Is |α₁⟩ a stationary state and eigenstate of L² and Lz?
  • Thread starter Thread starter CINA
    Eigenstate State
3 replies · 3K views
CINA
For the three-dimensional harmonic oscillator
[tex]H_{xyz} = \frac{p_x^2}{2m}+\frac{p_y^2}{2m}+\frac{p_z^2}{2m}+\frac{1}{2}m \omega^2 x^2 + \frac{1}{2}m\omega^2 z^2 + \frac{1}{2}m\omega^2 z^2[/tex]
Consider:
[tex]| \alpha_1 > = \frac{1}{\sqrt{2}} (|n_x = 0, n_y = 0, n_z = 0> + |n_x = 0, n_y = 0, n_z = 1> )[/tex]
and
[tex]| \alpha_2 > = \frac{1}{\sqrt{2}} (|n_x = 1, n_y = 0, n_z = 0> -i |n_x = 0, n_y = 1, n_z = 0> )[/tex]
Does it correspond to:
a) A stationary state
b) an eigenstate of [tex]l^2[\tex]<br /> c) an eigenstate of [tex]l_z[\tex]<br /> <h2>Homework Equations</h2><br /> <br /> a) [tex]H=(N_x +N_y + N_z +\frac{3}{2})\hbar \omega[/tex]<br /> <br /> b) [tex]L^2 = L_x^2 +L_y^2 +L_y^2[/tex]<br /> <br /> c) [tex]L_z=xp_y-yp_x[/tex]<br /> <br /> <h2>The Attempt at a Solution</h2><br /> <br /> I think for a) I can just apply the operator and see whether it is a multiple of the original function of not.<br /> <br /> It seems like I should do c) before b) and I always have trouble with operator manipulation.<br /> <br /> What does [tex]L_z=xp_y-yp_x[/tex] applied to<br /> <br /> [tex]| \alpha_1 > = \frac{1}{\sqrt{2}} (|n_x = 0, n_y = 0, n_z = 0> + |n_x = 0, n_y = 0, n_z = 1> )[/tex]<br /> <br /> look like? How do you apply to position and momentum operators to alpha? What are the eigenvalues you are supposed to get out look like?[/tex][/tex]
The first thing to do is step back and see what you actually have there.
i.e. how are these states constructed? i.e. what kinds of states are they made from?
##\renewcommand{\ket}[1]{\left| #1 \right\rangle}## It's shorter to write: using ##\ket{n_x,n_y,n_z}##
##\ket{\alpha_1} = \frac{1}{\sqrt{2}}\big( \ket{0,0,0} + \ket{0,0,1} \big)##
##\ket{\alpha_2} = \frac{1}{\sqrt{2}}\big( \ket{1,0,0} -i \ket{0,1,0} \big)##
... makes them easier to read.
Alright, I have trouble with terminology: The states [tex]|\alpha_1>[/tex] and [tex]|\alpha_2>[/tex] are superpositions of three-dimensional harmonic oscillator eigenstates as expressed in the the [tex]|n_x,n_y,n_z>[/tex] basis (don't know what exactly you'd call this basis.) Is that correct? An alternative basis would be the [tex]|n,l,m_l>[/tex] ("angular momentum basis?") basis, correct?
For part a) I did:
[tex]H = (N+\frac{3}{2})\hbar\omega[/tex]
so,
[tex]H|\alpha_1>=\frac{1}{2}(N\hbar\omega|0,0,0>+\frac{3}{2}|0,0,0>+N\hbar\omega|0,0,1>+\frac{3}{2}|0,0,1>)[/tex]
[tex]H|\alpha_1>=\frac{1}{2}(\frac{3}{2}|0,0,0>+\frac{5}{2}|0,0,1>)[/tex] So not a stationary state since [tex]H|\alpha_1>\neq E|\alpha_1>[/tex]
I found [itex]H|\alpha_2>=\frac{5}{2}|\alpha_2>[/itex]
For part b) we are allowed to simply give an argument.In class we derived something like this picture:
(Source: http://arxiv.org/pdf/0808.2289v2.pdf, Page 5) where the y-axis is the HO energy levels. So, here is my attempt at an argument for whether they are eigenstates of [itex]l^2[/itex]...
For [itex]|\alpha_2>[/itex] the state will always be in energy eigenstate with [itex]E=\frac{5}{2}\hbar\omega[/itex] which corresponds to an inaccessible hole in the above figure, so it is NOT an eigenstate of [itex]l^2[/itex]. It IS an eigen state of [itex]l^2[/itex] since both states correspond to l=1.
For [itex]|\alpha_1>[/itex] it is a superposition of [itex]|0,0,0>[/itex] (accessible,defined [itex]l^2[/itex]) and [itex]|0,0,1>[/itex] (inaccessible). Since it is not strictly a superposition of accessible (and consistent) [itex]l^2[/itex] states, it is NOT an eigenstate.
Is there any merit to this?
EDIT: and for c) [itex][H,l_z]=0[/itex] so they are compatible observables...which means that if an H eigenstate exists, an [itex]l_z[/itex] must as well?
The nx ny and nz label what? you have identifies |a2> as an energy eigenstate ...
It would help if you could express the nx-z basis into angular momentum basis right?
How do you change basis?
Have you done some work on commutators and simultaneous eigenstates?
[edit] off your edit: well done ... you can also do ##[H,L^2]## and check the other one as well.
Careful - the commutation means that simultaneous eigenstates are possible, but a particular eigenstate may not be simultaneous.
i.e. A linear combination of eigenstates for H may not be an eigenstate of a commuting operator.
Something in there should sound familiar with something you've done in class recently.
