Issues with Gravity: Help Amanda Solve Physics Equation
In summary: F = 0% at R = 1 Earth radius up, F = 25% at R = 2 Earth radius up, F = 11% at R = 3 Earth radius up, etc.
amandablackwood
Greetings!
I'm encouraged by the amount of people I see viewing this website... I'm in serious need of equation help.
I'm currently taking an online physics class because of my very full workload of 5 jobs, one being full time, another being very close to that, and the rest part time. (a few hours a week each - don't panic!) I'm currently about 2.5 weeks ahead in my homework! (Yay!)
Ahh, can you tell I'm a workaholic?
I've come to a real issue, and I need someone out there to maybe give me some helpful advice on where I can find out how to apply the correct equation to my problems.
How do I find out what force of Earth's gravity would have on me as a percentage of mg? I'm trying to solve that question for 1 Earth radius up, 2 Earth radii up, and if orbiting in a shuttle around 200 mi up. I'm MORE than willing to do the math - I love to learn! - but I need to know where to start. I feel a little lost, and have nobody I can ask, since it's an online class.
Thank you everyone! I really appreciate it.
Amanda Blackwood.
I would like to help you, but I don't understand your question, at all... can you state it more clearly pls...
The force of the Earth's gravity can be found using Newton's law of gravity:
[tex]F = G \frac{M_e m}{R^2}[/tex]
Where R is the distance from the center of the earth. (For R > = Earth's radius)
So, at the Earth's surface:
[tex]F = mg = G \frac{M_e m}{R_e^2}[/tex]
so... [tex]g = G \frac{M_e}{R_e^2}[/tex]
where [tex]R_e[/tex] is the Earth's radius.
So, the question is: How does the weight change when the distance goes from 1 Earth radius to 2 Earth radii ? Substitute [itex]R = 2 R_e[/itex] and then take the ratio of that force compared to the force when [itex]R = R_e[/itex]. (No fancy math; things will cancel!)
Honey, to me, this IS fancy math! LOL Thanks so much for your help. I'm working on the problem now, though I'm sure my mind is about 10 to the 5th slower than yours!
Thank you SO much!
So are my calculations correct for this being the answer?
9.8[tex]{m/s_^2}[/tex] at Earth's surface,
19.6[tex]{m/s_^2}[/tex] one radis up,
39.2 [tex]{m/s_^2}[/tex] two radii up, or am I going in completely the wrong direction?
Oh, MAN! Here's another...
How do I apply the same equation to find the [tex]M_jupiter[/tex] , if Europa orbits a nearly perfect circle in 3.55 days to go around once. It's
[tex]6.71 x {10^5} km [/tex] from Jupiters center...
I feel so lost...
I feel so lost...
Do you know Kepler's third law??
If not then think about it this way: (If you know what centripetal force is)
What forces does Europa feel from Jupiter? Also because it revolves around Jupiter it feels another force simply because of it's cuircular motion.
Since europa isn't going anywhere (that is not escaping from Jupiter) the sum of thse two forces must be zero
Thus they must equal each other
9.8m/s^2. at Earth's surface,
19.6m/s^2. one radis up,
39.2m/s^2. two radii up, or am I going in completely the wrong direction?
yes, you are completely wrong...
[tex]g' = G \frac{M_e}{R^2}[/tex] as Doc Al suggested
you should able to "see" whenever you double the R, the g' will decrease 4 times, the relation goes like [tex] g\alpha\frac{1}{r^2}[/tex]therefore, the right one should be:
2.45m/s^2. one radis up,
1.09m/s^2. two radii up,
Right. Now to put things in the form that the question asked (force as a percentage of mg) I would say that:
At the Earth surface, F = 100% mg (of course!)
At 1 Earth radius up (R = two Earth radii from the center), F is 1/4 as much, so F = 25% mg;
At 2 Earth radius up (R = three Earth radii from the center), F = 1/9 mg = 11% mg, etc.
I don't know Keplers third law... and I still feel a little lost. PLEASE tell me this is as bad as the math is going to get! The sylabus actually states that all I need to know how to do is be able to "count my money" to get all the math correct. I've been a bartender and server for 8 years. Counting MONEY isn't a problem!
Is there some simple equation I can use and memorize to put this all together?
Thanks again.
Amanda.
ok, let's see how much i remember from physics.
if I am not mistaken, this is how you can solve for the mass of jupiter.
define velocity as a function of period and radius:
[tex]v = \frac{2\pi r}{T}[/tex]
acceleration is equal to the velocity squared, so:
[tex]a = (\frac{2\pi r}{T})^2=\frac{4 \pi^2 r^2}{T^2}[/tex]
now define force:
[tex]F=M_{satelite}\frac{4 \pi^2 r^2}{T^2}=\frac{GM_{satelite}M_{jupiter}}{r^2}[/tex]
just canel out and solve for [itex]M_{jupiter}[/itex]. i hope i still remember physics correctly. those equations may be wrong. :redface: hope it works out fine.
oh, make sure you have the period (T) in the correct units.
This one's a little trickier; you'll need to know about circular motion. You'll need the period (T) of the orbit: convert 3.55 days to seconds. You'll need this to calculate the angular speed of Europa: [itex]\omega = 2 \pi / T[/itex].
The only force on Europa is the gravitational attraction, so:
[tex]F = m_E a[/tex]
The force is gravity; the acceleration is centripetal:
[tex]\frac{G M_J m_E}{R^2} = m_E \omega^2 R[/tex]
solve for the mass of Jupiter:
[tex]M_J = \frac{\omega^2 R^3}{G}[/tex]
1. What is the concept of gravity in physics?
Gravity is a fundamental force of nature that causes objects with mass to attract one another. It is responsible for keeping planets in orbit around the sun and objects on Earth from floating off into space.
2. What are some common issues with gravity in physics?
One common issue with gravity is its strength, which can vary depending on the mass and distance of objects. Another issue is the fact that gravity is a non-contact force, meaning that it can act at a distance without any physical connection between objects.
3. How can Amanda solve a physics equation related to gravity?
To solve a physics equation related to gravity, Amanda can use the formula F = G (m1m2)/d^2, where F is the force of gravity, G is the gravitational constant, m1 and m2 are the masses of the two objects, and d is the distance between them. She can also use calculus to solve more complex problems involving gravity.
4. What are some real-life applications of understanding gravity in physics?
Understanding gravity in physics has many real-life applications, such as predicting the motion of celestial bodies, designing space missions, and creating technologies such as satellites and GPS systems. It also helps us understand the behavior of objects on Earth, such as the trajectory of a ball when thrown.
5. How does gravity affect time and space?
According to Einstein's theory of general relativity, gravity is not just a force between masses, but it also warps the fabric of time and space. This means that the presence of massive objects can cause time to slow down and space to curve, which has been confirmed through experiments such as the gravitational redshift and the bending of light around massive objects.
