It's a question of what to assume......
  • Thread starter Thread starter AR1399
The discussion revolves around calculating the area wetted by a water sprinkler, assuming the water droplets behave like projectiles. The initial velocity of the droplets is denoted as v, and the range of each droplet is considered to determine the radius of the wetted area. A 45-degree angle of projection is suggested as optimal for maximizing the area, although the original question lacks clarity on the angle. Participants agree that the question may have been poorly worded, as it should specify the angle or indicate that it seeks the maximum area. The consensus is that the sprinkler sprays water in a spherical pattern, covering the area uniformly.
AR1399
A water sprinkler sprinkles water all around it. If the velocity of water coming out is v, find the area around the sprinkler getting wet.[/B]
In projectile motion,
Range = u^2 sin2(theta) / g
What I did was to assume each droplet as a projectile with initial velocity v. Looking at it that way, the range of the droplet would be the radius of the circle of area getting wet.
Everything is fine, except that nothing is mentioned about angle of projection of droplets.
I assumed 45 degrees and got the right ans. in objective type qn, but if the same comes for subjective explained ans, then which angle do we assume?
With 45 degrees, my answer was -
Range = v^2 sin90 / g = v^2 / g
So area = pi (v^2 / g)^2 = pi (v^4 / g^2)[/B]
I think the original question should read - " What is the maximum possible area covered by the water ? " .
Considering that , yes , angle taken would be 45° .
Likes AR1399
You can't assume any angle. The angle must have been omitted from the question by mistake. Alternatively, the question could have asked for the maximum possible area, which then implies 45°.
Likes AR1399
Hmmm...must be a qn error as u say. Anyway, thnx a lot for the help!
As I read the intended meaning of the problem, the sprinkler head is spraying randomly at all angles -- a more or less spherical spray. This is weakly implied by the "all around it" clause.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
