Is R\P a Multiplicative Set in an Integral Domain with a Prime Ideal?
  • Thread starter Thread starter tom.young84
    Ring Theory
The discussion revolves around whether the set R\P, where R is an integral domain and P is a prime ideal, is a multiplicative set. Participants are exploring the properties of prime ideals and the implications of removing elements associated with them.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants are attempting to show that the product of any two elements in R\P remains in R\P, questioning how to demonstrate closure under multiplication. Some express uncertainty about the implications of removing prime ideals versus specific elements.
There is an ongoing exploration of the definitions and properties related to prime ideals and multiplicative sets. Some participants provide insights into contradictions arising from assumptions, while others seek clarification on the logical connections between the definitions and the conclusions drawn.
Participants are navigating assumptions about the nature of prime ideals and the structure of local rings, with some questioning the definitions being used in the discussion.
tom.young84
R is an integral domain and P is a prime ideal.
Show R\P (R complement P or R-P) is a multiplicative set.
-Well since R is an integral domain it contains 1.
-{0} would be a prime ideal, and that was removed (is this too much to assume)
I'm not sure how to show multiplication is closed. My idea is that since we removed all prime ideals, so we have a, b in R and ab in R, we are only left with subsets where multiplication is closed.
2)
Local rings have only one maximal ideal
Could this be prove as such:
Suppose an ideal J that contains all non units. Now suppose another maximal ideal I in J and "a" (a non-unit) in J. This means that I must either be the ring R or J again. Since J is maximal, I=J and a is in J.
No, you removed the elements of P.
Outside of the case with {0}, I'm not sure why this is a multiplicative set.
(1) follows immediately from the definition of prime ideal.
tom.young84 said:
1)
As Hurkyl remarked you seem to have misunderstood the question. We haven't removed all prime ideals, just a single fixed one. You need to show that if a and b are elements of R\P, then ab is an element of R\P. That is assume a,b are elements of R that aren't in P. Now you need to show that ab can't possibly be in P. The easiest way is by contradiction. Suppose ab is in P. Then you have,
- a,b are not in P
- ab is in P
Can you see how this contradicts that P is a prime ideal?
2)
What is your definition of a local ring? It seems to be that all non-units in the ring form an ideal. If this is the case then this argument is correct.
For the first question, I understand your proof, but I don't understand why that answers the question. Your contradiction is that it violates the definition of a prime ideal. I don't understand why this demonstrates that A\P is closed under multiplication.
We prove that if [itex]a,b \in R\setminus P[/itex] and [itex]ab \in P[/itex] we get a contradiction, so if [itex]a,b \in R\setminus P[/itex] we must have [itex]ab \in R \setminus P[/itex] which is exactly what it means for [itex]R \setminus P[/itex] to be closed under multiplication.
  • · Replies 21 ·
10K
  • · Replies 31 ·
