Proving the Irrationality of √3 and Other Non-Perfect Square Roots
In summary, the conversation discusses the topic of irrational numbers and how to prove them. The conversation first touches upon the proof that \sqrt{3} is irrational and then moves on to discussing a similar method for proving \sqrt{n} is irrational where n is not a perfect square. The conversation also mentions the sum of two irrational numbers and how to prove it is irrational. Finally, the conversation explores different methods for proving other irrational numbers, such as \sqrt{2} + \sqrt{3} and \sqrt[3]{3}.
courtrigrad
1,236
Hello all
I encountered a few questions on irrational numbers.
1. Prove that [tex] \sqrt{3} [/tex] is irrational [/tex]. So let [tex] l = \sqrt{3} [/tex]. Then if [tex] l [/tex] were a rational number and equal to [tex] \frac{p}{q} [/tex] where [tex] p, q [/tex] are integers different from zero then we have [tex] p^{2} = 3q^{2} [/tex]. We can assume that [tex] p, q [/tex] have no common factors, because they would be canceled out in the beginning. Now [tex] p^2 [/tex] is divisible by 3. So let [tex] p = 3p' [/tex]. We have [tex] 9p'^2 = 3q^2 [/tex] or [tex] q^2 = 3p'^{2} [/tex]. So both [tex] p , q [/tex] are divisible by 3. But this contradicts the fact that common factors of [tex] p, q [/tex] were canceled out. Hence [tex] \sqrt{3} [/tex] is irrational.
2. If we had to prove that [tex] \sqrt{n} [/tex] was an irrational number where [tex] n [/tex] is not a perfect square would be do basically the same thing as we did above?
courtrigrad said:
Hello all
That's WRONG...And the rest of it is wrong as well...
NO,the proof following your pattern works only for [itex] \sqrt{2} [/itex]
Daniel.
Ok so how would you do it for [tex] \sqrt{3} [/tex] or for any matter [tex] \sqrt{n} [/tex]? What about if you had something like [tex] \sqrt{2} + \sqrt{3} [/tex]
Thanks
Thanks
I have no idea...I'm not a mathematician.The error i spotted was just common sense...
Daniel.
Why is what I have wrong? I just used proof by contradiction, as in [tex] \sqrt{2} [/tex]
Would it be that [tex] p^2 [/tex] has even powers of primes as its factors?
Thanks
Because [itex] p^{2} [/itex] divisible by 3 DOES NOT IMPLY [itex] p [/itex] divisible by 3...
Daniel.
Daniel.
If 3 is a prime it does.
Daniel.
dexterciogy, u were wrong
can you give me a conter-example, then
ps. i didn't use large font this time... ...
Ok let me take a shot at this again :smile:
[tex] \sqrt{3} = \frac{p}{q} [/tex] [tex] 3 = \frac{p^2}{q^2} [/tex] So [tex] p^2 = 3q^2 [/tex]. So this this mean that [tex] p^2 [/tex] has factors of even powers of primes hence [tex] 3^2 [/tex] is a factor which implies [tex] 3 [/tex] is a factor. Same with [tex] q^2 [/tex]
This is a guess
Thanks
dextercioby said:
That's WRONG...
I understand that I generally lack common sense, but what's WRONG with it?
For the sum of the two roots, square the sum first.
--J
This method of proof works fine for any prime...
But I want to ask courtrigrad:
Why does p^2 = 3q^2 let you conclude that p is divisible by 3?
For any irrational algebraic number, this method should allow you to prove it's irrational:
If a is an algebraic number, then let f(x) be the minimum polynomial of a. That is, the smallest polynomial such that f(a)=0. (Actually, you don't need the smallest, there is a wide class of polynomials that would work)
Now, you should know the criterion for a rational number to be a root of a polynomial: the only candidates are those whose numerator divides the constant term, and whose denominator divides the leading term.
The minimum polynomial of √3 is x^2 - 3 = 0. The only rational numbers that could be a root are 1, -1, 3, -3. Obviously, none of them work.
for √2 + √3, let it equal a...
a^2 = 5 + 2√6
a^2 - 5 = 2√6
a^4 - 10a^2 + 25 = 24
a^4 - 10a^2 + 1 = 0
The minimum polynomial of a is x^4 - 10x^2 + 1. (I haven't proven it actually is the minimum, but it will still suffice for this method of proof)
Now, the only possible rational roots of this are 1 and -1, and neither of these is √2 + √3, so it's irrational.
because [tex] p^2 [/tex] has [tex] 3^2 [/tex] as one of its factors which implies that [tex] 3 [/tex] is a factor of [tex] p [/tex]. Is this right?
Thanks
But why does it imply it?
Recall this theorem: if p is prime, and p | ab, then p | a or p | b
[tex] p^{2}=3\cdot 19 \Rightarrow p=\sqrt{57} [/tex] which is not divisible by 3...
Daniel.
P.S.So i was right...
Thanks guys (thanks Hurkyl for your wonderful explanation)
Ok so let's say I have [tex] \sqrt{2} + ^3\sqrt{2} [/tex] and we want to prove that it's irrational. Dp I just raise this to the sixth power and work off from here?
Also if we have [tex] ^3\sqrt{3} [/tex] and we want to prove that its irrational I receive [tex] p^3 = 3q^3 [/tex]. Would I emply the same reasoning as the other problems? Would it still be factors of even powers of primes ?
Thanks
Daniel.
p was assumed to be an integer.
--J
Daniel: remember that p was constructed to be an integer.
courtrigrad: the usual trick is to take the first few powers of the number, compute a few of its powers, and try to add them to get zero, and use that to get the minimum polynomial.
I'd expect that you'd need to compute 6 powers of your number. (because it's the sum of a square root and a cube root) So, if a is your number, compute 1, a, a^2, a^3, a^4, a^5, and a^6, and try to find a linear combination of them (i.e. you can multiply by constants and add them... much like elementary row operations on a matrix) that equals zero. Then, you have a polynomial with a as a root, and you can find all possible rational numbers that could be a rood.
I knew that.The idea was that everybody (vincentchan,zurtex and justin) argued that my assertion
p^{2}=3k =/=> p=3k'
was wrong...
I showed them i was right... :cool:
Daniel.
P.S.This thread cost me another black ball with the leaders... :cry:
p^{2}=3k =/=> p=3k'
was wrong...
Daniel.
For the love of Zarathustra,
p has always been assumed to be an integer ! Your example with [itex]\sqrt{57}[/itex] proves nothing ! Yet you smugly assert you were right all along. :yuck:
Do you understand the concept of a proof by contradiction ? The only problem that I could find with the OP's proof was that he didn't assert that p and q were coprime integers to begin with. Other than that, the proof stands, as it would for any prime n.
Your objection to his proof was unfounded and wrong all along.
Here, let me redo my example the cookie-cutter way.
[tex]
\alpha := \sqrt{2} + \sqrt{3}
[/tex]
[tex]
\alpha^2 = 5 + 2\sqrt{6}
[/tex]
[tex]
\alpha^3 = 11 \sqrt{2} + 9 \sqrt{3}
[/tex]
[tex]
\alpha^4 = 49 + 20 \sqrt{6}
[/tex]
I want to find an (integer) linear combination of the numbers [itex]1, \alpha, \alpha^2, \alpha^3, \alpha^4[/itex] that equals zero.
So, I apply linear algebra. You can consider a module over the integers (a generalization of a vector space) and apply linear algebra. The "basis vectors" are [itex]1, \sqrt{2}, \sqrt{3}, \sqrt{6}[/itex], so I want to solve the system:
[tex]
\left(
\begin{array}{ccccc}
1 & 0 & 5 & 0 & 49 \\
0 & 1 & 0 & 11 & 0 \\
0 & 1 & 0 & 9 & 0 \\
0 & 0 & 2 & 0 & 20
\end{array}
\right)
\vec{x} = \left(
\begin{array}{c}
0 \\ 0 \\ 0 \\ 0
\end{array}
\right)
[/tex]
Note that we have 5 unknowns and 4 equations, so the system is underdetermined and must have a nontrival solution.
Of course, you could do this by inspection too. I would start with [itex]\alpha^4 - 10 \alpha^2[/itex] which reduces to -1, so we have the combination: [itex]\alpha^4 - 10\alpha^2 + 1 = 0[/itex]
So, this proves [itex]\alpha[/itex] is a root of the polynomial [itex]x^4 - 10x^2 + 1[/itex]. Then, you simply exhaust over the candidates for a rational root of this polynomial, and show that none exist. Thus, [itex]\alpha[/itex] is irrational.
Yes,it may have been.The key point is that the three posters which contradicted me didn't do it on the error itself,but on something else which was incidentally true... :rolleyes:
Daniel.
Daniel.
*scratches head* :confused:
--J
Another way of finding this polynomial works like this:
You know that generally, when you take a square root, you get two different values... well, we can look at the "conjugates" of our number.
Our number was √2 + √3. But, by taking other roots, we get three conjugates:
-√2 + √3
√2 - √3
-√2 - √3
It turns out that the minimum polynomial has, as its roots, precisely this group of conjugate numbers. Thus, the polynomial can be factored over the reals as:
[tex]
(x - \sqrt{2} - \sqrt{3})(x - \sqrt{2} + \sqrt{3})(x + \sqrt{2} - \sqrt{3})(x + \sqrt{2} + \sqrt{3})
[/tex]
When you expand it, you get (yet again) the polynomial [itex]x^4 - 10x^2 + 1[/itex].
The number you have has 5 conjugates: two choices for the square root, and 3 choices for the cube root yields 6 numbers in all. You could find the minimum polynomial of your number as I did in this post.
p^{2}=3k =/=> p=3k'
was wrong...
Daniel.
Actually I'm going to stand by my point here, you say:
However ignoring the obvious fact in the first place that we were assuming p to be in an integer and that if p2 is divisable by 3 then p is divisable by 3 for all p in Z, you are clearly not talking about integers so the square root of 57 is divisable by 3 as:
[tex]3 \cdot \sqrt{\frac{57}{9}} = p[/tex]
This has gone on for a while, but:
Any integer, p, must be of one of these forms: 3n, 3n+1, 3n+2 for some integer n.
If p= 3n+1 then p2= 9n2+ 6n+ 1= 3(3n2+ 2n)+ 1.
If p= 3n+2 then p2= 9n2+ 12n+ 4= 9n2+ 12n+ 3+1
= 3(3n2+4n+ 1)+ 1
If p= 3n then p2= 9n2= 3(3n2)
That is, p2 is a multiple of 3 only if p itself is a multiple of 3:
For any integer, p2 divisible by 3 implies p = 3k for some integer k.
It's senseless to talk about divisibility if you take real numbers. Any real number is divisible by any other real number except zero, in the sense that the quotient is also a real number.
1. What does it mean for a number to be "irrational"?
Irrational numbers are numbers that cannot be expressed as the ratio of two integers. This means that they cannot be written as a simple fraction or decimal. Examples of irrational numbers include pi (π), the square root of 2 (√2), and the golden ratio (φ).
2. How do you prove that √3 is irrational?
The proof for the irrationality of √3 (and other non-perfect square roots) is based on the fact that if a number is rational, then its decimal representation will either terminate or repeat in a pattern. However, the decimal representation of √3 does not terminate or repeat, making it irrational. This proof was first demonstrated by the ancient Greek mathematician Pythagoras.
3. Can you provide an example of a non-perfect square root?
Yes, there are many non-perfect square roots, including √2, √5, √7, √10, and so on. These numbers cannot be simplified to a whole number or fraction and have an infinite number of decimal places.
4. Is it possible for a number to be both rational and irrational?
No, a number cannot be both rational and irrational. These are two mutually exclusive categories. A number is either rational (expressible as a ratio of two integers) or irrational (not expressible as a ratio of two integers).
5. Why is it important to prove the irrationality of certain numbers?
Proving the irrationality of numbers helps us to better understand the nature of numbers and their properties. It also has practical applications in fields such as geometry and physics. Additionally, this proof helps to reinforce the concept that not all numbers can be expressed in a simple, finite way.
  • Precalculus Mathematics Homework Help
  • Science and Math Textbooks
