Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #13,171
NUCENG said:
One of the most important things is to get good simulations of the conditions inside the drywell and torus during the accidents that match the information we actually have. This is likely to be available to develop new qualification requirements well before they can actually start retrieving failed cables or sensors.
I'd like first to see some honest curiosity to understand what happened at that plant, without which I can't see how one can conceptualise it and produce a proper model. Once there, implementing a good simulation of the model ought to be the trivial part. I couldn't care less about the fiddling with parameters and assumed events to get existing models to produce output with some semblance to actual data and that's all I've seen so far.
  • #13,172
Yes, you found the decay heat to be sufficient only to heat the water of the pool to about 140oF (60oC), not even warm enough to make instant coffee of, and with na'r a BTU left for evaporating any of it.
well more exactly , ... sufficient to heat HALF the water in a 'typical' pool BY 140 deg...
Boiling away 1760 lbs/hr would be around 20 tons a day, which is hardly a dent in that 1500 ton inventory.
So if the pool was not pretty low on water it got more heat from someplace.
Conversely if it got no more heat, it musta been pretty low?
i don't know which is the truth, but assumed at the time it was low on water.
Again, that was an assumption but it did fit with the 'gamma backscatter' idea as cause of high radiation readings around building, and with high radiation readings from helicopters..loss of water = loss of shielding above spent fuel.
But i wasn't there. And there's surely other possibilities.
That one could unravel.
What's your thoughts?
  • #13,173
We know that there were leaks around the reactor cavity on the side of the EQ pool. Maybe there were leaks on the other side too?
For the first times, when the internal pressure of the reactor were high that would mean steam condensing in the pool, raising it's temperature: later on as the pressure drops water would flow in and cool the containment cap.
Slightly connected: the water in the pool were filtered for cesium and other radioactive elements, but this filtering stopped after some time. Do we have any data about the pool water contamination after the filtering stopped?
I think if there is fuel with damaged cladding in the pool then the cesium level would rise after the filtering stopped. If the fuel cladding is intact, the Cs level would be steady.
If the fuel cladding is intact then there must have been other source for that Cesium.
Maybe from steam coming from the reactor, condensed in the pool?
  • #13,174
Well. First, look at the facts: There's a 1400 m3 pool of water with 0.5 MW of decay heat from spent fuel in it and its cooling has failed. 5 days later the operator informs its safety regulatory agency that due to the failed cooling, steam plumes are being emitted from the pool. The safety agency informs the public that this is the operator's estimate of the situation.
Next, there's the impeccable assumption: The laws of physics were not suspended in the pool.
Then follows the inescapable conclusion: What passed in this case as information from the operator to the agency, and from the agency to the public, was not information, not even false information. It was nonsense. Had it only been false information, that would be understandable. But no, for a statement to be possibly false, it must be implied that it can be possibly a true description of reality. Otherwise the statement is just so much nonsense -- and as your math has shown you, what was reported by the operator and sent on to the public by the agency was postulating a physical impossibility had occurred. All such statements are alike, they express nothing, they are all nonsense.
Imagine the operator had reported some other physical impossibility, e.g 'that gravity had reversed over the plant and was emptying the pool', and the safety agency reported this on to the public, the nonsensical nature of it all would have been clear to many people. It takes more knowledge to realize that a 1400 cubic meter pool of water cannot possibly be steaming plumes due to failed cooling after having been heated with 0.5 MW for a couple of days. The unsuspecting and ill-informed public would be excused in not 'getting it'. For Tepco the operator, and for NISA the agency, there is no excuse, and only a few credible explanations, none of which are flattering, and this is not the place to express them.
The fact remains, that what we were told about the situation in the pool did not make sense.
OK, so back to your considerations. If I get it, you meant to be able to extract as a fact that the pool was boiling from the nonsense "White smoke was seen rising from the vicinity of Unit-3 <..>TEPCO estimates that failing to cool the SFP has resulted in evaporation of pool water, generating steam.", then you added the assumptions that either the pool had lost a lot of water for unknown reasons, or it had an unknown heat source, then you coupled it to the observation of high doserate measured above the building, and got a plausible case of exposed fuel in the pool. But that seems to me to have been assumption upon assumption upon nonsense, and no surprise then that it was all wrong.
  • #13,175
The pool interface is of a different construction than that of the equipment pool, it is a double layered gate, held tight by the hydraulic pressure of the pool water. From what can be discerned in published video footage, the gates are in place, and a major steam route from inside the reactor seems to have passed close by, but on the side of the reactor, not that of the pool. While of course it cannot be held that the gates must be completely tight, there is no indication of any significant leak between the pool and the space over the reactor cavity, no indication that the pool has lost water to that space, or that steam from that space has added heat to the pool water. The added assumption of such a leak would seem to me superfluous, it doesn't appear to explain anything.
Pass on the Cesium thing. IRC the plan has been, using mobile units, with first reverse osmosis, then ion exchangers, to desalinate the water in the pools in turn, starting with unit 4. I do not know where SFP3 would be in the process.
  • #13,176
There could very well have been localized boiling.
However, steam plumes occur in air very commonly far below the boiling temperature. The air above the surface just has to get a saturation above the prevailing dew point.
It is fairly rare in pool applications, but any fisherman can tell you about a misty lake, which is exactly the same effect, but with the lake microclimate as the cool side.
  • #13,177
MadderDoc said:
The pool interface is of a different construction than that of the equipment pool...
Yes, you are right. Even if the FHM wreck damaged it the effect would be different. Thanks.
  • #13,178
Yes, wizwom, but this is the steam plume from 'the vicinity of Unit 3' which Tepco is talking about on March 16th:
http://gyldengrisgaard.dk/fuk/20110316_0935%20satellite/20110316_0935_Digitalglobe_zoom_thumb.jpg
Edit: See also the March 16th hourly webcam images
  • #13,179
If I get it, you meant to be able to extract as a fact that the pool was boiling from the nonsense "White smoke was seen rising from the vicinity of Unit-3 <..>TEPCO estimates that failing to cool the SFP has resulted in evaporation of pool water, generating steam.", then you added the assumptions that either the pool had lost a lot of water for unknown reasons, or it had an unknown heat source, then you coupled it to the observation of high doserate measured above the building, and got a plausible case of [nearlyjh] exposed fuel in the pool.
you got it.
IF that steam indeed came from the pool, there had to be a cause for pool being so hot.
With the modest heat input that pool had, either its thermal capacity was less than expected for that much water
or the heat input was more than expected.If neither of those is so then the steam came from someplace else.
why is that "nonsense" ?
EDIT
I think one of us misunderstands something the other is saying and our difference lies in semantics not thermodynamics. It is sooooo difficult to make communication precise.
old jim
  • #13,180
jim hardy said:
you got it.
With the modest heat input that pool had, either its thermal capacity was less than expected for that much water or the heat input was more than expected.
I apologize if I have given you the impression that seems implied by your question, I really thought I had clearly identified the target of that description to be the estimate by Tepco, that the pool was steaming plumes due to failed cooling, indeed I think you just quoted me to that effect.
What you have written there is just the sort of mental model one makes of possibilities and logical implications when one is trying to get a foothold in regards of some problem. I wouldn't call any of it nonsense. Otoh, I can't see where you are coming from with it, nor where you are going, also I think the option 'someplace else' might be specifiable both as to its whereabouts, and its logical implications. Better to chalk up the whole playing field, before deciding how to tackle the problem.
EDIT
old jim
Yes surely, but I think we will get by.
  • #13,181
Yes,seeing we can't assume there was no steam, that steam had to be coming from somewhere,
so evidently if steam was _not_ coming from the spent fuel pool, it had to come from someplace else.
However, looking at the published bits and pieces of Tepco's videos from March the 16th,
whether or not we would conclude that steam was coming from the spent fuel pool,
we would still have to accept that steam was (also) coming from someplace else,
since there is clearly a steam plume to be seen originating from the equipment pool in those videos.
In this poor video shot, we see from left to right (north to south) across the building, the contour of the equipment pool with a steam plume coming out of it,
the fallen girders across the reactor top area, and to the right of the girders, another plume, the origin of which is, shall we say, ambiguous.
The green splotch below that plume is the spent fuel pool.
  • #13,182
now i see clearly that you did. But i somehow missed it earlier. So my apology is extended.
i often try to rule things out.
When the "three minutes after" satellite photo came out showing what looks like that same plume,
i set out looking for what could have heated pool that quickly.
That path seemed implausible. I don't even know if they actually were the same plume.
So i decided to wait it out. That the plume came from someplace other than spent fuel pool is certainly not ruled out.
old jim
  • #13,183
Trying to put myself in your situation at the time you saw this photo, I imagine you'd have a possible case of nearly exposed fuel on March 16th in your mind. The satellite photo would have seemed to you to have possible repercussions to that, indicating a possible case of nearly exposed fuel already shortly after the explosion on March 14th, and then, a possible case of pool involvement in the Unit 3 explosion, the explanation of which 'hydrogen explosion' you felt was in miss of something.
As I recall, I came out from the curious incident of the pool on March 16th with no clear conception of what it was about, except for an intuitive feeling of bait and switch. I had that feeling arranged to reinforce a possible case of the presence of an unwillingness to admit PCV involvement in the Unit 3 explosion. Pool involvement, I believe, was not something I really thought of until it occurred to me that other people did. But then it just became a case for me of accommodating that possibility. To me that seemed pretty straightforward, seeing the energetics of flashing large quantities of water into steam in a short instant it left pool involvement with only a tiny probability of a case of criticality, bordering to the impossible according to experts, which I have to trust in such matters.
In respect to the never-ending circle of expanding knowledge along with language to express it ..
I suggest we can say less conservatively, that the plume from the building, at least for a part of that plume, did in fact come from someplace else, i.e. the PCV. Evidence, also evidence from a very early stage indicates this to be the case, no evidence appears to contradict it. The only inconsistency it produces is with Tepco's estimate on March 16th, which appeared to be, that the plume in its entirety was caused by evaporation of water from the pool.
  • #13,184
Thanks for 'walking in my shoes'. I find it helpful in my troubleshooting to ask myself "What would make a rational person say that? Just what was the picture in his mind right then ?"
...pool involvement with only a tiny probability of a case of criticality, bordering to the impossible according to experts
I watched the TV news video that morning and thought it had to be the SFP. I even emailed Arnie Gundersen to ask if those racks had boraflex and could go fast critical on loss of moderator.. i think i set him off on a tangent.
But as i learned more about their pools and about fast fission cross sections i too decided it wan't the pool.
Photos have since confirmed.
So next i looked into recriticality on reflood as described in ORNL and European BWR studies.
But Morbius made a pretty strong case against thermal recrificality and his credentials are awesome.
So next i looked into low enrichment Pu with U reflector.
And into Hafnium cross section at high energy(~10mev)
And what i found out is i don't know enough about fast reactor physics to make meaningful calculations. So i can't put a number on it. I admit defeat.
You could be right.
But for me that train of thought is too speculative to make any strong assertions.
As i said on another forum i'll have to wait for photographs of reactor head.
What's that "evidence from a very early stage " you mention ?
Probably i looked at it (i was obsessive back then) and tucked away in the 'unresolved observations' basket , and would like to know what facet it was that has retained your attention.
That was a very clearly communicated post, by the way . With my Asperger's i had to study it but it parsed quite well. Thanks !old jim
  • #13,185
Sorry, do you recall roughly when and in what thread was that part posted? This thread?
  • #13,186
That would be the explosion thread, now lost to time and incompetence. Sorry. Some people here may have copies of the Google cache before it expired or other such things - there is a discussion earlier in this thread wrt the demise of that thread. It was closed for moderation and never reopened. There is no backup at PF.
Morbius (aka Gregory Greenman iirc) was arguing, based on his extensive experience designing nukes and on some calculations he did, that unmoderated recriticality is impossible in reactor fuel, in any configuration, that moderated criticality is only possible in a 50/50 "matrix" configuration of fuel/(light)water, that there is no way that such a configuration could have been achieved with melted fuel.
He also stated that there is no way that the neutron-reflecting properties of either water surrounding fuel or reactor steel and other metals could have changed this.
At the time, I was obsessing over the possibility of pulsating criticality in reactor 3, which I saw as a way to explain some of the readings we saw in the first few weeks.
The issue of spent fuel in the pools was only marginally touched upon, I believe.
I present this along with pre-emptive apologies for any inexact info, both to you and to Morbius. It has been a rather long time and my memory is not getting better.
  • #13,187
It was in the 'Unit 3 explosion' thread which is no longer with us.
Would have been within a very few days of June 12 2011.
He ran a Monte Carlo program and said , to best of my recollection, 'corium' couldn't go if it has less than 10% enrichment because it lost the optimal geometry of an assembled core.
Monte Carlo is outside my experience base. All i know is it's a sophisticated neutronics program used by genuine experts.
I accepted his opinion as a solid data point. for uranium.old jim
zz posted while i was typing. He has a better memory for detail than i do.
we don't disagree, thanks zz i worry about anything i do from memory.
  • #13,188
De nada, I do too.
  • #13,189
IIRC, his challenge to criticality theoreticists is to postulate a credible mechanism for getting the fuel arranged as it is in the core and with no control rods between them, and submerged in water.
As regards the fuel in the SFP, that leaves afaics only the possibility of some disturbance overturning racks causing fuel to rearrange and come back to rest in the right positions for the criticality to happen. While not impossible, the probability of such occurrence is too low to take a theory about it seriously until one can say that one has examined and exhausted all other options for explanation.
As regards the fuel in the core, jim hardy did bring up a mechanism involving control rod melt-away in a degrading core during a LOCA. Criticality could then happen on subsequent reflooding of portions of un-melted fuel assembly parts being still in their original positions however now devoid of control rod material between them.
This would seem to me a much more likely contender for a criticality theory.
But, however much a theory of a criticality event makes a lot of exciting energy available for destruction -- the Unit 3 reactor, it must be assumed, at the time of the explosion was already shock full of hydrogen and accumulated energy in hot water, the system had already in it plenty enough of energy available for its own destruction. An assumption of criticality then becomes just one of many possible triggering factors, for its particular quality: energy, there is no need.
  • #13,190
I was thinking of the visual evidence from Tepco's intensive helicopter surveys on March 16th. Although in written sources Tepco comes over as saying that the plume in its entirety was due to water evaporated from the SFP , even this lousy video shot taken during the mission leaves no doubt that the reality of the situation was, shall we say, a bit more complex. Note the clear visibility of the steam plume out of the equipment pool. Surely Tepco would have noticed the presence of that plume, which certainly is not steam produced by water evaporated from the SFP many meters away. In fact, views like this would have suggested to me that the plume in its entirety might have very little to do with the spent fuel pool. Tepco, alas, curiously appears to have reported to NISA the opposite judgement, that it was all coming out from there.
  • #13,191
this one looking opposite direction also has appearance of steam coming out nearer reactor.
this one it's hard to say. Reactor would be centered on fourth column.
not sure where i got this one. Top one is from Cryptome, [EDIT: add] http://cryptome.org/eyeball/daiichi-npp3/daiichi-photos3.htm , twenty-third one down. It's worth loading the zipped full resolution ones from link at top of that page..[end edit]
Thanks, it had not occurred to me to localize the sources of the steam. Guess I'm intimidated by not knowing the piping there.
BTW - that control rod meltaway and recriticality scenario is not my creation. It's the subject of NUREG CR-5653.
which has this great line: "... the operations staff may be very surprised..."
It's bad science to go looking for things that support one's preconceived notions.
Mea culpa. The enormity of that explosion set me off looking for reasons to believe it got a fission boost.
old jim
  • #13,192
challenge to
...postulate a credible mechanism for getting the fuel arranged as it is in the core and with no control rods between them, and submerged in water...
Experiments to investigate the phenomena of core melt progression in prototypical BWR core geometries have been carried out in the Annular Core Research Reactor (ACRR) at Sandia National Laboratories (one BWR test) and at the CORA out-of-pile facility9 at the Kernforschungszentrum Karlsruhe (KfK) in the former Federal Republic of Germany (six BWR tests). The first of these was the DF-4 experiment,"° conducted within the ACRR in November 1986. The test apparatus, placed within the cylindrical region surrounded by the ACRR annulus, included a control blade arm, channel box walls, and 14 fresh fuel rods. The apparatus was dry, but the 20inch (50-cm) long test section was supplied from below with a steam flow representative of BWR boiloff conditions.
When the DF-4 fuel rod cladding was heated beyond the runaway zirconium oxidation temperature, the energy release associated with oxidation accelerated the temperature escalation. Much of the clad melted at 2125 K (3365°F) and relocated downward; the remainder was converted to and remained in place as ZrO2, which has a much higher melting point ([4900'F]2978 K).
The control blade in the DF-4 experiment melted earlier than expected and progressively and rapidly relocated downward. Subsequently, the reactor was shutdown to terminate power generation within the test assembly fuel rods before fuel melting could begin. In a post-test crosssection, the relocated control blade material was found in the form of an ingot at the very bottom of the test section, which was below the bottom of active fuel. Both the control blade and the channel box wall portions of the DF-4 test section were more than 90% destroyed due to melting and relocation during the experiment, but the fuel pellet stacks were predominantly still standing. Relocated cladding blocked the base of the fuel rod regions of the experiment.
Figure 3.7-15 illustrates the results of the DF-4 experiment, extrapolated to the same portion of the core that is represented in Figure 3.7-14. (Here the water rods, which were not included in the DF-4 experiment, have been assumed to relocate in the same time frame as the channel box walls.) The ramifications of these standing fuel pellet stacks in the absence of control blades with respect to the potential for criticality if water were to be introduced at this point in an actual accident sequence should be obvious.
Figure 3.7-15 You'll have to look at the document for i don't know how to copy the figure here. Its descriptor says it all, though. jh
Relocation of control blades and channel box walls leaves on U02pellets encased in thin Zr02sheaths sic
http://pbadupws.nrc.gov/docs/ML0210/ML021080117.pdf
so i could niether prove nor disprove it happened, only that it's deemed possible by credible sources..
old jim
  • #13,193
ps
Nureg CR-5653 was hard to find but it seems available here:
http://www.findthatfile.com/download.php?i=84077748&t=hPDF
12 meg , takes a while .
  • #13,195
Fwiw, i had proposed a mechanism where there is thermal inversion in the melt (ceramic ends up on the bottom) then the melt breaches in the bottom head and is blown down into the water which was supposed to exist on the PCV's bottom, as in the report you provided.
This would result in a steam explosion, of course, and would also create a bed of small ceramic fragments which when re-flooded might (I thought) go critical and provide the fluctuating radiation and heat levels we were seeing at the time as well as the periodic spikes of Iodine in the water.
Morbius chewed me over for thinking that it's even remotely possible for a debris bed to self-arrange into a favorable geometry.
  • #13,196
jim hardy said:
<..>Thanks, it had not occurred to me to localize the sources of the steam. Guess I'm intimidated by not knowing the piping there.
Oh, you'll be excused, but not so with Tepco. You must imagine you are Tepco's man on board the helicopter. Localizing the sources of the steam is part of you mission and you know exactly what is where in the reactor building.
Now, how could you possibly come to the conclusion from your views of Unit 3 from the air (only bleakly represented by the scraps we've been handed), that e.g. this scene of the plumes rising over Unit 3 is all about its having a problem of evaporating water from its SFP -- and not at all about its having a problem of a leaking reactor?
NISA Relase March 16 12:30:
-"White smoke was seen rising from the vicinity of Unit-3 at around 8:30, Mar. 16. Damage to the containment vessel of the unit is suspected."
(Bait: There may be a serious situation, it is being investigated)
NISA Release March 16 19:00:
-"White smoke was seen rising from the vicinity of Unit-3 at around 8:30, Mar. 16. TEPCO estimates that failing to cool the SFP has resulted in evaporation of pool water,
generating steam."
(Switch: We have now evaluated the situation. The white smoke is just steam from the SFP. But that is also a serious matter you can worry about. It may eventually boil dry.)
Next day, reinforcement. In all media: "There is an urgent need for watering the SFP"
  • #13,197
I guess i can excuse them for wanting to know what they had before going public.
That Atlantic article from last year said "Unfortunately, Welch couldn't share the specifics of the missions his team flew. The cone of secrecy around Fukushima extends far and wide."
http://www.theatlantic.com/technology/archive/2011/04/inside-the-drone-missions-to-fukushima/237981/
One would think by now there'd be a Nova show about it.
The line you quoted : "Damage to the containment vessel of the unit is suspected." is i think 'execuspeak' for the unmentionable. Media sure missed it.
old jim
  • #13,198
  • #13,199
Journalists are as a breed inquisitive, but what could they do, with counterparts moving about the map confusing as crabs and barely more outspoken than oysters.
The media did seem ready to blow. Media temper flares on March 16th Tepco press conference. But then next day we were at war with Poolasia, and news from the front naturally took focus.
Edit: After the first day of the war the generals could declare victory in the first few battles:
"Holding a midnight press conference, TEPCO is cautiously optimistic efforts with
helicopter drops and water cannons had some success cooling the spent fuel rod pool at the #3 Fukushima reactor.
"We were able to see some steam," says an official, "it’s fair to say that the spraying was somewhat effective." "
So the war with Poolasia which was started because Poolasia was steaming, was now being won because Poolasia was steaming.
  • #13,200
Oysters? Confusing? Counterparts?
you have to be blunt with me. I am more obtuse than normal people and miss social cues. It's called Asperger's.
The experts were caught flat-footed .. some of their emails are still floating around.
http://list.ans.org/pipermail/ncsd-fukushima/2011-April/000020.html
i think Tepco's scurrying about was from a genuine lack of knowledge compounded with shock and disbelief . Probably official pressure to quell panic, too.
I spent a lifetime working in a plant . Certainly i had a hard time acceptng that one of these things is capable of what it did.
But I've got over that and as I've said so many times - I'm ready for that Nova show.
A calm scholarly presentation would be welcome. Nobody needs tabloids screaming end of the world scanarios, though. And that's what would have happened last year.
We're ready now, IMHO.
old jim
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
467K
21K
  • · Replies 763 ·
282K
  • · Replies 38 ·
16K
12K
