Water tank conservation of energy approach
- Thread starter sg001
- Start date
53 replies · 7K views
sg001
- 134
gneill said:You didn't take advantage of the fact that L = dr + dR in order to eliminate dr. Take the initial expression and replace dr right away.
Ok so I have dR= ((L-dR)dm)/(M+m-dm)
So integrating
R=∫((L-dR)dm)/(M+m-dm)
But how do I integrate that?
I still have to many terms?
sg001
- 134
gneill said:You haven't isolated dR. It still appears on both sides of the expression.
I am aware but from the eqn's
dR +dr = L & (M+m-dm)dR=dr(dm)
You can't isolate dR without introducing dr...
am I missing something?
Mentor
- 20,989
- 2,934
sg001 said:I am aware but from the eqn's
It's just algebra. Replace dr using dr = L - dR. Move everything to the L.H.S. Expand and collect all the dR terms together. Rearrange with dR alone on the L.H.S.
Mentor
- 20,989
- 2,934
Rethinking it a bit, a simpler approach would be to let M be the total original mass of the tank plus water. You want to move a quantity m of that total mass (representing the water) through the pipe. Then
##(M - dm)dR = dm\;dr ~~~~## and as before, ##~~dr = L - dR##
##dR = L \frac{dm}{M}##
Integration is trivial, with limits 0 → m
##R = \frac{m}{M}L ##
sg001
- 134
gneill said:Rethinking it a bit, a simpler approach would be to let M be the total original mass of the tank plus water. You want to move a quantity m of that total mass (representing the water) through the pipe. Then
Ok so now the eqn for the distance traveled x = R=∫m/M *L with limits 0 &m
and final velocity =0.
Thanks!
sg001
- 134
Thanks for the continuing help
Greatly appreciated.
Mentor
- 20,989
- 2,934
sg001 said:Thanks for the continuing help
We'll see...
I've decided to add some confusion back into the mix. Upon rethinking the rethinking, I've decided that the previous form of the integration makes more sense
At some time partway through the emptying of the tank, let's say that an amount x of the water has already gone down the pipe. That leaves the tank plus remaining water with mass M-x. It's this remaining mass for which we need to find the dR associated with the next dx that's moved.
##((M - x) - dx) dR = dx\;dr##
##((M - x) - dx) dR - dx (L - dR) = 0~~~~~## because ##dr = L - dR##
##dR = L \frac{dx}{M - x} ##
Integrate that for x going from 0 to m, the mass of water drained. M is still the mass of the tank plus the initial amount of water.
EDIT: Changed variable dm to dx in order to have it reflect that it's affecting x, the water that's being shifted.
sg001
- 134
gneill said:We'll see...
ok so I have R = ∫L(dx/M-x) = ∫L (M-x)^-1 dx.
But then I have R= -L
Or could it be,,
R = -L(ln(M-x) + c
sg001
- 134
ok...
so x = R = (-L(ln(M-m)) - (-L(ln(M-0))
sg001
- 134
Finally...
x = R= -L(ln(M-m)-(M-0))
sg001
- 134
gneill said:You need to check your log manipulation math. ln(x) - ln(y) ≠ ln(x - y).
Ohh yeah My bad simple yet stupid mistake.
x= R = -L(ln(M-m)-ln(M-0))
sg001
- 134
woops
R = -L(ln((M-m)/(M-0)) = x
sg001
- 134
gneill said:It can still be cleaned up some. Drop the zero and use the fact that -ln(b/a) = +ln(a/b).
Ok so I have now
R = L (ln(M/M-m)) = x
sg001
- 134
gneill said:That looks much neater.
Thanks again gneil!
sg001
- 134
sorry gneill!
- etotheipi
- · Replies 18 ·
- Introductory Physics Homework Help
- Replies
- 18
- davidpele
- · Replies 5 ·
- Replies
- 5
- entropist1
- · Replies 6 ·
- Replies
- 6
- Hertz
- · Replies 2 ·
- Replies
- 2
- aa_o
- · Replies 3 ·
- Replies
- 3
- Oliver Legote
- · Replies 5 ·
- Replies
- 5
- Aeronautic Freek
- · Replies 13 ·
- Mechanics
- Replies
- 13
- JJ__
- · Replies 7 ·
- Replies
- 7
- GrimUpNorth
- · Replies 3 ·
- Replies
- 3
- StinkLog
- · Replies 2 ·
- Replies
- 2
