Iteration, linear function. convergence and divergence
janewaybos
I need to understand and prove the following: That if a>1 the function diverges, except for a special case x_0= b/(1-a). Then if a=-1 diverges for some cases and converges if x_0 is b/2. Again, not to clear on this.
lim n →∞ a^n(x_0+b/(a-1))-b/(a-1)
For a>1, then we just need to look at x_0 and b/(a-1)? If x_0 > b/(a-1), then this is + and still diverges, then we rely on -b/(a-1)? I am kind of confused and any help would be appreciated.
janewaybos said:
MOD Note: Is this your limit? What you wrote is hard to understand.
\lim_{n \to \infty} a^n \left(x_0 + \frac{b}{a - 1}\right) - \frac{b}{a - 1}
Yes.
? For a equal to 1 you have a^n= 1 so the two fractions cancel, but not a not equal to 1.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
