Is this flow turbulent or laminar?
  • Thread starter Thread starter teoman
    Flow laminar
The discussion centers on whether the flow over a wing is turbulent or laminar, given Reynolds numbers ranging from 350,000 to 1,500,000. It is clarified that the critical Reynolds number for determining turbulence is not strictly 4,000 for all flow types, particularly in external flows like those over wings. While the flow at these Reynolds numbers is likely turbulent, it is noted that laminar flow can still occur on very smooth surfaces. The transition from laminar to turbulent flow can happen early if the wing surface is rough. Experimental testing is suggested as the most reliable method to determine the flow characteristics accurately.
teoman
Hello,
is it a case of turbulent flow over a wing if the relevant Reynoldsnumbers are 350.000 to 1.500.000?
Teoman
Isn't Re > 4.000 = turbulent only applicable to pipe flow?
Hello,
I thought Re > 4.000 = turbulent is only applicable to pipe flow?
Am I wrong?
Teoman
It's turbulent for any Re > 4000. The calculation of Re number depends on what type of flow it is. For open systems (such the wing is in this case) you have to use hydraulic radius instead of charasterictic length used in pipe flows.
There is a wikipedia article how to calculate certain flows hydraulic radius:
http://en.wikipedia.org/wiki/Hydraulic_radius#Hydraulic_radius
Not really. Hydraulic radius is for channel flow. For external (non-channel) flow, it's true that Re = 4000 is not necessarily the critical reynolds number. Unfortunately, it can be difficult to get the true critical reynolds number without experimentally testing it, but it can be anywhere from a couple thousand up to roughly 1 million. In general, for a wing at Re = 3.5*105 to 1.5*106, I would guess that the flow is turbulent, as it is near the upper end of this range. At the very upper end of this range (Re just under 106), you would probably only get laminar flow on a very smooth plate. Of course, just because turbulent flow exists doesn't mean that it's turbulent over the whole wing. If the wing surface is rough at all, you'd probably get a transition to turbulent flow pretty early on, but if the wing is smooth, a significant portion of the wing would have laminar flow. Again, I'm not sure how to determine exactly how much would be laminar aside from experimentally.
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
