LayMuon
- 149
- 1
How can one prove that for homomorphism [itex] G \xrightarrow{\rho} G' [/itex] and H as kernel of homomorphism, quotient group G/H is isomorphic to G'?
Thanks.
Thanks.
Ben Niehoff said:Think about what happens to H under the mapping, and how this relates to the definition of G/H.
This is only true if ##\rho## is surjective. In general, ##G/\ker(\rho)## is isomorphic to ##\text{image}(\rho)##, which may be a proper subgroup of ##G'##.LayMuon said:How can one prove that for homomorphism [itex] G \xrightarrow{\rho} G' [/itex] and H as kernel of homomorphism, quotient group G/H is isomorphic to G'?
But you already defined ##\rho## as a map from ##G## to ##G'##. It can't also be a map from ##G/H## to ##G'##.LayMuon said:I understand that it suffices to prove that [itex] Ker[G/H \xrightarrow{\rho} G'] =e [/itex]. How do you prove this?
jbunniii said:But you already defined ##\rho## as a map from ##G## to ##G'##. It can't also be a map from ##G/H## to ##G'##.
jbunniii said:What is the most natural way to define ##\phi(g+H)## as an element of ##\text{image}(\rho)##?
What is an element of ##\text{image}(\rho)## which is in some way related to ##g##?LayMuon said:I don't know, how?
jbunniii said:What is an element of ##\text{image}(\rho)## which is in some way related to ##g##?
Yes, that's right.LayMuon said:By image(rho) you mean the subgroup of G' onto which G is mapped?
micromass said:So ##\rho## takes in an element of ##G## and gives you an element of ##G^\prime##.
You want to define some map ##G/H\rightarrow G^\prime##. are given the point ##g+H##. You know ##g\in G##. You want to use ##\rho## somehow to get a point in ##G^\prime##. What are you going to try?
You are overthinking this. Given an element ##g\in G##, and the mapping ##\rho: G \to G'##, can you write down a formula for an element of ##G'## which involves ##g## and ##\rho##?LayMuon said:bundle all ##\rho##s to get a ##\rho'##?
jbunniii said:You are overthinking this. Given an element ##g\in G##, and the mapping ##\rho: G \to G'##, can you write down a formula for an element of ##G'## which involves ##g## and ##\rho##?
Yes, that's what you need. So now how can you define ##\phi : G/H \to G'##?LayMuon said:##\rho(g)##
OK good, you have found the right mapping, that's half the battle.LayMuon said:##\phi(g+H)=\rho(g)## but how do you prove the isomorphism?
jbunniii said:OK good, you have found the right mapping, that's half the battle.
Now you need to prove the following:
1. ##\phi## is well defined. This is important because you defined the map ##\phi## in terms of a particular element, ##g##, of the coset ##g + H##. But that coset may have other elements. You need to show that ##\phi## gives you the same result if you choose a different element ##g_1 \in g + H##.
2. ##\phi## is an injection. i.e. ##\ker(\phi) = \{e\}##.
I think you have the right idea, but the statement is not very clear. If ##g_1H = g_2H##, then ##g_2^{-1} g_1 \in H = \ker(\rho)##, so what can you say about ##\rho(g_2^{-1} g_1)##?LayMuon said:##\rho(g_1)=\rho(g_i h_n) = \rho(g_i) \rho(h_n) = \rho(g_i) e' = \rho(g_i)##
##\rho(g_2)=\rho(g_i h_k) = \rho(g_i) \rho(h_k) = \rho(g_i) e' = \rho(g_i)##
So they are mapped onto the same point.
If ##\phi(gH) = \rho(g)##, then ##\ker(\phi)## is the set of all cosets ##gH## such that ##\rho(g) = 1##.LayMuon said:I am stuck here. ((
What is the kernel of ##\phi##?
jbunniii said:I think you have the right idea, but the statement is not very clear. If ##g_1H = g_2H##, then ##g_2^{-1} g_1 \in H = \ker(\rho)##, so what can you say about ##\rho(g_2^{-1} g_1)##?
By the way, I just noticed that in several previous posts above, I wrote ##g+H## as an arbitrary element of ##G/H##. Must be too much linear algebra on the brain. Should have been ##gH## as we are not assuming that ##G## is abelian.
OK, with that additional explanation it makes sense. Your proof is fine. So now try showing that ##\phi## is an injection.LayMuon said:I meant if ##g_1 \in g_i H## and ##g_2 \in g_i H## then they are mapped onto the same point of G'.
Right, and ##\rho(g_2^{-1})^{-1} = ??##LayMuon said:##\rho(g_2^{-1} g_1) =e'## hence ##(\rho(g_2^{-1}))^{-1} =\rho(g_1)##
jbunniii said:Right, and ##\rho(g_2^{-1})^{-1} = ??##
jbunniii said:If ##\phi(gH) = \rho(g)##, then ##\ker(\phi)## is the set of all cosets ##gH## such that ##\rho(g) = 1##.
Right, so once again you get ##\rho(g_1) = \rho(g_2)## and the mapping is well defined.LayMuon said:##\rho(g_2)##
I guess you mean "the kernel of ##\phi## is..."LayMuon said:so ##g \in H## and the kernel is H. so the kernel of gH is the ##{h_i H}## where ##h_i \in H \Rightarrow ker(\phi) = H ## , hence the kernel of G/H is trivial and the mapping injective.
No, it doesn't imply either one. What are the definitions of surjectivity and homomorphism?LayMuon said:Doesn't injectivity imply surjectivity and homomorphism?
jbunniii said:No, it doesn't imply either one. What are the definitions of surjectivity and homomorphism?
