Isothermal increase in pressure of solids
ch1000_man
How do you express work in an isothermal increase of pressure of a solid in terms of the initial and final pressure?
van der waals equation
W=Integral of PdV
(P-na/v^2)(v-nb)=nKT
P=pressure
V=volume
n=number of molecules(constant)
T=temperature(constant)
d/dV[(P-na/V^2)(V-nb)=nKT]*
The problem here is that dP and dV are very hard to separate so it is hard to substitute dP in W=integral of PdV.
(i) Why are you using the Van der waal equation of state for a solid, as it's usually valid only for real gases?
(ii) From my thermodynamics course, one of the empirical equation of states I used for a solid was
V(p,T) = a +bT +cT^2 - d (p) + e (p T)
where a,b,c,d,e are empirical constants depending on the substance.
This is valid for a fairly wide range of T and P. You should be able to find this in a handbook or a table. (or, http://www.ccl.net/cca/documents/dyoung/topics-orig/eq_state.html" )
I was really doubtful using the van der waals equation because most of the problems I encountered used this equation and it just so happened that all of them involved gases though I wasn't sure if van der waals was just limited to real gases. I thought it was a general equation. :)
I tried looking for an equation for solids but I just keep finding the van der waals eqn and the ideal gas eqn.
Anyway thanks, I'll try to use this and find an expression of work and I'll post it here.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
