Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #12,871
  • #12,874
NUCENG said:
I have seen quite a bit of speculation that there is a large vertical crack in thereactor pressure vessel (RPV), but cannot figure out how they could tell. There has been no entry of the Dryell (Primary Containment) due to rad levels and I am not aware of cameras that would survive longtime exposure in the drywell during normal operations and they certainly haven't installed cameras since the accident. If pressure was high enough to cause a break it would likely occur in piping or rod penetrations of the RPV. Breaches due to core melt would be on the bottom of the vessel. It just doesn't seem to me that a vertical crack in the RPV can be any more than speculation.
At least I hope so.
There are many more easier ways to fail the interfaces to the RPV then to crack the actual containment vessel. I think we'll find failed piping and as you mention rod penetrations etc and a mostly intact RPV.
Just my guess.
  • #12,875
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120418/index.html [unit 2] On 18 April, the robot checked 90% of the upper part of the suppression chamber but until now no major damage or deformation was found. The north and south inspection manholes were checked but water leaks or traces of leaks were not found, and they looked comparatively clean. Otherwise, Tepco says that leaks might be located in the parts that connect the PCV and the suppression chamber, but their status has not been checked yet and Tepco has yet to analyse the pictures taken on 18 April. The highest radiation was 120 mSv/hour in the north-western region. Saying that "It is a high value, but it is still possible to plan short time human operations for important tasks that cannot be performed by robots", among other things, Tepco is taking the necessary steps to grasp the radiation distribution.
  • #12,877
Regarding the radiation in the torus room: would it reduce the airborne radiation if they cover the water surface with oil?
  • #12,878
Tepconium-311 said:
These posts made me think of a scenario.
Readings were manually taken in intervals, yes?
Then it would be unlikely that explosion pressure/vacuum spike was recorded, right?
Could we then actually really exclude existence of such a spike?
Right, we have no continuous recordings, and not even a lot of discrete readings. Strictly the pressure readings we have can only say that the reactor pressure in unit 3 appeared to be lower after the event than it did before.
And now my questions:
Could there have been a pressure surge ("explosion") in RPV/drywell which lifted concrete reactor seal a bit for a moment, propagating hydrogen explosion from drywell to maintenance floor 5, so pressing reactor concrete seals back into place, mostly undamaged except two or three points ("white steam leaks")?
I hope you don't mind some correction in terms of understanding. The RPV/drywell/wetwell,( in short the reactor) of unit 3 is strictly a steel container, it is nowhere sealed with concrete. It's got interesting things inside it, and it has an interesting shape, but looked at from the outside one must visualise it as a mere steel container, having a closed surface made of steel. A leak in it implies there's a hole in that steel surface.
However true enough there's concrete packed up all around the reactor, for support, for radiation shielding, and for making the building structures around it, but none of all that concrete is there to keep the reactor tight. Specifically the concrete slabs stacked on top of the reactor, which I think you are referring to, are not there to keep any pressure at bay. You should, in principle, be able to operate the reactor quite well without them. So, to get back to your point, an assumed falling back of those top concrete slabs after an explosive pressure surge from the reactor could not be assumed to reseal the hole in the reactor below, from which that pressure surge would have to be coming from.
If so, wouldn't pressure wave have been directed in a way that would lift up FHM from below sideways, and then push it horizontally like a javelin into the pool?
The hall mark of the unit 3 explosion is exactly the vertically rising cloud over the building. It stands to reason that this vertical rise represented a considerable upwards mass flow over a short period. Anything that stood in its way should have experienced the impulse. So I can well imagine your scenario, it is possible that the FHM was lifted up/sideways. Only from what I have seen of the FHM it appears to be more beaten up than I'd expect if it had been just pushed sideways into the pool.
  • #12,880
Rive said:
This might be relevant regarding U3 explosion: http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120419_03-e.pdf
Aha, very interesting.
Its not terribly surprising given that we have previously seen attention paid to high radiation levels from the rail on the floor in front of this equipment hatch.
( Last november http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_111122_02-e.pdf )
However I do not recall Tepco talking about the 'crevice between shield plug and reactor building' before, so I think this new information is only going to increase suspicion that TEPCO do not reveal every detail as soon as they discover it.
My knowledge is not sufficient to judge whether this damage would occur due to explosion (e.g. explosion within containment) or whether damage to seals due to heat or pressure would be sufficient to cause such a gap & leak.
  • #12,881
My other question is whether this shield plug has moved considerably away from the position that it is supposed to be in. Is it supposed to be so much further away from containment than the rest of the containment wall? (i.e. in photo it is much nearer to camera than the rest of wall, is it supposed to be flush to wall?)
  • #12,882
As I understand it, the backside of the shield plug is not meant to be flush with the wall, but there is not supposed to be so much of an opening (the 'crevice') between the wall and the shield plug as there is now, so the shield plug is not in place, and appears as pushed out a bit from some impulse from inside the hatch.
BTW, if there is currently an active leak of water from somewhere in PCV flange of the hatch, as the wet floor inside the hatch could indicate, would that mean the PCV of unit 3 is water filled to that level?
  • #12,883
IMHO not necessarily. In U2 PCV the water level is low, but everything is wet and there is heavy 'rain' inside. A small leak can catch enough water to keep wet those rails and areas even if it's not under water if the 'weather' is any similar in U3 PCV.
Ps.:
SteveElbows said:
By the way I am quite impressed with the quality of the video from the robot that did the reactor 2 torus room survey, good detail & well lit.
It'll be perfect for steam hunting :-)
  • #12,884
Not sure, would need to know something about leak rate. As we saw from video inside reactor 2 containment, water injection/spraying can cause a lot of droplets of water to be dispersed quite widely inside containment. Failure to get inside torus room at reactor 3 doesn't help build a picture either.
http://photo.tepco.co.jp/en/date/2012/201204-e/120419-01e.html
  • #12,885
If I take the diagrams they used literally, then its been seriously displaced. We see from both the main floor plan and the smaller diagram that either side of the outer shield plug, the wall comes out at at approx 45 degree angle, so the 'frame' around the plug sticks out compared to the rest of the wall. But the shield plug is currently well beyond this, perhaps as much as a meter or so away from the frame?
  • #12,886
Those rails might be what the shield plug is traveling upon, cf.the floorplan of Unit2 which is showing the hatch in the open position:
The PCV hatch we are talking about would seem to be large opening seen to the right at the equator of the PCV bulb in that never-boring photo of a BWR reactor during construction before it gets dressed up in concrete:
  • #12,887
The more I look at the photo, the more I think that plug should be flush with the frame part of the wall.
This is because you can see behind the ladder the part of the wall that is at about 45 degrees, which to me means that the wall to the left of the ladder is the frame part that's supposed to be about flush with the plug.
  • #12,888
Yes I think this fact was fairly well discussed at the time that the rails (& attempted cleaning of rails) was news.
  • #12,889
Agreed, it seems to be displaced quite a lot more than a bit :-)
  • #12,890
No, I think that opening is on the opposite side to the equipment hatch we are talking about today. Look at where the personnel airlock is on that photo (equator).
Anyway I have been looking again at the photos and videos from November that showed robots cleaning the rail areas.
I am still a bit uncertain as to how everything should look under normal conditions. For example looking at images at left of page 2 of this document:
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_111105_02-e.pdf
It seems that the equipment hatch itself has some thin doors. Both of these doors were open in first photo, but they managed to shut the right-hand one in second photo. This is confirmed by another photo on page 4.
So now I am not sure if this entire structure has moved, or whether the plug part that moves on rails is behind these doors (and structure that sticks out is a kind of porch).
Then look at this document:
First image on page 2 shows that this structure is at an angle, not 90 degrees to the floor. Can see probable hinge for the thin doors that I mention above.
Also if TEPCO diagram of radiation detection points has point very close to where equipment hatch should be at normal time, so either diagram is lying or it hasn't really moved forwards like I suggested before.
So I think its quite easy for me to make a mistake when looking at this stuff, really could do with seeing photos of how equipment hatch of this type should look under normal conditions, but equipment hatch pictures we have seen at other sites are very different so not much help.
  • #12,891
OK I have figured out my above confusion.
There is an additional white box that has doors on it, that is in front of the main shield plug that we saw in todays photo. It is further to the left, so cannot be seen much in that photo, but it is visible in the cleanup photos which I mentioned in previous post.
Check out the following video at about the 7 minute mark, and it becomes very clear, because we can see both this protruding porch that has doors on it, and the much larger shield plug that is behind it. The grey box with black wire duct that goes upwards and then left can be seen in todays photo and that video, thus making sense of the whole thing.
http://www.tepco.co.jp/en/news/libr...368209002&bclid=59370327002&bctid=59374639002
  • #12,892
Thanks, well done! So the plug has in fact moved considerably.
  • #12,893
Well, I don't think anything I've said or shown proves this conclusively. Maybe its supposed to stick out of the wall like that, but I have serious doubts about that.
Sadly it may be hard to learn more unless some journalists actually notice this news and ask the right questions. Or someone who knows what that hatch is supposed to look like talks.
I am somewhat amused that the websites that like to do big scary headlines and poor analysis of Fukushima disaster don't seem to have noticed this stuff, maybe there is a flashing light or some weather on a camera that is distracting them.
  • #12,894
If this big plug was moved, how ? Earthquake or explosion ?One more unit 2 thermometer is broken :
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120419_04-e.pdf We evaluated the reliability of the thermometer (RPV bottom head 135°) which was monitored for reference based on safety regulations 138 through direct current resistive measurement. We evaluated the thermometer broken down based on the increase in direct current resistance. No large swings confirmed at other thermometers, monitoring posts, and PCV gas management system indicators. We will continue monitoring PCV temperature by thermometers (RPV bottom upper head 270°and RPV upper skirt junction 135°).
http://www.tepco.co.jp/tepconews/library/movie-01j.html 19 April press conference 14:50 (Junichi Matsumoto on the robot mission into unit 2's torus room) : we recorded sounds with an IC recorder, but the "beep beep" sounds of the radiation dosimeter is mixed to it, so we could not make a good sound recording. We were thinking that water flowing sounds could be checked that way, but in retrospect the situation is that it could not be done well enough. Concerning this PCV suppression chamber torus room inspection with "Survey Runner" [the robot's name], one thing is that we confirmed that it is possible to use Survey Runner for this kind of mission, and the other thing is that at this point, although some heat insulating material covers were found to have fallen down, no major pipe or equipment deformation or damage was found in the upper part of the torus room. [...] (20:26, replying to a question by NHK's Hanada) I think it is possible that the heat insulating material's covers fell down because of the earthquake. As one year has elapsed since the earthquake and the humidity was high, corrosion can also be a possible cause. The exact cause is not known, but the heat insulating material, the wool-like material itself was not blown away, so that we think the cause is not liquids or gasses flowing out of the pipe. [...] (29:01) If no damage is found in the upper part of the torus room, we'll have to find a way to inspect underwater. [...] (29:30) Hanada : What methods can be thought to inspect the inner side of the torus room and the lower part that is not submerged by water ? Matsumoto : first we have to create a route astride the suppression chamber to get to the inner side catwalk. If we manage to take Survey Runner there, we can have it make a round trip on the inner side catwalk and inspect the vent pipes. For the area between the water surface and the catwalk, the grating is an obstacle, but I think it is possible to move the camera so that it focusses downwards. At this point we have not yet decided how or when we will do that. [about sound recording] I think perhaps we can try to record sounds again after turning off [all other] sounds. [about unit 3's equipment hatch] (...) (33:30) Yomiuri's Funakoshi: What did you want to see with this survey ? Matsumoto: One thing is that if water is oozing like that, it could be a valid water level. One other thing is that when we inspected the North-eastern area with Packbot, water was accumulated near the rail, and the radiation there was comparatively high, so we thought it was quite probable that water is leaking from the PCV (...) At this point, we don't know if it is a leak. The situation is that although it is wet like this, it was not confirmed that water is flowing. Funakoshi: Which quantity of water is accumulated on the floor ? Matsumoto: the floor is somewhat wet. At present we don't know the width and length of the wet area. Funakoshi: You don't know which percentage of the area is wet, and which percentage is dry ? Matsumoto: No we don't. We only inspected a small part with the endoscope. As the radiation is high the duration of the work was 4 minutes. Funakoshi: what is the most natural leak route that can be thought ? Matsumoto: the hatch is closed with bolts, like a manhole, and the most likely route is between bolt and packing.
http://www.tepco.co.jp/en/press/corp-com/release/2012/1202043_1870.html Report submitted to NISA concerning response to safety regulation breach during first FY2011 safety investigation at Fukushima Daiichi Nuclear Power Station
  • #12,895
Are there two hatches?
Looking a MadderD's drawing in post 12898, the one at 2 o'clock is clearly a hatch with plug extended.
Opposite, 8 o'clock, is that another one with plug inserted?
It'd make sense to have one near each recirc pump for motor replacement.
Not a BWR guy,
old jim
  • #12,896
Not a BWR guy,
old jim
Well the other large opening, that you describe as 8 oclick, looks a bit different on the plans we've seen. If I take the diagram literally then I get the idea that this hatch is not routinely used, does not have rails, may have been 'bricked in'. Perhaps it is was only used during reactor construction, or could be unblocked if something went wrong with opening the other one that is normally used. Been a while since I saw photos of this area, seem to think I may have seen a picture that confirms it is blocked off, but maybe I dreamt it.
There is also the personnel airlock one, which is obviously smaller, and in a part of the building that I don't think we have seen much of.
Big shame nobody at the press conference seemed to ask about whether the plug was further forwards than it should be when closed according to what Tsutsuji translated (thanks again!). Understandable that they talk about the unseen bolted hatch by the steel part of containment and possible kind of leak, but I really wanted to know whether todays discussion about the plug being forwards is true and important or not. Now I have no idea if/when we will ever find this out!
  • #12,897
The area at the other large opening has been the scene of some cleaning and monitoring effort, so there is reasonable photo coverage of it. It appears as you say, to be blocked with a semipermanent plug. The plug appears to be in position, same as shown in the diagram of unit 2. That is: its outer face is at some distance from the wall, on the right hand side it has that 45 angles frame reinforcement you've pointed to, in order to meet the wall. On its left hand side it comes together with the shield walls around the personal airlock.
Best views I've found are at around 12:09 in this video:
http://photo.tepco.co.jp/en/date/2011/201106-e/110615-01e.html
Areas close to where the plug meets the wall to the right of this opening appear to be strong gamma sources:
http://photo.tepco.co.jp/en/date/2011/201106-e/110611-02e.html
and there has been quite some cleaning efforts at the site:
http://photo.tepco.co.jp/en/date/2011/201107-e/110702-01e.html
Assuming the plug was not moved by the earthquake or later events, the only possibility I can see how the plug can be in the semi-open position shown to us by the Tepco diagrams and videos would be if it had been intentionally, temporarily unplugged and I think if that were the case Tepco would have left no doubt about it. From that I deduce that the plug must have been moved by the earthquake or later events.
  • #12,898
One can be sure the plug is restrained for seismic acceleration. When M is that large a small A generates lots of F; that ~1/2 g quake would have made the plug push against its restraints with half its considerable weight.
Presumably there's a bolted steel door on inside that could flex on overpressure and push against the plug like a piston. The available force from pressure is far greater than from earthquake but one has to consider most of it should have been opposed by door's rigidity. We need a GE guy who knows the design of that piece.
As always not quite enough data. But it is interesting to keep these observations in the back of our mind and be on lookout for relevant details.
You guys are doing an excellent job at that.
  • #12,899
I can't exclude that the earthquake moved it, I suppose it could plausibly have moved anything anywhere, however this plug appears so distinctly to have been pushed out, so I'd put my money on an explosion (some pressure wave from it).
Thanks a lot, tsusuji, for these extra insights non-Japanese speaking users get from you.
From one of Tepco's publications, I've attached a cropped diagram, and a photo of a PCV hatch, as seen from inside the PCV. From what I've read elsewhere, the flange of a Japanese BWR would be sealed with silicone rubber seals, which should be good for at least 225 degrees C, but PCV temperatures upwards of 400 C were reported during the weeks after the explosion.
  • #12,900
The fact that the first floor into which any impulse from the crevice would have entered was covered with dust and rubble and looked like it was hit by a hurricane further supports that the plug was pushed open by the explosion. Or maybe just that an impulse passed through the crevice whenever the plug was moved.
However, could the interior hatch still be in place and any impulse that pushed out the plug have been carried by air between the PCV steel liner and the concrete surrounding it? The reason I wonder this is that despite the disarray in the first floor, I'm not impressed that it took the full explosive force one might expect had there been a direct passage from a PCV explosion into the first floor. Or maybe the hatch was largely left in place but just enough of an impulse passed through its seams to push out the plug.
Btw, which Tepco publication has those images?
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
471K
21K
  • · Replies 763 ·
284K
  • · Replies 38 ·
17K
12K
