Loren Booda said:
Are observers physically immortal?
This is an interesting question.
Frank Tipler has written a book trying to flesh out ideas about the physics of immortality. Just in case you are wondering, he has written pretty extensively about topics involved in General Relativity and even to some extent Time Travel with respect to space-times that allow theoretical paths to time travel.
But if I wanted to give a specific question for this, I would be asking this important question: what energy is involved for consciousness, what kind is it, where is it stored (in some kind of field for example) and how can it be transformed?
In my view, answering those questions will give a specific way to start thinking about this question in depth from a viewpoint that I think both scientific communities and religious communities can both appreciate and agree on as a basis for exploring this topic further.
Personally (IMO disclaimer), I think that there is some kind of other field that is not part of the known fields like EM, the nuclear forces and gravity that contains something that compromises of what we call 'consciousness'.
I am not saying that things like EM and the other forces don't play a role in how we behave, what we think, and so on, but I don't think that it is the whole story.
With the above aside in terms of immortality, if the energy that makes up consciousness can not be destroyed, and also can not be transformed away to something that loses or wipes information about conscious awareness then I would say that yes physical observers are indeed immortal on that argument.
But in order to argue the above you have to first define what consciousness actually is in terms of energy and also what kinds of energy forms they actually are and unfortunately I have a feeling it's going to take a while to even get close to even defining the specifics of this, let alone doing an experiment or having discussions about the veracity of whether the claim is wrong, right, or somewhere in between.
Parallel Universes, Max Tegmark --
http://space.mit.edu/home/tegmark/PDF/multiverse_sciam.pdf. What is not physically possible in an infinite universe? Can a finite universe have infinite possibilities? Do universal event horizons repeat without bound?
In terms of the infinite possibilities question, again this comes down to the discussion we had before about whether you can always construct a joint distribution that has random entropy for all conditional distributions for 'prior' events. In other words the entropy of each possible conditional distribution has maximal entropy. If this is always the case, then you should have infinite possibilities.
Also remember that the above is framed in terms of a finite state space. Think about it like constructing a process where no matter how you construct any conditional distribution for the next roll given every permutation of the previous rolls, all distributions will have maximal entropy. This means that you can construct a completely random system. If you can't do that but can do something in between minimal and maximal entropy then it is semi-random. If you can only construct a zero entropy distribution, then it means your system has become deterministic.
For the infinite universe question (what is not possible in an infinite universe), this will have to do with not only physical arguments but with philosophical arguments as well.
You see the reason that plates just don't assemble themselves from broken states and that gravity acts in a uniform way and even that quantum behaviour and all other physical interaction mechanisms work the way they work says to me at least that there is a reason why you can't just do 'anything you want', at least not currently.
Again my thought experiment would be to consider if people just randomly dematerialized and gravity just decided when it wanted to 'work' and 'not work' and the kind of chaos that would create for life in general. This tells me that there is a reason for the constraints at least in the context that you want an environment that supports and promotes the situation for living organisms in any form.
In terms of possibilities, this can be formed if you have a clearer idea of the nature of the different joint distributions. The big caveat though is that we don't have these yet. Science is very young for earthlings in the current state it is in and the amount of data we have and also the tools to effectively analyze it are not mature enough to really make all of these connections.
It's not just actually having the data: it's also having the computational hardware and technology, the algorithms, the mathematical techniques, and all of this to actually do all of this. These areas are evolving quite rapidly, but it's going to be a little while at least before it gets to a stage where we can give a more specific quantifiable answer using the above to answer 'what's really possible'.
For now we have to rely on experimental results, theoretical ideas and discussions, and the inquisition of scientists to help push this boundary and thankfully this is happening on a scale that probably never would have been imagined even a hundred years ago.
A truly unified theory might transform the existing order in maximal ways, including entropy/anentropy reversal.
The ironic thing about humans is that we crave certainty.
While I don't think this is necessarily a bad thing, the effect that it can have is that in a scientific perspective, we want as much certainty as possible both in its predictive power and subsequently in the mathematical representations that are used to both describe and predict things.
Quantum mechanics has come along and destroyed this notion and I think it's a thing that we should embrace at least in the idea that at some level, things will not be able to be predicted.
Here is one idea I have about why this kind of thing is good.
Consider that you have the complete set of laws that allow you to take the state of the complete system and engineer it in such a way that you can create whatever state you want at a future point of time.
Now consider what the above would do to the stability of the system. This situation creates situations where the stability of the system itself can be for lack of a better word, destroyed.
If situations exist like this, then what this would mean is that you would get all these possibilities where you would get these situations where things just literally blow up and create a situation where the evolution of a system is essentially jeopardized.
In a situation where this doesn't happen, you would need some kind of non-zero minimal entropy for all conditional permutations to avoid this very scenario which means you need to resort to a statistical theory of reality and not a deterministic one.
A situation where levels of stability in different contexts are 'gauranteed' or at least probabilistically high enough to warrant enough confidence would result in a kind of collective design so that this kind of thing would either not happen, or at least happen with a tiny enough probability so that it can be managed.
In fact if things had some kind of entanglement, then this mechanism could be used to ensure some kind of stability of the entire system and localize instabilities of the system if they do occur as to ensure that the system as a whole doesn't for lack of a better word 'blow up'.
The real question then if the above has any merit, is to figure out how you balance this kind of stability with the system both locally and globally having the ability to evolve itself in a way that is fair?
Thermal disequilibrium moves toward equilibrium by absorbed or emitted correspondent photons, with a decrease in entropy.
I don't know the specifics, but in the context of what I've been saying in this thread it would not be good for system stability to move towards a state of either maximal entropy or complete minimal entropy for reasons discussed above.
What is the most ordered universal structure possible? Is an empty universe interpretable as having both maximum and minimum entropy density? Can a maximally entropic universe have the same "complexity" as one of minimum entropy? Does an observer always impose order upon a more random universe? Can two or more disordered universes interfering together (e.g. through branes) reduce entropy overall?
To me, the situation where you have the most ordered universe is where all conscious forms work together in a way that doesn't create instability.
Some might see this as a religious theme or some kind of 'new age' comment, but an ordered system would look more like something that works in unison for each and every element rather than having elements working against one another.
If I had to characterize it, I would characterize it as every conscious form working with another to create the scenario where everything would be supplementing everything else in a way that creates a system where the energy ends up being directed in a way that everything works together as a whole which results in a kind of unification of all conscious beings which means that everything becomes a unified system which in terms of information means that it can be described as such which results in a decrease of entropy.
Remember entropy in this context is synonymous with not only order but also with the amount of information to describe something.
Remember that if you have a collective system that reaches some set of unified goals or constraints, then instead of having all these separate set of constraints to describe something, you end up having a situation where they end up merging which will result in requiring less information to describe the system. This lessening in the amount of information to describe the system translates in a reduction of entropy including the overall measures for all conditional entropies.
To me, the observer has the choice to either decrease or increase the entropies that end up contributing to the system as a whole but I would estimate that for a collective system to evolve in a positive manner, you would always want a system to at the very least decrease it's entropy over its evolution within any sub-region and collectively to find some kind of order for the system as a whole that reduces it's entropy from a previous state.
In terms of what that actual order is, I can't say but I imagine that there are many different kinds orders that could be formed just like there are many different functions that can be described once you have a dictionary and language structure that is minimal enough to describe a complicated system in a minimal form.
If this sounds like BS or foreign you should note that these ideas are a huge part of information theory including the area known as algorithmic information theory. If you want more information about this you should look up Kolmogorov complexity: it's not something that has been clarified in terms of algorithmic methods but the idea has been clarified to some respect.
Entropy, being scale dependent, sees an object like the Moon as being more ordered on many levels relative to the Earth.
A very good observation.
The thing is however, you need to define the order being used and this is really the heart of what makes language interesting.
The nature of the order could be to do with geometry and color variation. Describing a filled circle with a color spectrum that has little variation in one language is ordered.
But in another language it is not ordered. In another language something like the Mandelbrot set is highly ordered, but describing the moon in that language is highly disordered and requires a tonne of information.
This is why we have so many languages, jargon, structures, codings and so on. They all have a purpose in a given context. One language will represent something with minimal order but when you convert it to something else, it would take a ridiculuous amount of information to represent that same thing.
The question then becomes, how do we create languages in the best way possible? This is not an easy question and it is something that we are doing both consciously and unconsciously every single day.
The ultimate thing is that there are many different orders and not just one which makes it very interesting because we as scientists want to find 'the universal order' but my guess is that there are many orders that are just as valid as any other at the scope that they are presented at (i.e. the actual state space that these orders correspond to: think in terms of cardinality of the set).
Probability zero regions, found near atomic orbitals, are located in singular spacetime structures but quantum mechanically can be considered P>1, as they can not accommodate finite particles.
I don't know what this means, can you give me a link to a page that describes this?
The cosmic background radiation -- containing the microwave background radiation -- includes photons, gravitons, WIMPS (like neutrinos) and perhaps Higgs particles which impinge anentropically (focused) from the event horizon upon an observer. The accelerating cosmos, with possible inflation, linear expansion, and dark energy provide an outward entropic divergence of energy.
Can you point somewhere where this is described mathematically (and possibly in summary in english)? I'm for most purposes a mathematician/statistician and not a physicist.
