Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The Fukushima Daiichi nuclear plant is facing significant challenges following the earthquake, with reports indicating that reactor pressure has reached dangerous levels, potentially 2.1 times capacity. TEPCO has lost control of pressure at a second unit, raising concerns about safety and management accountability. The reactor is currently off but continues to produce decay heat, necessitating cooling to prevent a meltdown. There are conflicting reports about an explosion, with indications that it may have originated from a buildup of hydrogen around the containment vessel. The situation remains serious, and TEPCO plans to flood the containment vessel with seawater as a cooling measure.
  • #9,501
  • #9,502
radio_guy said:
one thing nagging me about all that is wondering if the core of #4 was fully unloaded.. or if they were a little behind and just said oh yeah.. we did it. expecting to have it completed shortly?
well, of course, the implication in what i am saying is that, contrary to what TEPCO says,
there was in fact fuel in #4 reactor and it's for certain that the primary containment
lid (yellow cap) was off and stored...
  • #9,503
Tepco doesn't tell us also about unit 5 pressure stress test during earthquake until last gov report... so who know... maybe there was fuel in unit 4.
  • #9,504
elektrownik said:
Tepco webcam what the...
http://www.tepco.co.jp/nu/f1-np/camera/
yes, here at 2:48 a.m. Japan time Bdg. #4 is steaming like mad, and the "extra cloud of fog"
is being caused by all of that excessive steam.
  • #9,505
I never saw so much steam from unit 4
  • #9,506
this is about the 3rd time I've seen it. i think it happens whenever they water
the corium in the reactor at the same time they water the SFP.
  • #9,507
I see 2 sources of steam in unit 4:
  • #9,508
There's also a plume coming out of Unit 2. It's hard to see, though.
  • #9,509
in unit 4? according to tepco there are no fuel rods in the reactor since it was all offloaded.
edit: are they using one of the first ever webcams made with a horribly small picture and huge compression a like 9FPS.
if they wanted people to guess and debate over minor things due to low quality to keep their minds off the actual problem they are doing a great job.
  • #9,510
Well, the one of the right is clearly unit 4, but I see the one on the left as coming from unit 3.
Isn't all this fog weather related? And the plume is simply visible because of the fog... I'm no weather expert but I'm not sure there is something suspicious here (even if it looks so).
  • #9,511
I would have to agree that it seems quite possible. now most of the site is shrouded in a fog, but it was definately coming from just the buildings to begin with, maybe the temperature change brought the dew point down enough, water evaporated etc.
also, am I the only one that notices the bright flecks now and then on the image sensor? leads me to believe that radioactive particles are still being released. if it starts to look like snow on an analog broadcast they are pretty much done with any work there.
  • #9,512
well, from the standpoint of the dewpoint and the temperature and the humidity,
yes, there is fog about at Fukushima Daiichi. but, the "extra thick fog" around
Bdg. #3 and Bdg. #4 is being caused by the excessive steam coming out of Bdg #4
  • #9,513
ManuBZH said:
...Isn't all this fog weather related? And the plume is simply visible because of the fog... I'm no weather expert but I'm not sure there is something suspicious here (even if it looks so).
I was about to post the same thing. Looks to me like this is all related to the marine fog layer that was rolling in. Take a look now:
http://www.tepco.co.jp/nu/f1-np/camera/index-j.html
all fogged in.
Side note: I see a much higher quality image at the url than what has been posted recently...?
It's very hard to separate the weather related water condensates versus what the units are putting out. There have been way too many "fire at #3!11!" followed by "oops, not so much" All the units are constantly generating steam. I don't understand the variances we see.
  • #9,514
all fogged in.
oh contraire. 45 minutes ago there was a very clearly delineated steam event happening
around Bdg. #4 (see previous posts)
at this time however, it is daybreak in Fukushima and the event has now been
swamped by the usual fog formation.
  • #9,515
causeceleb said:
none of the information put out by TEPCO is to be trusted.
There is no Fuel in the Reaktor. The fuel is unloaded because the shroud was change during the Accident
  • #9,516
Pu239 said:
...What actually happens if the #4 spent fuel pool collapses?
Well it would be very bad. Beyond that, it seems to me that there are way too many variables for any speculation to be meaningful. They are desperately trying to keep the site so that humans can work there. The collapse of SPF4 would likely compromise that (radiation levels) for part of the site. They are actively working in RB4 to reinforce SPF4. See previous posts on this thread (a few pages back, or on the tepco site).
Pu239 said:
...What causes this steam?
It must be SFP-related since there is no active core.
"Steam" can be generated by 50C water (or lower). SPF4 temps are 86-89℃ (6/8 19:50)
http://www.jaif.or.jp/english/news_images/pdf/ENGNEWS01_1307676246P.pdf
  • #9,517
Bandit127 said:
Possibly a gun barrel length to width ratio might be ideal - I am not an expert.
But things designed to 'shape' (i.e. vector) explosions commonly have a L/W ratio of 1:1 or 2:1
True and true, this may explain the observations of Jorge with regards to the lack of upward speed of the wave at the explosion, a 1:1 ratio will create a very wide wave that will be vectored but may not get the speed that you would with a true gun barrel.
  • #9,518
causeceleb said:
well, you are certainly entitled to your opinion.
Page 90
http://www.kantei.go.jp/foreign/kan/topics/201106/pdf/chapter_iv_all.pdf
and.. when the shroud is changing, there is no water in the Reactor
  • #9,519
  • #9,520
causeceleb said:
do you really believe anything that TEPCO says?
hahahahahahahahaha ha!
Tepco?...
http://www.kantei.go.jp/foreign/kan/topics/201106/iaea_houkokusho_e.html
  • #9,521
Bioengineer01 said:
ONLY smoke/fog/vapor can be seen, nothing else...
Looks to me like a thick fog bank rolled in.
  • #9,522
Last temperature readings we got yesterday from SFP unit 4 were close to 90 C... That is darn too close to boiling...
  • #9,523
Even if you disbelieve anything TEPCO says, it makes no sense to leave fuel in a dry reactor vessel, particularly if the fuel has been run for 6 months. It would be at best a messy workaround for the people maintaining the facility., for no plausible gain.
  • #9,524
This means that the suspicion that there was fuel in RPV 4 was correct. We have speculated till hell froze over in other forums about this topic...
  • #9,525
Exactly. The steam observed this morning was an unusual event (a larger than normal release) from Unit 4 (mainly) - and clearly distinguishable from fog. Also clearly different than the usual slow vapour release.
  • #9,526
The closed circuit cooling system is supposed to be installed in July..
Meanwhile, my guess is that they will let the pool boil, because they cannot shore up the pool while it is overflowing radioactive water because new water is getting injected. Once they have that work done, it is likely that they will flush the pool with colder water.
  • #9,527
Thanks very much to everyone who posted about the issue of total radiation estimates and the water. It was very helpful and I shall digest this information over the weekend.
Im surprised it took this long for visible steam on the camera to create a fresh mini hysteria on the internet, given how long that particular camera has now been up and running, and that this is not the first time that impressive quantities have been visible. I shall go and review footage from earlier today but I don't expect to see anything too interesting.
One thing the webcam is actually good for is observing at least some of the earthquakes that can be felt on site. On several occasions I have been able to link the time of slight camera shaking with an earthquake that is reported online.
For example, the 19:39 point according to the TEPCO top banner timestamp of this video, which corresponds to roughly the 9 mins 44 point of actual youtube time of this video, seems like a good fit for the earthquake I am linking to below.
http://www.youtube.com/watch?v=eac5zIZNwtc&feature=channel_video_title
http://earthquake.usgs.gov/earthquakes/recenteqsww/Quakes/usc00043ab.php
  • #9,528
Makes sense as a heat extraction mechanism, what about contamination of the site, will all that vapor carry out any more contaminants or "radioactive flies"?
  • #9,531
Very clever!
While the closed circuit shot says "Live", there is no way to prove that it is not put through an edit loop, to censor undesirable images before they get broadcast. An earthquake is hard to plan for, however, so it should show whether the video is real time or not.
Unfortunately, I could not reconcile the time lines in your videos, so the status is till up in the air, whether it is real time or not. Have you come to a conclusion on this issue?
  • #9,532
Good question!
We must defer to those on this site with real nuclear expertise to estimate what the emissions from a full load of 6 month old fuel aged three months would be. Way above my pay grade.
  • #9,533
Why are you thinking that there was fuel in RPV 4? Would this explain something?
  • #9,534
Regarding the live feed:
I just realized that the west side of Unit 1 has been sprayed or painted with a yellow or brown substance. Is that probably the glue they're using to keep particles from being carried away by winds? But why are they only treating the east side of Unit 1 and nothing else?
I searched for the process, it can be seen on this video:
It starts at minute 1. 2006-06-09, 10:00.
  • #9,535
etudiant said:
Good question!
NUCENG posted some documents regarding the fission products in spent fuel. I think it was back in April. He also calculated the I131 inventory of a six month old core. You should find it with the search function.
https://www.physicsforums.com/showpost.php?p=3255998&postcount=4302
https://www.physicsforums.com/showthread.php?t=493058 And maybe you get a few ideas out of this thread.
  • #9,536
This ? If (as we seen on underwater sfp 4 video) gate is undamaged, there is no other explanation...
[PLAIN]http://img535.imageshack.us/img535/3165/gggss.png
  • #9,537
clancy688 said:
You're right when you talk about radiation data. Radiation releases, nuclides in the air, the sea, the food...
But you're wrong if it's about NPP status. Nobody except TEPCO has data about the actual reactor status. What are the sensors telling? What's the load of the SFPs and the reactors? What are the radioactivity levels of the water in the basement? NRC can't answer these questions. US officials and Greenpeace can't either.
We have dozens of sources regarding anything what happens OUTSIDE the Fukushima Daiichi fence. We have only ONE for anything what happens inside.
We were getting so much faulty data from TEPCO, I do not blame anybody for venting a little about it. After the massive explosion in Reactor Three TEPCO was still saying that they had pressure inside the reactor and finally on March Sixteenth told us that the reactor was at atmospheric pressure.
Reactor One was listed for weeks as having increasing pressure and temperature. Now, we know that was fiction as the Japanese have finally admitted that they had a melt down and a holy reactor vessel two to three days after the tsunami.
If we believed TEPCO they were going to get a firm Cold Shutdown in Six months at Fukushima. Ha!
They had to have known that they had three melted cores and damaged reactor vessels 72 hours after they were douched. Talking about cold shutdown was just for public consumption.
I don't know one reactor operator that I had contact with who believed that the cores were still intact one day after the accident. Total heat generated at five percent power as opposed to total heat dissipated said meltdown. Not just meltdown, but rapid meltdown.
  • #9,538
Watch the youtube video from 02:30 JST:
http://news.lucaswhitefieldhixson.com/2011/06/tepco-cam-blocked-out-by-vapor-event.html
Lots of smoke and steam, then fog?
EDIT: where is the best place to find up to date rad readings for the NPP?
  • #9,539
I just realized that the east side of Unit 1 has been sprayed or painted with a yellow or brown substance. Is that probably the glue they're using to keep particles from being carried away by winds? But why are they only treating the east side of Unit 1 and nothing else?
Actually, this has already been reported by SteveElbows on post #9406. With a more interesting fact that the previous video which holds an "action scene" showing some workers wandering in front of the camera.
  • #9,540
Oh, I guess I missed that post. So, any idea what it is?
  • #9,541
I think you mean the west side. Dust inhibitor.
Here's a map of the entire compound, with many labels:
http://bravenewclimate.files.wordpress.com/2011/03/fukushima_daiichi_map_plan.jpg
  • #9,543
...and here:
http://www.youtube.com/fuku1live#p/u/2/v7ueN17orYo
  • #9,544
Bioengineer01 said:
I think that we understand each other, but for the fun or argument :), forensic data from outside sensors can provide a ton of information about what is going on at the plant...
Why have these CTBTO guys stopped reporting?
There has never been a gap in the data like this:
http://www.bfs.de/de/ion/imis/spurenmessungen.html/#2
Nothing for the past 10 days...
Does anyone have academic contacts with bfs? Can any german speakers here contact them?
  • #9,545
Unit 3:
TEPCO announced on June 10 that they confirmed the presence of water in the basement of the Reactor 3 reactor building at Fukushima I Nuclear Power Plant. TEPCO had estimated that 6,400 tons of water would be in the basement as of the end of May, based on the amount of water injected into the RPV. Now its existence has been confirmed.
  • #9,546
If you draw a line from Unit 1 to Unit 4 you're basically walking due South. The camera is facing towards south-east.
Looking at the camera, you're sort of looking south-ish, with east towards left, and west pointing right.
And, you will see a racoon if you stare long enough (near Unit 1), and a black crow [not a UFO]. The odd worker will show up, spraying dust inhibitor on bushes and other things. A robotic arm might be seen spraying walls - very adroitly I might add, impressive to watch.
  • #9,547
The Gate was closed at 11.3-
But it could be demaged by Erthquake or Explosion. So the water get fromthe SFP to Reactor.
  • #9,548
[PLAIN]http://img535.imageshack.us/img535/3165/gggss.png[/QUOTE]
[STRIKE]Isn't the hotspot in this picture in the wrong spot for the reactor? My understanding of the construction of the reactor building is that if viewed in elevation view from the side, it's L-shaped. The taller portion contains the RPV and is square shaped with the RPV centered in the square and the shorter portion is rectangular shaped. In plan view seen from above, the RPV would be in the center of a square with a rectangular lower portion of the building attached to the side. In other words, if the hotspot in the above picture shown were the RPV, shouldn't it be centered in the picture vertically and offset to one side horizontally instead of centered horizontally and offset vertically?
I will try to find a picture illustrating what I'm talking about and will edit this post if I can find what I'm looking for. If I'm wrong, let me know, because then I've got the building layout all wrong in my head.[/STRIKE]
EDIT: Nevermind, I think I understand where my confusion was. I was thinking of the Unit 1 prints I've seen and even those were not exactly what I was picturing. I don't have anything to add other than the reactor doesn't seem to be offset where I thought it was. I left the original post struck-through.
  • #9,549
That's what they write under the I131 and C137 graphs:
Die Aktivitätskonzentrationen von Jod-131/Cäsium-137 liegen seit Anfang Mai 2011 größtenteils unterhalb den stationsspezifischen Nachweisgrenzen (schraffierter Bereich). Die Grafik wird wöchentlich aktualisiert.
Since the beginning of may, activity concentrations of I131/C137 lie mostly under the verification limit of the respective measuring stations. The chart will be updated weekly.
  • #9,550
If I'm reading the document correctly, it is because they state that they have reached such a low level that it disappears into the background.
They speak of a 'minimal level for demonstrable presence', whichg the measurements have sunk into.
49K
449K
273K
16K
11K
