Is this Best alternate to battery electric vehicle?
The discussion centers on a new technology that uses water and aluminum to generate hydrogen for vehicle propulsion, claiming efficiency of 1 kg of aluminum for 600 km in a 900 kg vehicle. However, concerns are raised about the operational cost of approximately $0.50 per mile, suggesting that while the system could function, it may not be economically viable. The original patent holder may have abandoned the project after realizing its impracticality. Speculation about the inventor's absence and potential embarrassment is mentioned, along with a call for further investigation into the technology's feasibility. Overall, the technology is questioned as a viable alternative to battery electric vehicles.
sr241
i found that this invention uses water and aluminum to make hydrogen in the most efficient way, uses only 1 kg aluminum for 600km for a 900kg vehicle. for more details click the link http://anon99.tripod.com/water_engine/index2.html
Is this technology a better solution for today's crisis. if so, why isn't used till now.
Wow. I didn't know Globalspec had their own forum.
Anyways, someone there named Blink described why it is a bad idea. See post # 75 in the following http://cr4.globalspec.com/thread/5405" .
I'll briefly summarize what Blink said:
Although the system would work, running a vehicle using this system has a cost of roughly $0.50 per mile.​
The original patent holder probably realized this after he got one working.
United States Patent
http://www.google.com/patents?id=dworAAAAEBAJ&printsec=claims&zoom=4#v=onepage&q&f=false" Oct 27, 1987
Continuation of Ser. No. 790,361 Oct 23 1985, abandoned
Continuation of Ser. No. 332,803 Dec 21 1981, abandoned
And after working on his invention for so many years, was probably very upset that he didn't just sit down for 10 minutes and do the math beforehand. He probably changed his name out of embarrassment.
Which of course, led to the obligatory conspiracy line from your link:
Where is the inventor?
Then again, maybe he understood his invention, and just tired of kooks asking him about it.
Calling Professor Francois P. Cornish! Where are you!
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
