Iron, Sulfur, and Hydrochloric Acid
  • Thread starter Thread starter Soaring Crane
    Acid Iron sulfur
Hydrochloric acid reacts with a heated mixture of iron and sulfur due to the activation energy required for the reaction, which is not met in an unheated mixture. In the demonstration, the lack of visible reaction, such as gas evolution, indicates that the acid does not react rapidly with the unheated iron and sulfur mixture. Instead, the reaction proceeds slowly at room temperature. The key takeaway is that the properties of the compound formed, such as iron sulfide, differ significantly from the individual elements, affecting their reactivity with hydrochloric acid.
Soaring Crane
I know that hydrochloric acid reacts with a heated mixture of iron and sulfur, but why does it not react with an unheated mixture of iron and sulfur? (During a demonstration, I could see a soggy mixture of the powder and fillings in the acid, and I noticed nothing so I am assuming no reaction occurred. Is this correct?)
Thanks.
Chemistry news on Phys.org
I can attempt to answer this only in the general case. And the way I'll start is by asking a question : do you not know of any other reaction that works hot, but not cold ?
Er, I'm sorry but I don't understand what's being inquired . . . :confused:
Anyone?
Thanks.
This one's gotten far enough sideways.
"... a heated mixture ..." is a student's way of saying "a mixture of iron and sulfur that has been heated." That is, HCl reacts with pyrite, marcasite, troilite, and however many other iron sulfides. The key point here is that the "heated mixture" is not iron, nor sulfur, and does not exhibit the chemical properties of either of the elements from which it was prepared.
You did not see any vigorous evolution of gas, therefore, no rapid reaction of acid with metal (it is proceding, but slowly at room temperature), nor did you see any other obvious signs of other chemical reactions that are occurring in the "soggy mixture." The point of the demonstration is that the compound, iron sulfide (I'm not going to hazard a guess which) has different properties and reactivities toward HCl than do the constituent elements.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
