Isolating variable confounded by cursed reciprocals
  • Thread starter Thread starter Atomised
    Variable
The discussion revolves around solving two equations involving variables x and y, specifically xy = 1 and x(t^2) - y = (t^3) - 1/t. Participants explore methods to express x and y in terms of t, with one user initially struggling to isolate the variables. After several attempts, they discover that substituting y = 1/x simplifies the problem, leading to a quadratic equation that reveals two solutions for x and y. The conversation highlights the importance of recognizing the symmetry in the equations and acknowledges the need for careful substitutions to find all possible solutions.
Atomised
Given
1) xy = 1
2) x(t^2)-y = (t^3)-1/t
Express x in t, y in t
2. The attempt at a solutionx/t = [(tx+1)(td-1)] / [(t^2)-1] but I still can't separate t and x, driving me mad it is.
Also subtracted 1) from 2) to obtain
(t^2)x - (t^3) +1/t -1/x = 0
but no progress from there.
That's a good start. You can get rid of the fractions by multiplying everything by tx.
Then, if you know t and you want to find x, what sort of equation do you have?
Likes 1 person
(x - t) (x t^3 + 1) = 0, therefore x = t, and (1) implies y = 1/t.
Solved thank you very much. I am self studying and this forum is incredibly helpful.
Atomised said:
Given
1) xy = 1
If your second equation is
t^2 x - y = t^3 - \frac{1}{t}
then, substituting y = 1/x from the first equation gives you
t^2 x - \frac{1}{x} = t^3 - \frac{1}{t}
so if you divide through by t you find that the 'variable' ##z = xt## obeys
z - \frac{1}{z} = t^2 - \frac{1}{t^2}
There are two solutions for ##z##.
Likes 1 person
Atomised said:
(x - t) (x t^3 + 1) = 0, therefore x = t.
There are two solutions to that quadratic equation. not one. if AB = 0, either A = 0, or B = 0.
Likes 1 person
Full Solution
x_1=t\\ y_1=1/x\\ x_2=-1/t^3\\ y_2=-t^3
It is not immediately apparent to me what the advantage of making this substitution is. Is it that it makes apparent that $$z=t^2$$ and therefore $$x=t$$
Or could it be that it is suggesting the difference of two squares identity, which I cannot see how to use?
You can do it however you want; it all amounts in the end to finding the two solutions of a quadratic equation. However, the form ##z - 1/z = t^2 - 1/t^2## has nice "symmetry" that allows one to spot the two solutions right away, with almost no work. The solutions are ##z = t^2## and ##z = -1/t^2##. The point is that both sides of this equation involve differences of terms that are reciprocals of each other, and that makes the solution easy to write down.
I cannot figure out why you refuse to acknowledge that there are two solutions.
Likes 1 person
Fully acknowledge two solutions - it was hare brained of me to omit in earlier post. I will experiment with substitutions more from now on.
