Is it possible to solve for “t?”
  • Context: Undergrad
  • Thread starter Thread starter Devin-M
92 replies · 9K views
Like @Mark44 , I don't understand where you are coming from. It is easy to solve this type of problem numerically, and a computer will find the answer to any reasonable degree of accuracy as soon as you hit 'return'. Whether the answer is rational, irrational, or can be expressed analytically is basically irrelevant.
I was just wondering if after any amount of time the computer program would be done solving for t, having found it exactly. I think you are saying the answer is that it’s an endless task though I don’t know for sure.
Yes, it's an endless task and the answer will never be known exactly. Just like you will never know the value of pi exactly.
It would be possible to determine the infinite Taylor series of the solution or some other algorithm. After that, the length of the task depends on the accuracy that you require. If you are asking for a closed-form solution, those are not as common in real applications as you might think.
So then does it become possible to show, at a finite degree of accuracy, that in 9.8m/s^2 gravity, with 1m/s initial velocity that the minimum travel time between 2 horizontal points separated horizontally by 1 meter is 0.602... seconds via:
##Time = sqrt(r/g) * dt##
  1. You have confused things greatly by putting ## t ## in your equations to represent an angle which you have called theta. It would be much clearer if you had used ## \theta ## (i.e. ## \theta ## to mean theta leaving ## t ## for time.
  2. Where did you get ## Time = sqrt(r/g) * dt ## from? What does it mean? Does ## dt ## here have something to do with time?
  3. How do you know that your assumption that the optimal curve when the initial velocity is non-zero is a cycloid is correct?
  4. You have not specified the final velocity anywhere, can it be zero?
  5. You start talking about depth and elsewhere you mention a distance of 5,000 metres. Do you realize that gravity decreases with depth? (edit: oops, no it doesn't!)
  6. Do you realize that friction, and particularly air resistance, becomes very significant at increased velocity, meaning that for any real application you need to provide additional power to avoid falling short of the destination and falling back down the slope?
You have asked a lot of questions that have been difficult to interpret, and then it turns out that the question you have asked is not really relevant. Why don't you ask what it is you actually want to know and then we can work out which details are relevant?
I got that one from pg 116:
http://classicalmechanics.lib.rochester.edu/pdf/vpcm.pdf
Devin-M said:
Where did you get Time=sqrt(r/g)∗dt from? What does it mean? Does dt here have something to do with time?
I got that one from here:
https://mathworld.wolfram.com/TautochroneProblem.html
Are you referring to Equation 12 ## dt = \sqrt { \dfrac a g } d \theta ##? How are you calculating the parameter a (or r in your equation) and the initial angle ## \theta_0 ##?
pbuk said:
How are you calculating ... the initial angle ## \theta ##?
From your table it looks like you are guessing it. You don't have to do that, the initial point is the vertical distance below the cusp where the difference in potential energy equals the initial kinetic energy.
I calculated t (initial angle) and r (generating radius or a) using some logic steps:
https://u.pcloud.link/publink/show?code=kZq8VHXZIECHjF10TLJpQhMs7l1WEROKqDt7
For t, the algorithm first guesses 1 radian, runs it through the A= formula, compared it to the desired depth to determine if 1 rad is too big or small. Then it determines an increment and continues refining until A= is as close to the desired depth as possible after a certain # of iterations...
pbuk said:
Are you referring to Equation 12 dt=a/gdθ? How are you calculating the parameter a (or r in your equation) and the initial angle θ?
The other formulas are:
Devin-M said:
I added an extra set of parenthesis:
A=−(B/(2((pi−t)+sin(t))))(1−cos(t))
When B and t are 1, A should be -0.077...
Devin-M said:
The other helpful part of the solution is:
r=B/(2((pi−t)+sin(t)))
Where r is the cycloid generating radius
(the lowercase a from your quote equals the lowercase r)
(uppercase A does not equal the lower case a)
OK, I see what you are doing. The calculations in the sheet you linked look OK, you could improve this by using the solver to make 'Freefall Equivalent Error (m)' = 0 by adjusting 'Cycloid Initial Theta Best Guess (rad)'.
Bear in mind that the assumption is that the initial velocity is in the direction of the curve (which is pretty steep), not horizontal.
& therein lies the endless task...
Its not an endless task, its an iterative task, and the solver in Excel will do it for you in a millisecond.
hmm... i thought there was no exact solution for t when A and B are both rational... (or t is irrational)
Excel will have some error tolerance number in the algorithm to tell it when the answer is close enough to stop. Whether you want to call this "endless" or not depends on whether Excel's tolerance is good enough for your application. In any case, it is not the same as a closed formula. Even with a closed formula, the value that you get from a computer is often an approximated evaluation of the formula which may be obtained iteratively.
It's got nothing to do with being irrational, it is simply not helpful to talk about this task as 'endless'.
It is true that it is not possible to write down an 'exact' solution to the problem, but neither is it possible to write down the 'exact' value of 1/3 (a rational number) in the decimal number system, would you refer to that as endless?
There are things in mathematics which are 'endless', such as searching for the limit of the sum ## 1 + \frac12 + \frac13 + \frac 14 ... ##, but that is not the situation we have here.
Excellent point that seems to get to the heart of what the OP is asking about.
I can solve the equation ##3x = 1## algebraically to get the exact answer, but it will take an "endless" number of digits to write the exact value as a decimal fraction.
But so what? Rational or irrational makes just about zero difference here.
My suspicion is that what the OP is trying to get at is that the object can slide down the tube in a finite amount of time, but writing all of the decimal digits would take an infinite amount of time. I could be wrong, but if not, this is not something to be concerned about.
Devin-M said:
Just to confirm, would it be accurate to make the following statement—
“Whenever t & B are rational, A is irrational. Whenever A & B are rational, t is irrational.”
I suppose I thought that, when A & B are rational (each can be expressed as a ratio between integers) that, since the formula can’t be rearranged algebraically to solve for t, that t might not be able to be expressed as a ratio between integers and hence t would be “irrational” though I’m not sure.
I was imagining, if t is irrational, it leading to a scenario where someone with a fast computer solves t to very many digits, and from t and B calculates r, and from r, g and t, calculates the travel time and says “this is the quickest route.” But then someone else calculates to more digits, and finds an even faster time. Could this lead to a scenario where one can’t find the “quickest” route because someone with a faster computer and more time can always calculate t to more digits than the person before (more digits of t affecting and altering the proposed “quickest” cycloid generating radius), so as time goes on ever faster routes can be found ad nauseum?
So, two points:
(1) I think that what others are trying to say is that even if the "exact solution" for t is a number with infinitely many digits, the problem you seem to be worried about holds for any such number. For example, maybe I know the answer is 1/3 (a rational number). If I have to write that out as a decimal, I know exactly how to do that - start with 0.33 and keep adding 3's on the right. So it would take me an infinite amount of time to write it down exactly, but not nearly an infinite amount of time to write it out to a reasonable degree of precision.
Apply the same reasoning to a number like ##\pi## (an irrational number). If you give me a radius, I can calculate the circumference ##2\pi r## of a circle to arbitrarily many digits, depending on how many digits of ##\pi## I want to compute and use. No, it will never have infinitely many digits, but there's never going to be an application in which you need to know infinitely many digits. Knowing the value of the circumference that's more precise than any of your measuring devices, for example, is more than enough. More digits than that become redundant unless you're going to build a better tape measure.
(2) Both in the circle example and in your example of an extremal trajectory, using more digits will not radically change your final answer. Rather, you should expect that if you keep computing with more and more precision, your circumference or trajectory will be converging to some particular thing. No, you won't be able to say what it is with infinitely many digits, but you'll have, for example, a trajectory that changes so little as you introduce more digits for t that you very quickly stop being able to measure the resulting differences in travel time. Think of computing with t to 10 digits, and then with 15, and getting two trajectories. They will probably be similar to the point that a stopwatch could not measure the difference in time between taking each path, and indeed they're probably similar enough that no instrument could chart a course that knows how to distinguish between them. Furthermore, a computer would take very little time to do either of these calculations.
In fact, you'll find that you waste much more time trying to calculate to infinite digits than to just travel on the trajectory that's good to 10 digits, even while your measurable time spent on each of these paths would not be different.
Am I understanding correctly that you think there's some paradox in taking infinite time to calculate a trajectory that minimizes time? I'm not sure whether you just find this kind of ironic or whether it really bothers you mathematically. Hope this helps!
Nearly all numbers are irrational but they don't seem to worry about it and nor should you :biggrin:
No, there is only one fastest route.
Bear in mind that you have used the approximate value of 9.8 m/s2 for g: there is no point specifying your solution to more than 3 significant figures because it will change if use use a different value of g (note that g varies by about 0.05 m/s2 between the equator and the poles and there are also local variations due to altitude and geophysical anomalies).
Not my area of expertise but won't the Implicit Function Theorem just give us existence not construction? We don't have a problem with existence - we don't even have a problem with calculation; this is simple root finding for a (in the region of interest) monotonic function so we can achieve arbitrary precision in logarithmic time.
WWGD said:
I assume the Implicit Funcion Theorem could give a definitive answer on the possibility of isolating t?
I don't think so. I agree with @pbuk that this theorem just talks about the existence of a function. From the wiki page, https://en.wikipedia.org/wiki/Implicit_function_theorem
The implicit function theorem gives a sufficient condition to ensure that there is such a function.
That's how it seems to me.
Agreed, but maybe a 'no', not possible to represent even locally, would shed some light. Let me look at the theorem again see if I can find a constructive corollary of some sort.
It is probably worth a summary as there have been a few diversions and dead ends on the way.
We are trying to find the shortest journey time between points ## A ## and ## B ## at the same elevation for an object under the influence of gravity constrained without friction to a path. The object has initial velocity of ## v_0 ## in the initial direction of travel, and arrives at B with equal speed.
By other work referenced, we know that the solution is part of a cycloid defined by
$$ \begin{align*} x &= r (t - \sin t) \tag 1 \\
y &= r (1 - \cos t) \tag 2 \end{align*} $$
at point ## A ## we must have
$$ mgy_A = 0.5mv_0^2 \implies y_A = \frac{v_0^2}{2g} \tag 3 $$
and we know the distance ## X ## between ## A ## and ## B ## and that ## x_A = x_B ## so
$$ 2 x_A + X = 2 \pi r \implies X = 2 (\pi r - x_A) \tag 4 $$
We now have two unknowns, ## t_0 ## (the value of the parameter t at X) and ## r ## (the generating radius). There are a number of ways of proceding: the OP (if I remember rightly) has estimated ## t_0 ## and used (2) and (3) to find the corresponding ## r ##; substituted this into (1) and (4) to find the resulting ## X ## and reduced the error by bisection.
