Isolated singularity (complex analysis)
Sartre
1) \frac{e^{z}-1}{z}
Locate the isolated singularity of the function and tell what kind of singularity it is.
2) \frac{1}{1 - cos(z)}
z_0 = 0
find the laurant series for the given function about the indicated point. Also, give the residue of the function at the point.
1) I thought that it first was a removable singularity. Because of only z in the denominator. But I don't get why the value at 0 is 1 ? I attempted to use g(z) = z, calculate with H(z)/(z - z_0) But that didn't help me in the understanding of the question. So my question really is how do you know what the value is at the 0. And how do you calculate the singularity with more rigour!
2) First thing I saw was \frac{1}{1 - z} and that is e^{z}
But then I thought that maybe you take the taylor expansion of cos z and e^{z} and multiply them. But from there it went downhill :confused:
z_0 = 0
What is the Taylor's series, about 0, for ez? Subtract 1 from the Taylor's series and then divide by z. What is the value of that when z= 0?
I don't understand this at all! In what sense is \frac{1}{1 - z} the same as ez?
You're confusing me! There is no ez in problem 2!
If you multiply both numerator and denominator by 1+ cos(z) you get
\frac{1+ cos(z)}{sin^2(z)}[/itex]<br /> You might find that simpler to work with.
Hallsofivy: first of all, thanks for the quick response! I am very grateful for this :smile:
on problem #1; isn't the taylor series e^{z} for \frac{z^{n}}{n!}?
then you get z + \frac{z^{2}}{2!} + \frac{z^{3}}{3!} + ... + \frac{z^{n}}{n!} so if you divide by z you get 1 + z + \frac{z^{2}}{2!} with all of the z:s being zero and a 1 left! thanks for that one, when you explained, it became rather straightforward.
on problem #2: I thought that e^{z} equals \frac{1}{1 - z} because if you take the taylor series to the limit it becomes that. But it was apparently wrong. And getting to know that is rather nice. And maybe I should just get the e^{z} thinking out of this problem. I will come back to you with my solution on this problem tomorrow.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
