Is my solution for the acceleration of two blocks correct?
  • Thread starter Thread starter ckboii89
    Accleration
The discussion revolves around verifying the acceleration calculation for two blocks on an incline, with various attempts leading to different results. Initial calculations yielded an acceleration of 3.72 m/s², but corrections were suggested, emphasizing the need to divide terms correctly. Ultimately, the correct acceleration was determined to be 2.35 m/s², with a time of 1.30 seconds. The conversation also clarified the concept of contact force between the blocks, highlighting that it is the magnitude of the force one block exerts on the other. The final formula for acceleration incorporates both gravitational and frictional forces acting on the system.
ckboii89
a= F/m
F= mgsinθ-Ffr
Ffr = \mumgcosθ
d= 1/2gt^2
a = (m1gsinθ+m2gsinθ)-(\mum1gcosθ+\mum2gcosθ)/(m1+m2)
a = 3.72 m/s^2
t = 1.03s
I need someone to verify if this is correct, no anwser key was provided
d=
ckboii89 said:
a = [(m1gsinθ+m2gsinθ)-(\mu_1m1gcosθ+\mu2m2gcosθ)]/(m1+m2)
a = 3.72 m/s^2
t = 1.03s
d=
Take care with the formulation. The first term has to be divided by (m1+m2), too. Your result is not correct.
ehild
a=[gsinθ-(μ1m1gcosθ+μm2gcosθ)]
a=.298m/s^2
t=3.66
how about now?
a=.298m/s^2
t=3.66
how about now?
Still wrong. Did you divide the second term with m1+m2?
ehild
a=[gsinθ-g(μ1cosθ+μcosθ)]
a = 2.35 m/s^2
t = 1.30s
ck
a = 2.35 m/s^2
t = 1.30s
ck
Correct the red part.
ehild
[gsinθ-μ1gcosθ-μ2gcosθ]
ehild i really appreciate the help
is the contact force the difference between the forces of the blocks? or the sum
The contact force is the magnitude of the force one block exerts to the other.
The common acceleration is the sum of all forces on the system divided by the sum of the masses. The internal forces (the force of block 1 on block 2 and the one block2 exerts to block 1 are opposite and of equal magnitude) cancel, so a=∑Fi(external)]/mi.
If T is the contact force, Newton's second law applied to both blocks says that
m1a1=m1gsin(θ)-T-m1μ1gcos(θ) and
m2a1=m2gsin(θ)+T-m2μ2gcos(θ) .
If the blocks move together, a1=a2.
Add the equations:
a(m1+m2)=(m1+m2)g sin(θ)-(m1μ1+m2μ2)gcos(θ),
that is,
a=gsin(\theta)-\frac{m_1 \mu_1+m_2\mu_2}{m_1 +m_2}g cos(\theta)
ehild
