A Is tangent bundle TM the product manifold of M and T_pM?
Joker93
Hello.
I was trying to prove that the tangent bundle TM is a smooth manifold with a differentiable structure and I wanted to do it in a different way than the one used by my professor.
I used that TM=M x TpM. So, the question is:
Can the tangent bundle TM be considered as the product manifold of a smooth manifold M and its tangent planes TpM with p∈M?.
If this is the case, then can we conclude that it is a smooth manifold because it is a product of smooth manifolds and we can find a differentiable structure that comes from the maps of M and the maps of TpM?
Thank you.
Joker93 said:
Hello.
Thank you.
In general, the tangent bundle is not a product. For instance, the tangent bundle of the 2 sphere is not the product of a sphere with a 2 dimensional plane. In fact, the only closed surface with a product tangent bundle is the torus.
However, the tangent bundle is always locally a product. It is a product over any smooth coordinate chart.
Aah, I wrote a proof in a test that depended on the last paragraph you wrote, but I did not think about it not being expandable globally.
Shame..
Thanks though!
Joker93 said:
Hello.
Thank you.
Adding to what Lavinia said, this is equivalent to the Tangent Bundle being (globally) trivial. EDIT: This is equivalent to the existence of a continuous nowhere-zero vector field.
Could you explain why this is please?
If you could give me some background re your knowledge, I will try to produce an argument.
This isn't true. Every odd-dimensional sphere admits an everywhere non-vanishing vector field, but S^n only has trivial tangent bundle for n=1,3,7. You might mean that having ##n## everywhere-independent vector fields on an ##n##-manifold is equivalent to having trivial tangent bundle (this follows simply by identifying an element ##(x,v)## of the tangent bundle with ##(x,w)\in M\times\mathbb{R}^n## where the coordinates of ##w## are projections of ##v## onto the vector fields at ##x##). For oriented ##2##-manifolds, it's enough to find a single such vector field ##X## because we may produce a second by fixing a metric ##g## and defining ##Y## to be everywhere unit length and orthogonal to ##X## and so that ##(X_p,Y_p)## is positively oriented for all ##p##.
Likes lavinia
And no non-orientable closed manifold has a product tangent bundle but many have zero Euler characteristic e.g. the Klein bottle.
I just know elementary manifold theory(just enough to start studying Riemannian Geometry) and I am currently learning Riemannian geometry.
I have only been learning higher mathematics for the past 3/2 months.
Sorry, I was trying to say that there exist n independent sections.
You should think of fibre bundles in general as generalized combs, at not as products. Locally you can write each bundle as the product of a (small) open subset of the manifold and the fibre (= local trivialization) but in general there is no way to 'glue' these local trivializations in a consistent way to a global trivialization. Heuristically, you can think of the curvature of the manifold being the obstacle to do so (not always true, but in most cases this picture fits).
A fiber bundle need not have a manifold as its base space.
A product bundle over a manifold often has non-zero curvature. Around any point where the curvature tensor is not identically zero, there is a neighborhood where the bundle is a product.
Depends on the definition. I usually include it into the definition, but of course this depends on what you want to do.
Yes, locally.
Are there any examples of n-manifolds; n=2 or higher with non-zero curvature tensor and trivial tangent bundle? For n=1 , we have the circle as a counter, but 1-manifolds are relatively straightforward.
https://en.wikipedia.org/wiki/Fiber_bundle
Yes, locally.
So curvature is not an obstruction to a product bundle.
Also many closed Riemannian manifolds with non-zero curvature have product tangent bundles. E.g. any torus embedded in ##R^3## or the standard 3 sphere in ##R^4##.
Likes Joker93
see post #15
Likes WWGD
lavinia said:
see post #15
How does the tangent bundle distribute with respect to the product, e.g., is there a nice result for ##TM(A\times B) ##? Maybe ##TM_A \times TM_B ##?
yes
lavinia said:
yes
Doesn't that then explain the result for Tori, i.e., the triviality of the tangent bundle?
WWGD said:
Doesn't that then explain the result for Tori?
yes.
Also the torus is a Lie group - as is the 3 sphere. All Lie groups have trivial tangent bundle.
Every closed orientable 3 manifold has a trivial tangent bundle.
Important examples of fiber bundles where the base is not a finite dimensional manifold are the universal classifying spaces for bundles with structure group a given Lie group.
For instance, the base of the universal classifying space for the discrete group ##Z_2## is the direct limit under inclusion of the finite dimensional projective spaces of all dimensions. Its topology ( I think) is the smallest topology such that intersection of open sets with the finite dimensional projective spaces is open.
Covering spaces are examples of fiber bundles with discrete fiber. The base can be any topological space. The interesting cases are mostly path connected locally path connected spaces.
Here are some references: Steenrod The Topology of Fiber Bundles; Milnor Characteristic Classes
lavinia said:
This thread is based in the subforum of differential geometry and in many books on differential geometry or gauge theory they start right away by defining bundles over (differentiable) manifolds. Of course the most general definition incorporates topological spaces , but dependent on your goal you may restrict definitions, makes life simpler. Examples: Morita - Geometry of Differential Forms; Baez/Muniain - Gauge Fields, Knots and Gravity, etc. etc.
lavinia said:
Also many closed Riemannian manifolds with non-zero curvature have product tangent bundles. E.g. any torus embedded in R3R^3 or the standard 3 sphere in R4R^4.
Okay, I didn't know that. Thanks for the information ;)
Granted. But inaccuracies can be misleading. I just wanted to dispel the possible implication that bundles are defined only for manifolds.
Likes Metmann
Does the bundle depend ( up to bundle morphism I guess) on the embedding, or is the bundle dependent only on homotopy/isotopy (and then what are the morphisms in the category of bundles)? How about the dependence on the ambient space in which the object is embedded?
WWGD said:
Does the bundle depend ( up to bundle morphism I guess) on the embedding...
What embedding?
I mean say the tangent bundle of a knotted circle. The circle may be embedded in different ways, including some embeddings where it has non-trivial knots, e.g. the trefoil is an embedding of the circle. Is the tangent bundle of the trefoil , or any other embedding of the circle the same as that of the standard ##S^1:= \{x: ||x||=1\} ##? EDIT: A more dramatic case: Is the bundle of Alexander's Horned Sphere the same as that of the standard sphere as defined? Is the bundle preserved by homotopy, i.e., do homotopic embeddings of the same space have isomorphic tangent bundles? Or do we use pullback bundles to study TM when we have different, possibly non-homotopic or non-isotopic embeddings?
I am not an expert, but I would say the tangent bundle of a smooth manifold is defined intrinsically, independent of an embedding. Then when you have a smooth embedding, that bundle also embeds as a sub bundle of the ambient embedding space. So every embedding of the circle into any euclidean space will have as (embedded) tangent bundle just the embedded copy of the intrinsic tangent bundle of the circle as its tangent bundle, hence all tangent bundles of all embedded circles are isomorphic, namely they are all isomorphic to the intrinsic tangent bundle.
As for the horned sphere, which I don't really know at all well, it looks from the pictures as if the embedding is only topological and not smooth, hence the tangent bundle would probably not embed along with it, and there would not be an obvious (to me) definition of an embedded tangent bundle. I.e. I suspect that the horned sphere is not a smooth submanifold of euclidean space so i don't know how to define its tangent bundle. there is such a thing as a topological tangent bundle, but i don't know what its definition is.
Likes WWGD
as far as homotopy goes, there is a theory of classifying spaces of bundles. I.e. as i recall distantly, given an embedding of a manifold X into euclidean space E of high dimension, for any n plane bundle on X, not just the tangent bundle, one gets an induced map from the manifold X to the grassmannian of all n dimensional subspaces of E. Then I believe that different embeddings of X, equipped with the same bundle, into E define homotopic maps from X to that grassmannian. conversely any map from X into the grassmannian pulls back a bundle to X indued from the universal n plane bundle on the grassmannian, and for any two homotopic maps the pull back bundles are isomorphic. something like that, it has been a long time, and not my area. the standard source in the 60's were xeroxed notes by milnor. you can google classifying spaces for vector bundles, or just see the 6.28 here:
https://www.ma.utexas.edu/users/dafr/M392C-2012/Notes/lecture6.pdf
Likes WWGD
A smooth embedding is by definition diffeomophism. If the embedding is not smooth then the image may not have a tangent bundle. For instance a square is a non-smoothly embedded circle and does not have well defined tangent spaces at the corners. The Alexander horned sphere is not a smooth embedding as mathwonk said.
Yes, thanks, that is sort of what I was getting at, that one should refer to a specific embedding when talking about the bundle. It may be, e.g., a knotted copy of the circle, like the trefoil, instead of the standard embedding.
  • #31
Every smooth embedding always gives a bundle isomorphism since it is a diffeomorphism. If it is not smooth then there is no bundle morphism at all. A trefoil knot is a smooth embedding.
Likes WWGD
  • #32
lavinia said:
What embedding?
I think this is a very important point that passes above the heads of many students, in particular if manifolds are introduced as embedded spaces. It cannot be emphasised enough. One of the main points of the differential geometry formalism is to only use properties of the manifold itself regardless of any embeddings. Far too many students get stuck in thinking about manifolds in terms of embedded spaces in some flat embedding space.
Likes lavinia
  • #33
now just for fun, note that the grass man of 1 diml subspaces of R^3 is just real projective plane, so any embedding of the circle in R^3 gives a map from the circle to RP^2 (sending a point of the circle to the line through the origin parallel to the tangent line to the circle at the point) and two such are homotopic iff they pull back the same bundle. Now imagine the usual embedding of a circle in a plane in R^3 and I think you can see the induced map to RP^2 wraps twice around the equator hence defines a trivial element of homotopy, hence the tangent bundle is trivial. similarly but harder to visualize is that a trefoil knot seems to induce by its tangent bundle a map that wraps 4 times around the equator but still the trivial homotopy element hence again the trivial tangent bundle. so the classifying space approach seems to show both that a standard and a knotted embedding of the circle define the same tangent bundle and also that this bundle is trivial.
  • #34
I was going to say that the classifying map for any embedding of the circle into ##R^3## can be factored through the Gauss mapping into the sphere and the sphere is simply connected. But this is the same as saying that the tangent bundle to the circle has a non-zero section - since otherwise there would be no mapping into the sphere - so one proves it is trivial by assuming it.
  • #35
True, but a lot of use deal with other perspectives, like Topological and Differential-Topological ones where the embeddings are relevant, if not the essential issue itself.
  • #36
I disagree. A manifold is a topological space. Embeddings are definitely not the essential issue of topology. The more essential issue is what is meant by continuity, comvergence, and homeomorphisms.
Likes lavinia
  • #37
My background is more along the lines of Knot theory where the embedding ( and its isotopy type, knotedness, other characteristics) _is_ the subject matter. EDIT: While I agree that it is an important, if not essential matter to study properties of manifolds that are independent on the embedding, there is some importance too, in other areas outside of D.G, to study the dependence on the choice of embedding.
  • #38
I suspected as much, but knot theory is a subfield of topology, not the main matter of study in the field. The main issues in topology itself remains what I quoted in my previous post. I also believe many people have the wrong impression that topology has to do with continuous transformations (who has not seen an animation of the coffee cup transforming into a donut?) and I think it is important to point out that it is not the main issue. Before you get to knot theory, you must pass several ideas that are more fundamental in topology. How points are topologically distinct, what it actually means for a function to be continuous in the first place, etc.
  • #39
This part of the thread led me ask whether a closed manifold can have two different differentiable structures whose tangent bundles are not isomorphic as bundles. Another way to ask this question is whether the tangent bundle is a topological invariant of the manifold.
Interestingly, Milnor proved that there are topological manifolds with two different differentiable structures whose tangent bundles are not bundle isomorphic. One of the tangent bundles is trivial and the other is not.
If one embeds a topological manifold in a smooth manifold so that it has a well defined tangent plane at each point, then the resulting tangent bundle might depend on the embedding.
  • #41
knots are of course interesting, and were traditionally studied by the fundamental group of the complement, and more recently by the "Jones polynomial" and its variants. I am largely ignorant of this theory, in spite of having heard some nice talks by Vaughn Jones, who draws rather beautiful pictures of knots.
I was hoping to find a link to a video of the talks but only found this announcement with abstracts:
http://www.math.uga.edu/events/10th-annual-cantrell-lectures
  • #43
not really, just saying that along the lines of milnor's examples, there are theorems that say choosing the complex structure differently on a given smooth manifold cannot greatly change the holomorphic cotangent bundle. But more variation is possible if the new complex structure also defines a different smooth structure on the given topological manifold. Specifically, if one has a diffeomorphism between two complex manifolds, or say just smooth projective complex surfaces, there is an induced isomorphism of cohomology groups. Q: what does this isomorphism do the "canonical class" K, a cohomology class associated to the holomorphic cotangent bundle? The answer seems to be that it can take K to -K, and maybe more variation than that in some cases, but i have not mastered this theory. (some name - omitted)
see last Theorem on page 297 here:
https://books.google.com/books?id=VgG9AwAAQBAJ&pg=PA297&lpg=PA297&dq=canonical+class+of+diffeomorphic+complex+manifolds&source=bl&ots=jnHZyQxxCc&sig=U8aaZECNU5rtTG8DohRqBbuUMy4&hl=en&sa=X&ved=0ahUKEwjAg6ObxtDXAhUnqVQKHRNPB-wQ6AEIVzAH#v=onepage&q=canonical class of diffeomorphic complex manifolds&f=false
  • #44
But you may have non-isotopic embeddings, both smooth , on a large dimensional manifold. EDITThis is the generalization of the iusual ##S^1 ## knots.
  • #45
Not sure what you are trying to say.
  • #46
Would their reapective bundles be isomorphic if the embeddings are non-isotopic or if the differentiable structures are inequivalent?
  • #47
A trefoil knot would seem not to be smoothly isotopic to a circle. Yet their tangent bundles are isomorphic.
The 7 sphere has different differentiable structures but all exotic 7 spheres have trivial tangent bundles.
I don't know anything about knots but one thing that distinguishes a knot in ##S^3## is the fundamental group of its complement. However all knots have a trivial tangent bundle.
  • #48
WWGD: I have tried to explain in #27 why all tangent bundles of all embedded circles are isomorphic, namely they are all isomorphic to the intrinsic tangent bundle. I.e. such isomorphisms do not need bobtailed by deformation, i.e. isotopy. In fact the same problem arises for why the knotted circles homeomorphic to the standard embedded circle. I.e. there is no nice deformation from onto the other but they are still homeomorphic via a map that goes back (and forth) to the intrinsic circle. So I am saying that if you believe the knotted circle is diffeomorphic to the standard unknotted one, you should also believe their tangent bundles are isomorphic. I.e. forming the tangent bundle is a "functor", and functors always take isomorphisms of one sort to isomorphisms of another sort.
but perhaps you are subconsciously trying to ask whether there is actually a diffeomorphism of the entire embedding space that restricts to a diffeomorphism of the two differently embedded circles, and carries one bundle to the other. That would be no, I guess. but that is not the definition of bundle isomorphism.
e.g. some informal descriptions of homeomorphism ("rubber sheet geometry")give the impression that one should always be able to deform one object into another homeomorphic one, but that is not the correct definition.
check out the answer to this question on mathoverlow:
https://math.stackexchange.com/questions/469992/tangent-bundles-of-exotic-manifolds
  • #49
lavinia: according to wikipedia, the fundamental group of the complement is not sufficient to distinguish between two knots up to "equivalence". not sure what you meant ??
https://en.wikipedia.org/wiki/Knot_group
  • #50
Right. My point was that this was one method that gives information whereas the tangent bundle does not.
