Why is Tension Greater Than ma in a Horizontal Pull Scenario?
  • Thread starter Thread starter physicsgurl12
    Tension
In a horizontal pull scenario with a box being pulled at a 5-degree angle, the tension in the wire exceeds the product of mass and acceleration (ma) due to the vertical component of the tension counteracting the weight of the box. The force equation f = ma must account for both the horizontal and vertical components of the tension. A free body diagram is essential for visualizing these forces and their components. The tension not only facilitates horizontal acceleration but also supports the weight of the box, leading to a greater overall tension. Understanding these dynamics clarifies why tension is greater than ma in this context.
physicsgurl12
a box withmass m is pulled with a constant a along a horizontal frictionless floor by a wire that makes a 5 degree angle above the horizontal. why is the tension greater than ma?
f=ma
i don't know where to start
f=t+mg
Draw a Free Body Diagram.
vector components: parallel the motion, and perpendicular to the motion.
