Is my Three Phase Induction Motor Teacher Giving Me Accurate Information?
Concerns are raised about the accuracy of information provided by a teacher regarding three-phase induction motors, particularly the lack of fundamental concepts like stator and rotor in the curriculum. The teacher has been criticized for relying on handouts from websites instead of delivering comprehensive instruction. A specific issue discussed involves a motor rated at 440V and 3000 watts, where one winding is drawing an excessive current. It is noted that an unbalanced motor indicates a problem, likely due to a short in the winding. Recommendations include using a megger to test for ground faults to diagnose the issue effectively.
chris_MH
Hello, I have come to this forum as I don't believe what i am being taught to be entirley accurate and need some clarity on a question (not an exact answer, this is not homework)
To begin, I believe the person 'teaching' my subject is not up to standard as when our final topic of three phase motors came about, instead of teaching the construction, starting principles of operation, poles ect, he gave us a hand out printed froma random website.
The words 'stator', 'rotor' and even how the line windings influence the poles are never mentioned, its more of a case of 'here read this and get on with it'. This has repeated through out my course, for example, a new formula appeared today
power = resistance x voltage I am being taught so how am i meant to know right from wrong ? anyway onto my question, now you know what I am dealing with!
I quote
'motor rated 440v 3000 watt, however one winding has become bad drawing an extra 50% of its current load.
Using three phase theory produce a representational graph to show the effects of an unbalanced motor entering the relevant information'
Basically what my teacher said was this...
Two phases will remain unchanged in terms of their current, frequency and power. He said the output will be current and the input will be 240V voltage (UK) (?)
The third phase however will be out of phase, the current unchanged.
After soooo many months of trying to teach myself and ignore what I am told I can not trust this person, simple errors such as power formula being wrong (not the one above), not being taught anything relevant to assignments, not being taught anything at all at times and blaming us for not knowing it.
Is what I am told true?
If you have a current imbalance, then for sure there's a problem with the motor. The winding probably has a short somewhere or is shorted to the motor casing. You can use a megger aka megaohm meter to test for ground fault condition.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
