Is the Wavefunction a Contravariant Component?
47 replies · 4K views
JohnH
I've heard that the wavefunction as a function of x has units of square root of inverse distance, but I haven't heard an intuitive description of why this is aside from that the math works out when you integrate to get the probability. But aside from the math working out, I'm hoping to get a more intuitive understanding of what this means for the wavefunction as a physical object. If it means that the wavefunction is a contravariant component of a vector, then I can understand why its units are of inverse distance. Is this a common understanding of it? Or is the intuition for the units just a mystery? In short, philosophically, what is to be made of the wavefunction having these oddly inverse units if it's a physical object that exists in the world?
It is just because the maths works out. For a probability density, it has units of 1/x so that when you integrate against dx, you get a unitless probability. Similar reasoning gives the units for the wave function.
Regardless of units, it is a matter of interpretation whether the wave function is considered a physical object, or just something like a probability that may be taken to represent subjective knowledge.
It isn't.
Why? A vector can have all kinds of different units.
PeterDonis said:
Where? Please give a reference.
We should have a standard reply button with this phrase on PF.
  • Haha
That's just a statement of a fact. The question is what is the intuition for these particular units.
I think that pretty much answers the question.
As a follow up, would it be a theoretical possibility to interpret the wavefunction as a contravariant component of a vector, or would there be some logical reason for necessarily disqualifying that interpretation?
But that intuition has nothing to do with whether or not the wave function is the contravariant component of a vector, which is what your statement that I quoted implied. It has to do with the wave function being a probability amplitude, i.e., its square is a probability density. So the units of the wave function have to be the square root of the inverse of whatever the probability density is a density over (in this case position, i.e., units of length).
You can't just choose to "interpret" the wave function (or anything else, for that matter) as a contravariant component of a vector. To be a component of a vector, it would have to be a member of a set of quantities that, taken together, transform as a contravariant vector. The wave function isn't.
That's a better answer. But it still seems a bit Nhilistic to simply say that "the math just works out" is as intuitive as it gets.
That was the answer to why the units of the wave function are what they are, not to why it isn't a component of a contravariant vector. I expanded on that some in post #10.
Yes, I think we both are agreeing on the basic facts (and I was alluding to what you were talking to in post 10 in my first post). But where there's some conflict is as to whether or not there's any more intuitive understanding of these facts than have yet been mentioned. I was trying to puzzle through the intuition and thought perhaps it had to do with contravariance, but apparently I was wrong about that.
So from here, I'd ask would you all agree that it is intuitive to say that the wavefunction has the units it has? If so, why? And if not, what does the literature say on this subject? Is there any deeper meaning/interpretation to be had here even if only theoretical? In other words, with classical physics there's always an intuition and an imaginable reasoning behind everything and I understand that's not always the case with quantum mechanics. If this is simply a case where we don't have an intuitive answer for it, then that's a fine and complete answer. Not complaining. Just wondering.
For me it is, but I guess it's a matter of what intuition one has. Studying physics forces you to rebuild your way of thinking and what's "intuitive". As to why it is intuitive (and I'm repeating what PeterDonis said):
##P=\int_\mathcal{O}|\psi|^2\textsf{d}\mu##
##P## has no unit, so ##|\psi|^2## has to have the inverse unit of measure. Then we take a square root and that's all. That's my intuition.
So I take it you don't interpret the wavefunction to be a physical object then.
I would say no one interprets it as a "physical object" 😉
By the way, in order to properly speak about "covariance" and "contravariance" of mathematical objects, one first needs the full machinery of (usually finite-dimensional) differential geometry (i.e. topological/differential manifolds, points, charts, tangent spaces, tangent bundles, parametrized curves on the manifold, differentiability of curves, etc.).
The mathematical interpretation of wavefunctions: vectors from the infinite-dimensional Hilbert space ##L^2 (\Omega\subseteq \mathbb{R}^n, d\mu)##, so yeah, quite unrelated to the paragraph above.
If you wish, you can perceive wavefunctions as contravariant vectors, but there is no solid mathematical background for it...
Some interpret wave functions as ##\frac{1}{2}##-densities.
That is correct, it's the "diff. geom." interpretation made popular by the relativist Robert Geroch, but I've not seen it formalized in terms of infinite-dim manifolds.
Thank you all for the replies.
Just for clarity of the discussion, do you agree that there is no connection between being the two issues of the units for the wave function and whether it's a component of a contravariant vector? A vector can have any units you like. Momentum, for example, has units ##\dfrac{\text{mass} \cdot \text{length}}{\text{time}}##, while current density has units ##\dfrac{\text{charge}}{\text{length}^2 \cdot \text{time}}##
As I said right above what you quoted, I was wrong about it having anything to do with contravariance.
stevendaryl said:
Momentum, for example, has units , while current density has units
Yes, that's a good example, the charge density. Are you suggesting an analog--that the wavefunction is divided out over space like a charge? Because an answer like that is very intuitive.
Schrödinger originally thought this about the wave function for an electron. Unfortunately, this analogy breaks down as soon as you consider a quantum system of more than one particle, since the configuration space--the space that the wave function "lives" in--is no longer ordinary 3-dimensional space. In fact, this is true even for a single electron since it also has spin as well as position; Schrödinger's original wave equation ignored spin.
PeroK said:
Dirac spinors have four components that transform according to a representation of the Lorentz group:
Yes, but it's not the vector representation.
So my problem with the current explanation is that it treats the square integral and the resulting probability distribution as if it's all that mattered and as if all the innerworkings don't need to make any sense. It's as if we built a car that works and when we open the engine, nothing makes any sense, but we say, but no look--the car drives just fine when I turn the wheel so "seems pretty intuitive to me."
And I'm fully prepared to accept that the answer might not be "intuitive" based on my macro-world associations, but I still believe the mathematical descriptions should be imaginable--at least as far as the fundamentals are concerned.
Another thing that's been on my mind is the units of the eigenfunctions. If the wavefunction started out with these inverted units, how then might it arrive at units of momentum, energy, etc for the eigenfunctions? Perhaps I just don't have a popular way of thinking about things, but personally I need to be able to imaginatively reconstruct some narrative explaining these fundamentals.
As an aside, it was this issue that led me to believe that the wavefunction was interpreted as a contravariant component because then the eigenfunctions could be covariant and they would seem to map out right.
The square of the wave function is the probability distribution; that's the definition of the wave function. What else would you expect?
What "innerworkings" are you talking about?
Those units aren't units of the eigenfunctions; the eigenfunctions are wave functions, whose units are "square root of probability density".
The units you are talking about--momentum, energy, etc.--are units of observables. Observables are operators, not wave functions.
What textbooks on QM have you read? How much of the actual math of QM are you familiar with?
If the answers are "none" and "not much", then I would strongly recommend remedying that first, before trying to figure out any "intuition". You can't expect to have an intuitive grasp of something if you don't understand how it works or what predictions it makes or how those predictions are confirmed by experiments.
