Is this angular momentum question correct?
The discussion centers on a physics problem involving a ball colliding with a pole and the calculation of angular speed after the collision. The initial angular momentum of the ball is calculated using the cross product of the displacement and momentum vectors, resulting in L = -d/2 * m * v. The final angular momentum is expressed as the product of the final inertia and angular speed, with the final inertia being the sum of the ball's and pole's moments of inertia. The rearranged formula for angular speed is omega = [-d/2 * m * v] / [(mr^2) + (ML^2)/12]. There is a suggestion to clarify variable usage to avoid confusion in calculations.
Lachlan1
A ball traveling in a straight line, colides with the end of a pole on a centre pivot, ie, the pole initially has inertia given by equation (ML^2)/12.After the colision, the ball sticks to the pole and the two rotate together. What is needed to be found is the angular speed
use the variables m for mass of ball, d for length of pole, omega symbol for angular speed, v for speed of ball before colision.
cross product of vectors for ball initially are sued to generate the balls angular momentum.
so, angluar momentum=(displacement vector) *(momentum vector) = L = r*p
i take this as L=-d/2 *m*v
this is also angular momentum intital, as the conservation of momentum is used to calulate the resulting angular speed. the final angular momentum = inertia *omega
final inertia is equal to the sum of the two moment of inertias about the axis. this is
mr^2 + (ML^2)/12
using
-d/2 *m*v=(omega)(mr^2 + (ML^2)/12)
rearange to isolate omega results in
omega= [-d/2 *m*v]/[(mr^2) + (ML^2)/12]
is this right though? I am not sure I've done the cross product correctly.
Assuming that the velocity of the ball is perpendicular to the pole when it hits, it looks ok to me.
Though, you probably want to express r and L (in ML^2) in terms of d to avoid confusing yourself later (especially since you also used L to mean angular momentum).
yeah, ok. thanks for your help
