Is this a valid operation (integration by parts)?
The discussion revolves around the validity of operations involving integration by parts, specifically in the context of a function defined as f(x) = x sec(f(x)). Participants explore the steps taken to manipulate integrals and the implications of those manipulations, including the use of the Lambert W-function.
  • One participant presents a function and attempts to apply integration by parts, questioning the validity of cancelling dx in the integral manipulation.
  • Another participant introduces the Lambert W-function and provides a potential solution for a related integral, prompting questions about acceptable forms of answers.
  • There is a discussion about the correctness of the manipulation steps, particularly regarding the expression involving f(x) and its derivatives.
  • One participant suggests that the manipulation involving cancelling dx is acceptable, while another questions the absence of a specific term in the integral transformation.
  • Corrections to earlier posts are noted, with participants confirming the adjustments made to the problem definition.
Participants express differing views on the validity of certain mathematical operations, particularly regarding the manipulation of integrals and the use of the Lambert W-function. No consensus is reached on the correctness of all proposed steps.
Some assumptions about the functions and their properties may not be fully articulated, and the discussion includes unresolved questions about the validity of specific mathematical transformations.
jam_27
Say I have a function,
f(x) = x sec (f(x)) [this is just an example function, the actual problem is more complicated]
g(x) = x f(x), then using integration by parts, I can write
I = abg(x) dx = abx f(x) dx = (f(x) [itex]\frac{x^{2}}{2}[/itex])|[itex]^{b}_{a}[/itex]- [itex]\frac{1}{2}[/itex]ab[itex]\frac{d f(x)}{dx}[/itex] x2 dx
Then can I write the integral as (cancelling dx from the numerator and denominator in integral on the RHS)?
I = (f(x) [itex]\frac{x^{2}}{2}[/itex])|[itex]^{b}_{a}[/itex]- [itex]\frac{1}{2}[/itex]f(a)f(b) x2 df
or,
I = (f(x) [itex]\frac{x^{2}}{2}[/itex])|[itex]^{b}_{a}[/itex]- [itex]\frac{1}{2}[/itex]f(a)f(b) f2 cos2 (f) df ?
This is simplified version of my actual problem. So any inputs will be very useful?
PS: I have edited the originally posted problem definition as it was causing confusion.
So you need to find the integral
[tex]-\int_a^b xW(-x)dx[/tex]
where ##W## is the Lambert W-function?
What kind of answers are acceptable? A closed form solution? A series solution?
Wolfram alpha gives the following:
[tex]\int - x W(-x)dx = \frac{x^2(1 - W(-x))(2W(-x)^2+1)}{8W(-x)^2}[/tex]
which in term of your notation would be
[tex]\frac{x^2(1 + f(x))(2f(x)^2 +1)}{8f(x)^2}[/tex]
I know about the Lambert W-function. As I said, above is a simplified version of my actual problem. so I specifically need to know if my last 2 steps are valid operations. Thanks
OK.
I think this is ok.
I = (f(x) [itex]\frac{x^{2}}{2}[/itex])|[itex]^{b}_{a}[/itex]- [itex]\frac{1}{2}[/itex]f(a)f(b) [itex]\frac{f}{e^{f}}[/itex]df ?
Any reason why you don't have ##f^2/e^{2f}##? You have ##x = \frac{f(x)}{e^{f(x)}}## and thus ##x^2 = \frac{f(x)^2}{e^{2f(x)}}##. No?
Thanks, I have corrected the typo and also the original problem definition. Please see if its ok now.
Seems fine to me.
  • · Replies 31 ·
  • · Replies 20 ·
  • · Replies 27 ·
