Is Y a Surjective Ring Homomorphism?
  • Thread starter Thread starter cagoodm
cagoodm
Let T be the ring of all continuous functions from the closed interval [0,1] to R. Define a function Y: T-->R by Y(f) = f(1)
Prove that Y is a surjective ring homomorphism.
Is Y an isomorphism? Prove your answer is correct.I honestly just don't understand what this is asking... but I think it has to be surjective because every function in f is mapping to f(1). Is that the right way of thinking about it?
But, it can't be an isomorphism because it's not one to one, there are multiple functions mapping to the same f(1)
Any help would be greatly appreciated. Thank you!
Well, you're doing the correct things. The only thing you still got to do is to write it formally.
Let's begin with the homomorphism thingy. You need to show that
1) Y(f+g)=Y(f)+Y(g)
2) Y(fg)=Y(f)Y(g)
3) Y(1)=1
Then for surjectivity. You need to take an a in R arbitrarly. You'll need to find a function f such that Y(f)=a. There's an easy function f which does that.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
