ax)x = tanh-1yx = (tanh-1y)/a
Char. Limit
Now, I decided for no real reason to derive a formula for the hyperbolic tangent using only what I know about the derivative of the inverse hyperbolic tangent. However, what I have looks wrong, and I'd like to check it here.
\frac{d tanh^{-1}\left(ax\right)}{dx} = \frac{a}{1-\left(ax\right)^2}
\frac{1}{1-u^2} = \frac{1}{2} \left(\frac{1}{u+1} - \frac{1}{u-1}\right)
So, I started with the derivative, of course...
\int \frac{a}{1-\left(ax\right)^2} dx
I did a quick u-substitution, with u = a x and du = a dx:
\int \frac{1}{1-u^2} du
I used the second equation in part 2, which I derived seperately:
\frac{1}{2} \left( \int \frac{du}{u+1} - \int \frac{du}{u-1} \right)
Next came the actual integration, of course...
\frac{1}{2} \left( log\left(u+1\right) - log\left(u-1\right) \right)
I rearranged with the logarithmic rules and resubsituted ax to get...
\frac{1}{2} log\left(\frac{ax+1}{ax-1}\right)
Now, this should be the formula for the inverse hyperbolic tangent. So, if I set this equal to y, and then solve for x, I should have the formula for the hyperbolic tangent, right?
\frac{1}{2} log\left(\frac{ax+1}{ax-1}\right) = y
Rearranging to isolate the logarithm...
log\left(\frac{ax+1}{ax-1}\right) = 2y
And now I raise e to both sides to remove the logarithm.
\frac{ax+1}{ax-1} = e^{2y}
Now, I'll multiply both sides by ax-1 (why not, what else can I do?), and see what happens. Note that from here I'm pretty much doing this as I write.
a^2 x^2 - 1 = a e^{2y} x - e^{2y}
I'll rearrange to set the right side equal to zero...
a^2 x^2 + \left(-a e^{2y}\right) x + \left(e^{2y} - 1\right) = 0
Now I tried to use the quadratic formula to solve this, which is probably where I went wrong...
x = \frac{a e^{2y} \pm \sqrt{a^2 e^{4y} - 4 a^2 e^{2y} + 4 a^2}}{2 a^2}
Simplifying the radical slightly by pulling out the a, I get...
x = \frac{a\left( e^{2y} \pm \sqrt{e^{4y} - 4 e^{2y} + 4}\right)}{2 a^2}
So, the a's will cancel, and then I recognize the radical as a perfect square...
x = \frac{e^{2y} \pm \sqrt{\left(e^{2y} - 2\right)^2}}{2a}
And now I'll cancel the square and square root and split this into two equations...
x= \frac{e^{2y} + e^{2y} - 2}{2a} OR x = \frac{e^{2y} - e^{2y} + 2}{2a}
And then I'll simplify that.
x = \frac{e^{2y} - 1}{a} OR x = \frac{1}{a}
Now, neither of those seem right. What did I do wrong?
You multiplied the left side by ax-1 twice instead of once to get rid of just the denominator.
Oh, wow, I feel like an idiot now.
So, if we do it the right way instead (why not, right?), this is what I come up with...
ax+1 = a e^{2y} x - e^{2y}
That's much easier to solve than the complicated quadratic I was working on earlier... Let's put all the x terms to one side and all of the constants to the other...
ax - a e^{2y} x = -1 - e^{2y}
Multiply by -1...
a e^{2y} x - ax = e^{2y} + 1
Factor out the ax...
ax\left(e^{2y} - 1\right) = e^{2y} + 1
Divide and conquer!
x = \frac{1}{a} \left( \frac{e^{2y} + 1}{e^{2y} - 1} \right)
That still doesn't seem right though... is that 1/a supposed to be there? I don't think that's supposed to be there...
I think that 1/a does belong there. Apparently
\frac{e^{2y} + 1}{e^{2y} - 1} = \frac{1 + e^{2y}}{1 - e^{2y}}
and this is what I'm trying to figure out. The second "version" comes from writing 1/(1 - u2) as
\frac{1}{2}\left(\frac{1}{1 + u} + \frac{1}{1 - u}\right) \text{instead of } \frac{1}{2}\left(\frac{1}{u + 1} - \frac{1}{u - 1}\right)
The second one is valid, but using the first one easily works out to the formula for tanh(x) with the exponentials. I don't know why, but it's tricky...
[Edit] I hope those first two fractions are equal, I could have been too tired last night and missed something. I'll take a look at it again later.
Not true. Each one is the negative of the other.
See above.
See above.
Ok, I had overlooked the absolute values required when you integrate and get natural logs. Still using u:
\ln\left|\frac{u + 1}{u - 1}\right| = \ln\left|\frac{u + 1}{(-1)(1 - u)}\right| = \ln\left|\frac{1 + u}{1 - u}\right|
Factor ex from the numerator and denominator, cancel them, then change the variables to get the inverse.
As far as 1/a, consider some functions like f(x) = x2 and g(x) = sin(x) and their inverses (with restricted domain) with ax.
y = f(ax) = (ax)2
Inverse:
x = (ay)2
√x = ay
y = (√x)/a
y = g(ax) = sin(ax)
Inverse:
x = sin(ay)
sin-1x = ay
y = (sin-1x)/a
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
