Is it possible for heat to be a physical form?
The discussion revolves around the concept of heat as a physical entity. Participants clarify that while heat exists at the atomic level, it cannot be contained in a tangible form like a jar. Comparisons are made to other abstract concepts that also cannot be physically stored, such as color or speed. The phlogiston theory is referenced to highlight that heat can be generated without consuming substances, emphasizing its intangible nature. The conversation includes a humorous remark about using a "bucket of BTUs" to illustrate the idea, while cautioning about the dangers of heat. Overall, the consensus is that heat, while a physical phenomenon, does not have a physical form that can be jarred or contained.
ARC123
By physical form I mean stored chemical or actual be a physical thing you can touch. Yes I understand it already is a physical form in atoms but I mean is it possible to have a jar of heat.
Chemistry news on Phys.org
You mean like Sterno?
No, you can't have a jar of heat. You also can't have a jar of blue (although you can have a jar of blue paint), you can't have a jar of speed, you can't have a jar of acceleration and you can't have a jar of logic. Plenty of things that can't be jarred.
Likes Sancho Panza, ProfuselyQuarky, epenguin and 2 others
The phlogiston theory has been falsified by the experimental observation that heat can be produced in any amount without consuming any other substances. One might consider phonons to be heat-particles but I wouldn't call that a chemical.
Well, I always use a bucket of BTUs to warm up on those cold mornings. :rolleyes:
But be careful touching the bucket - you can burn yourself. It is full of heat after all. :wink:
Likes ProfuselyQuarky
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
