LSMOG said:
I've tried to read the reason for using Fourier transform in wave packets, I don't understand why. Please help me with this.
Is this specifically a physics question, or a question about Fourier transforms?
The issue is this: Suppose we have a particle that is initially distributed in a packet described by (in one-dimension)
\psi_0(x) = F(x)
where F(x) is some function that is strongly peaked at x=x_0. For example, it might be Gaussian:
F(x) = \sqrt{\frac{1}{2 \pi \lambda}} e^{- \lambda (x-x_0)^2}
Now, you would like to know what \psi(x,t) will look like at some time t > 0. You can try to solve the Schrodinger equation for that particular initial condition, but here's an easier way:
You know that a solution to Schrodinger's equation is \psi(x,t) = e^{i (kx - \omega_k t)}, corresponding to the initial wave function \psi_0(x) = e^{i k x}, where for the nonrelativistic Schrodinger equation, \omega_k = \frac{\hbar k^2}{2m} for a particle of mass m. So we can use that knowledge to solve the general problem:
Write \psi_0(x) = \int dk \tilde{F}(k) e^{i kx}, where \tilde{F}(k) is the Fourier transform of F(x). Then, at a later time t, the wave function will be \psi(x,t) = \int dk \tilde{F}(k) e^{i (kx - \omega_k t)}. Voila! The Fourier transform allows you to write down the general solution.
