Ionizing Air Guns: What Do They Use?
  • Thread starter Thread starter Russell_B
    Air
Ionizing air guns are utilized in cleanrooms to eliminate static charges from sensitive electronic components. They operate by using electricity to ionize the air, creating a stream of positively charged air that neutralizes negative charges on surfaces. The process is akin to mass spectroscopy, where ionization occurs through electrical means rather than UV or X-rays. This technology is crucial for maintaining the integrity of circuits in environments like Silicon Valley cleanrooms. Understanding the mechanism behind these devices highlights their importance in static charge management in electronics.
Russell_B
Hello,
I have been reading up on ionizing air guns, such as those used in silicon valley cleanrooms, and as i understand it they are used to remove static charge from circuits and such. This would imply that the gun is creating positive ions, and thus it is somehow dislodging electrons.
What do ionising air guns use to achieve this? UV? X-Rays?
Russ
I believe they work by using electricity to ionise the air passing through the 'gun', in a way similar to mass spectroscopy. This results in a jet of positively charged air which neutralises any negative charges on the target.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
