Is this possible? Magnetic tires
  • Context: Undergrad
  • Thread starter Thread starter theboom
    Magnetic Tires
The discussion revolves around the feasibility of magnetic tires for vehicles, exploring theoretical designs, potential applications, and practical challenges. Participants examine concepts related to magnetic levitation, energy requirements, and the mechanics of tire rotation.
  • Some participants express skepticism about the practicality of magnetic tires, citing the need for a power supply and concerns about energy consumption from the car's battery.
  • Others suggest that permanent magnets could be integrated into the tire design, although challenges related to maintaining magnetic field proximity are noted.
  • A participant points out that the geometry of a spherical tire may complicate the use of Permanent Magnet AC motors, affecting efficiency and performance.
  • Concerns are raised about the accumulation of metal debris on the road and its potential impact on tire performance, with some questioning whether magnetic fields would prevent this issue.
  • Some participants propose that the electromagnetic field could originate from within the tires, with magnets on the car to facilitate movement, likening it to maglev technology.
  • There are mixed opinions on the advantages and disadvantages of such a system, with some highlighting low-speed maneuverability as a potential benefit while others cite high costs and reliability concerns.
  • One participant suggests an alternative using compressed air for vehicle suspension, indicating a preference for simpler solutions over complex magnetic systems.
Participants do not reach a consensus on the feasibility of magnetic tires, with multiple competing views and unresolved questions regarding practicality, efficiency, and design challenges.
Participants express uncertainty about the level of precision required for the system to function effectively, as well as concerns about the weight and energy demands of the proposed tire design.
theboom
I hope I am posting this in the right place but forgive me if I am not.
I randomly came across this video and was wondering if this is even possible. I have limited knowledge on this but I have a few thoughts as to why this would not work. First, would you not have to have a power supply in the tires as well to power an electromagnet strong enough to pick up the car? You would also use a ton of energy from the cars battery to power the magnets in the car. Even if you manage to power the magnets in the tires, how would you keep the pools aligned with the tire spinning? A gyroscope? I could be wrong about this next part but based on my limited knowledge of how an electric motor works, how would you transfer power to the wheels to make the tire rotate? An electric motor requires a coil all the way around the center shaft right? Well the entire bottom half of the tire has nothing around it so how would it make it rotate? The only axis that has something all the way around it is horizontaly making the tire spill in place like a spin top which would not move the car anywhere.
People in the comments of the video keep siting a maglev train as to how it would work but from my understanding, this is not how a maglev works at all. A maglev has magnets on the track and train to levitate and more magnets in the track in front and behind the train that push and pull to make it move. It doesn't rotate anything and because it would require magnets to be installed in every road, that solution would never work.
Are my thoughts correct here?
This design would work in principle. The tires could have permanent magnets positioned throughout.
A problem might be in getting the magnetic field close enough to the tire - even with tread wear and when the tire is dirty, iced up, etc.
At this link: http://www.marathonelectric.com/docs/SyMAXFAQ.doc
I found this:
Permanent Magnet AC motors are inherently more efficient due to elimination of rotor conductor losses, lower resistance winding and “flatter” efficiency curve. Due to their synchronous operation, PMAC motors offer more precise speed control. PMAC motors provide higher power density due to the higher magnetic flux as compared with induction machines. Finally, Permanent Magnet motors generally operate cooler, resulting in longer bearing and insulation life.
Of course, in this application many of the advantages of using a PMAC will be severely offset by the required geometry of the rotor being a spherical tire and the inner stator surface being a section of a sphere.
It has many great possibilities, but can one imagine a road free of metal fragments of all kinds sticking to the tires and what the magnetic track path would look like with all the sharp points of metal sticking straight up.
Copied the picture below from this site.
Why should the metal fragments stick to the tires. won't the car and tires have repulsive magnetic fields to stop this..
Only other magnets can be repulsed. Metal is only attracted to magnetic fields.
I think it is assumed that everything will be within the tire. The electromagnetic field comes from within the tires themselves and the permanent magnets are on the car. This way, it would be feasible to make it work similarly to your maglev example. Magnets on the car in "front" and "behind" the tire (what ever direction that maybe) that push and pull to make it rotate.
From other videos I've seen, this is more of study case to show what is feasible in tire technology such that other area can research more in their own fields. You know, like: «Wouldn't it be wonderful if tires were spherical, then we could adapt our technology to it.» Well, wonder no more, some people are seriously looking into that right now.
So what you guys are saying is that this is actually possible? I really didn't think it was. If this is possible, the only advantage would be the maneuverability at low speed. I can think of many disadvantages.
I had to go back to the video and pause it in order to read the captions (didn't do that the first time) so I'll retract my comments about how much trash would be picked up magnetically.
However having driven all kinds of vehicles on all types of road surfaces, for almost 60 years, I still have some doubts about the level of perfection that would need to be maintained in order for this to work ?
I do like the idea and I think a less expensive system might be possible using compressed air to suspend the vehicle over the tires, friction transfer to drive the wheels. (but then I guess I'm resisting the future too much in my old age) :wideeyed: :rolleyes: :biggrin:
To me, even if you could get this to work, the only advantage would be the low speed maneuverability. Cons would be plentiful. Cost would be astronomical. I would be very concerned with reliability. Unless the ball can collapse a little, the contact patch would be tiny. If it can collapse, I think it would have to collapse so much that heat would become a problem. Auto makers spend a lot of time and money trying to get as little unsprung (or in this case, unmagleved?) rotating weight as possible. Unsprung is important for ride quality and traction safety. The heavier the tire assembly, the more it "bounces" over bumps causing a safety traction issue. Rotating weight is important because it takes longer and more energy to speed up and slow it down. These spherical tires would weight a LOT. Yes you get rid of the rim but you have about 3x the rubber and a bunch of heavy as hell magnets. It would take a ton of extra energy to accelerate and slow the car and it would do it MUCH slower that a traditional car. Driving down the road with a sudden crosswind would likely cause a uncontrollable lane change. I think stealing would be an issue because they are not actually connected to the car and they would be way more valuable than a regular tire. We are focusing on efficiency lately and this thing is not efficient at all. The amount of energy require to levitate the car and rotate the tire would be through the roof. How do you power the magnets in the tire? This would be very difficult and add even more weight. Lastly, this is one of the biggest violations of the K.I.S.S. principal ever.
Don't you are right.
So even if the field is repulsive the tyres will still pick up metal.
They might be better on a hoover.:smile:
Either the batteries would not produce or hold enough power, or whatever generator used would not produce enough electricity. Presently we are looking at better batteries, but a far more productive course might be to look at better electrical production bypassing a battery completely. When this is achieved all new sorts of power plants are viable
Don't electric cars these days already have independent motors on each tire? If that's the case you could have them rotate just as well as those ball tires, but with much less pain. I think the major reason for cars not being able to turn their wheels 360 degrees is because of the common drive shaft.
My limited understanding of electrical induced levitation gives me the impression that not a lot of electrical energy would be required to hold the body above the ball wheels, but changing of load weight and distribution would pose a real challenge.
As stated, I like the idea but think it is quite limited in many ways. I will continue to think air suspension might be more practical and see the extension to six or eight ball wheels, which might give a vehicle that can drive across lakes or still water conditions, but that starts to take the thread in a wrong direction. (sorry) :frown: :smile:
Maybe someone can explain the concept of how much electrical energy would be needed to levitate, I have a pretty good idea of the drive forces that would be required.:smile:
ps. I almost forgot to put my thought in, which is that the ball wheels will completely eliminate the suspension alignment problems that all current vehicles have now. :rolleyes:
What about all the cons I listed in post #10? I personally really don't want this to happen. I just was curious if it was even possible.
As an electric design, I pretty well agree with most of your cons, lite-weight and large air gaps do not go well with electric power transfer.
As a mechanical design floating on air over the ball tires, using some form of friction transfer, I see a lot of potential. That comment deviates from the OP so I will stop with that. :smile:
  • · Replies 33 ·
  • · Replies 42 ·
