Is the Universe spinning on a vast scale?
  • Thread starter Thread starter Orion1
    Spinning Universe
The discussion centers on whether the Universe exhibits any large-scale spin or rotation, with references to the Friedmann–Lemaître–Robertson–Walker (FLRW) metric, which suggests a homogeneous and isotropic Universe without spin. Observations of spiral galaxies indicate a slight preference for counterclockwise rotation, raising questions about potential net rotation on a cosmic scale. However, current evidence does not conclusively support the idea of a spinning Universe, and anomalies in galaxy motion remain unexplained. The Godel metric is mentioned as a theoretical model that allows for rotation but does not align with observed cosmic expansion. Overall, while some evidence hints at rotation, it lacks sufficient support to confirm a spinning Universe definitively.
Orion1
According to my understanding of the LCDM Friedmann–Lemaître–Robertson–Walker metric, the Universe under such a metric model is homogeneous and isotropic, and does not have any spin rotation.
Friedmann–Lemaître–Robertson–Walker metric:
c^{2} d\tau^{2} = -c^{2} dt^2 + a(t)^2 \left(\frac{dr^2}{1 - k r^2} + r^2 d\theta^2 + r^2 \sin^2 \theta \; d\phi^2 \right)
Galaxies spin, stars spin, planets spin, and particles spin. So, why not the whole Universe?
Why would the Universe Big Bang not have any strong angular momentum and rotational energy on a vast scale?, or at least powerful vortices?
Ref. 4 said:
Looking northward, above the plane of our Milky Way, he found that more than half of the spirals were spinning in a counterclockwise direction in the sky. This overabundance seems small, only seven percent of the total observed galaxy sample. But the odds of it being purely due to chance are a one in a million say the researchers.
If the whole universe is rotating, then an excess number of galaxies on the opposite part of the sky, below the galactic plane, should be whirling in a clockwise direction. And indeed they are according to a separate 1991 survey of 8287 spiral galaxies in the southern galactic hemisphere.
Reference:
Friedmann–Lemaître–Robertson–Walker metric - Wikipedia
Solving Einstein's field equations - Universe - Wikipedia
Detection of a Dipole in the Handedness of Spiral Galaxies with Redshifts z ~ 0.04 - Longo - Department of Physics, University of Michigan
Is the Universe Spinning? - news.discovery.com
Space news on Phys.org
Although there have been some anomalies of motion, such as the one you mentioned. On the larger scale, the observations do not suggest that the universe is spinning. Or rather its not conclusive enough to say that it is or isn't with any degree of certainty. This is also a question that crops up from time to time. If you search the forum for "dark flow" you many also find some decent discussion. It is possible however we still don't have the conclusive evidence one way or the other.
Coincidentally the metric you posted doesn't support a spinning universe. The only link you supplied as support is the pop media article and the arxiv article. I seem to recall a counter paper to this but have been unable to locate it thus far, currently seeing if I still have it in my archive
It may bve interesting to note one of the authors later papers. In the one you posted the findings challenge the cosmological pinciple as a rotation denotes a preferred location ie not all locations would observe the same thing. However this later paper by the same author concludes that the universe is at sufficient scales homogeneous and isotropic.
http://arxiv.org/ftp/arxiv/papers/1305/1305.0464.pdf
You can have a homogenous rotating universe (Godel universe) but it won't be isotropic. Observers at every location will observe the same anisotropy due to the preferred direction in space. Anyways, the comoving observers in the FLRW metric clearly undergo no rotation because their 4-velocity field ##\xi^{a}## is hypersurface orthogonal to a one-parameter family of space-like hypersurfaces (the homogenous and isotropic time slices of the universe, with time referring to proper time according to the comoving observers) and the existence of such a foliation requires that ##\xi^{a}## have no rotation. More explicitly, ##\omega^{a} = \epsilon^{abcd}\xi_{b}\nabla_{c}\xi_{d}## is the twist of ##\xi^{a}##; now ##\epsilon_{ajkl}\omega^{a} = -6\xi_{[j}\nabla_{k}\xi_{l]} = 0## because of hypersurface orthogonality so ##\epsilon^{ejkl}\epsilon_{ajkl}\omega^{a} = -6\omega^{e} = 0## i.e. the comoving observers have vanishing twist and, as a result, the rotation ##\omega_{ab} = \epsilon_{abcd}\xi^{c}\omega^{d} = 0## as well.
We had a thread on the exact same topic a while back: https://www.physicsforums.com/showthread.php?t=696477
Godel metric in Minkowski coordinates: (ref. 1)
ds^2= \frac{1}{2\omega^2} \, \left( -\left( dt + \exp(x) \, dz \right)^2 + dx^2 + dy^2 + \frac{1}{2} \exp(2x)\, dz^2 \right)
The Godel metric listed on Wikipedia is in Minkowski coordinates. For my tensor examination, I require it to be in spherical coordinates, I could not locate a spherical coordinate form in Google search engine, so I attempted the transformation myself:
Godel metric in spherical coordinates: (ref. 2)
c^{2} d\tau^{2} = \frac{1}{2 \omega^2} \left( -c^2 dt^2 + dr^2 + r^2 d\theta^2 - \frac{e^{2r} r^2 \sin^2 \theta}{2} \; d \phi^2 - 2c e^{r} r \sin \theta \; d\phi \; dt \right)
Is this transformation correct?
[/Color]
Reference:
Godel metric - Wikipedia
Metric tensor - General Relativity - Wikipedia
These things (except particles) tend to spin noticeably because they have collapsed from much larger clouds of essentially randomly-moving particles. A tiny bit of random net rotation of a larger cloud turns into a much more noticeable rotation after collapse.
Our universe as a whole hasn't collapsed: it's been expanding.
Is there some net rotation? Probably.* But our universe is so large, and getting larger all the time, that there's basically no way for it to be noticeable.
* One caveat here is that relativity may potentially make this issue moot. The problem is that if you have a spinning object, it tends to drag space around it. So if the whole universe has some net rotation, will it just drag space around it in such a way that that rotation is completely undetectable? I think it might, but I'm not certain.
[/Color]
Reference:
wow its been awhile since I've seen the Goedel form without Lambda.
I had to dig deep into my archive for this article lol. You will probably find everything you need in this paper. By the way this includes the Goedel form with the cosmological constant.
http://arxiv.org/pdf/gr-qc/0511015v1.pdf
edit: lol just noticed its referenced on the Goedel wiki reference page as well. wuld have saved me some hassle ah well
According to (ref. 1, pg. 3, eq. 2.3) and (ref. 1, pg. 5, eq. 2.15) and (ref. 2, pg. 3, eq. 1), a is a constant defined as:
a^2 = \frac{1}{2 \omega^2} = - \frac{1}{2 \Lambda}
The criteria between \omega (angular velocity) and \Lambda (cosmological constant) for these Godel metric models:
\omega^2 = - \Lambda
Godel metric in spherical coordinates and with cosmological constant:
c^{2} d\tau^{2} = - \frac{1}{2 \Lambda} \left( -c^2 dt^2 + dr^2 + r^2 d\theta^2 - \frac{e^{2r} r^2 \sin^2 \theta}{2} \; d \phi^2 - 2e^{r} r \sin \theta \; c \; dt \; d\phi\right)
[/Color]
Reference:
Godel's Metric And Its Generalization - Ozgoren
Reflections on Kurt Gödel - Wang
Wikipedia Godel metric...
The Godel metric given by Wikipedia:
ds^2 = \frac{1}{2 \omega^2} \, \left( -\left( dt + \exp(x) \, dz \right)^2 + dx^2 + dy^2 + \frac{1}{2} \exp(2x)\, dz^2 \right)
The Godel metric given by (ref. 1, pg. 3, eq. 2.2)
ds^2 = a^2 \left[ -(dx_0 + e^{x_1}dx_2)^2 + dx_1^2 + \frac{e^{2x_1}}{2} dx_2^2 + dx_3^2 \right]
If I overlay coordinates (x_0,x_1,x_2,x_3) with (t,x,y,z) the result is:
ds^2 = a^2 \left[ -(dt + e^{x}dy)^2 + dx^2 + \frac{e^{2x}}{2} dy^2 + dz^2 \right]
The metrics do not appear to match, please clarify?
[/Color]
Reference:
Transpose y and z, and look again.
Currently working out in the field typing from my phone. There are a couple of properties of the Godel universe you should also consider.
1) universe is static
2) there are no timelike closed null geodesics.
3) the frame dragging and its lightcone path effects.
“the compass of inertia”. this is a key aspect of the Godel universe
another key property concerning light paths quoted from the link I provided.
Godel’s rotating cosmological model [12], [13] is one of the most interesting solutions
of Einstein’s field equations with negative Lambda-constant, particularly in view of its
contribution to our understanding of rotation in relativity and its signs of causality
breakdown due to the existence of closed timelike curves
later on
Godel’s stationary solution of Einstein’s field equations with cosmological constant
describes the gravitational field of a uniform distribution of rotating dust matter, where
- loosely speaking - the gravitational attraction of matter and the added attractice force
of a negative lambda-constant is compensated by the centrifugal force of rotation
a lot of the above is shown in the Ricci tensers. Just some key aspects to look at and consider. Looks like Nugatory is helping with the metrics your working on
It will be interesting to see how you plan on incorperating expansion into a static model witrh frame dragging
Wish I could help more than that but work calls.
The godel universe is not static, it is only stationary. Stationary means the space-time has a time-like killing vector field and static implies the time-like killing vector field is hypersurface orthogonal; the latter condition would actually obstruct the global time-like congruence represented by the dust particles from rotating. It can be shown that there exists no static solution to the Einstein field equations generated by dust.
ah your correct I misread the one paper,
edit: I located another reference that may be handy, I particularly like the visualizations presented in this paper. The causality violations of the Godel universe is also intriging. When I get more time I will probably look deeper into the metrics. It will give me something new to study. Need a break from perturbation field self studies lol
http://arxiv.org/pdf/1303.4651v1.pdf
however my question still stands particularly in regards to this quote from the reference I posted.
"In his paper [8] Godel admitted that his rotating universe cannot serve as a model of
the universe we live in since it does not contain any redshift for distant objects accounting
for an expansion as required by Edwin Hubble’s law of 1929"
Found the paper with the referenced quote above.
http://fuchs-braun.com/media/91ac4f6879c27351ffff8191blackf0.pdf
As the the physical meaning of the solution proposed
in this paper, it is clear that it yields no red shift for
distant objects. For, by using the transformation (I)
defined in the proof of the properties (1) and (2), one
proves immediately that light signals sent from one
particle of matter (occurring in the solution) to another
one arrive with the same time intervals in which they
are sent.
If you're interested in looking at the differential geometry of the Godel space-time, see chapter 3 of Malament's notes (which were turned into a text on the foundations of general relativity): http://www.socsci.uci.edu/~dmalamen/bio/GR.pdf
Thanks I'll definitely look through it, at a quick glance it looks like a great article to study.
I hope you enjoy it. I recently bought the aforementioned text and I love it thus far. Rotation in general relativity is quite a deep subject area.
Transpose y and z and the metrics are equivalent.
Are such coordinate transpositions allowed in General Relativity metrics, and therefore both metrics from post #9 are correct? or is my symbolic coordinate substitution method and interpretation incorrect?
[/Color]
[/Color]
Yes. x, y, z, and t are just variable names with no significance until you plug them into a metric or use them in a coordinate transformation. You just have to be consistent in how you use them.
It's fine. Somewhere back in this thread you said "If I overlay coordinates (x0,x1,x2,x3) with (t,x,y,z)..."; all you needed to do was to overlay (t,x,z,y) instead. You could have overlaid "dog", "cat", "sheep", and "cow" if you had wanted.
If the universe is found to be spinning, would that be evidence that the universe is not infinite?
Not necessarily. For example the Godel universe is infinite and rotating.
Just a side note curiosity, I wonder how close the characteristics between the Godel universe and Poplowskii's torsion, and spinor characteristics match up in similarity. Its another model that can have rotation related characteristics.
http://www.physics.indiana.edu/~nipoplaw/publications.html
its been awhile since I read any of his papers, some of his metric applications I found intriguing at the time.
Godel metric in spherical coordinate form...
Godel metric in Minkowski coordinate form (dt,dx,dy,dz):
Godel metric in expanded Minkowski coordinate form (dt,dx,dy,dz):
ds^2 = a^2 \left[ -dt^2 + dx^2 - \frac{e^{2x}}{2} dy^2 + dz^2 - 2 e^x \; dt \; dy \right]
Godel metric in spherical coordinate form (dt,dr,d\theta,d\phi):
c^{2} d\tau^{2} = - \frac{1}{2 \Lambda} \left( -c^2 dt^2 + dr^2 - \frac{e^{2r} r^2}{2} \; d \theta^2 + r^2 \sin^2 \theta \; d\phi^2 - 2 r e^{r} \; c \; dt \; d\theta \right)
[/Color]
Reference:
I don't see a problem with that derivative, however Nugatory is far better at calculus than I. Some things I have to practice more often lol.
