Inverse of a special matrix of arbitrary size
  • Thread starter Thread starter stormyweathers
    Inverse Matrix
stormyweathers
Hey guys.
In a project I'm working on, it would be very convienent to express the inverse of this matrix in terms of its size, NxN.
The matrix is
<br /> \leftbrace \begin{tabular}{c c c c}<br /> a &amp; b &amp; \ldots &amp; b \\<br /> b &amp; a &amp; \ldots &amp; b \\<br /> b &amp; b &amp; \ddots &amp; b \\<br /> \vdots &amp; vdots &amp; ldots &amp; b \\<br /> b &amp; b &amp; \ldots &amp; b \\<br /> \end{tabular} <br /> \rightbrace <br />
[the tex isn't working, but the matrix is just constant b, except on the diagonal where it is a]
I can see a pattern in the inverses for N=2,3 ; the whole this is divided by det(A) and each element is given by the determinant of its corresponding cominor. This is great because it gives me a recursive formula for computing the inverse. But I'd like to be able to express it explicitly so I can write down the $$i^{th}$$ row in general
I think this is what you meant:
<br /> \begin{bmatrix}<br /> a &amp; b &amp; \ldots &amp; b \\<br /> b &amp; a &amp; \ldots &amp; b \\<br /> \vdots &amp; &amp; \ddots &amp; \vdots \\<br /> b &amp; b &amp; \ldots &amp; a \\<br /> \end{bmatrix} <br />
That's a Toeplitz matrix, and a rather special one at that. For an NxN matrix of this form, the determinant is ##(a-b)^{N-1}(a+(N-1)b)## and the inverse is simply:
<br /> \frac 1{(a-b)(a+(N-1)b)}<br /> \begin{bmatrix}<br /> a+(N-2)b &amp; -b &amp; \ldots &amp; -b \\<br /> -b &amp; a+(N-2)b &amp; \ldots &amp; -b \\<br /> \vdots &amp; &amp; \ddots &amp; \vdots \\<br /> -b &amp; -b &amp; \ldots &amp; a+(N-2)b \\<br /> \end{bmatrix} <br />
Your matrix is of the form
$$aI + b(1-I)$$
where ##I## is the ##n \times n## identity matrix, and ##1## is the ##n \times n## matrix consisting of all ones. We might speculate that the inverse has the same form ##cI + d(1-I)##. Let's see if that will work:
$$\begin{align}
(aI + b(1-I))(cI + d(1-I)) &= acI + ad(1-I) + bc(1-I) + bd(1-I)^2 \\
&= (ac - ad - bc)I + (ad + bc)1 + bd(n1 - 1 - 1 + I) \\
&= (ac - ad - bc)I + (ad + bc)1 + bd((n-2)1 + I) \\
&= (ac - ad - bc + bd)I + (ad + bc + bd(n-2))1 \\
\end{align}$$
where on line 2, we have used the fact that ##1^2 = n1##. We need the final expression to equal the identity ##I##. This will be true provided that ##ac - ad - bc + bd = 1## and ##ad + bc + bd(n-2) = 0##. We have two linear equations with two unknowns (##c## and ##d##), so for most values of ##a## and ##b## there should be a unique solution. I'm too lazy to carry out the rest of the algebra to confirm. :-p
