Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #10,861
rmattila said:
As far as I am aware, noble gas releases from fuel would have reached 100 % before it even starts to melt. Therefore, the only way I see new release of Kr possible is that part of the fuel would have not overheated to 100 % release levels (=would possible have maintained their cladding integrity and would continue to slowly release noble gases). This is exactly the point I found interesting about the results: to me it seems that either the containment is able to contain noble gases for a long period of time or part of the core must have remained unmelted.
The http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110810_03-e.pdf" says the Kr-85 was in liquid samples. The air sample doesn't list it.
  • #10,863
Gary7 said:
I think the English handout is mistaken. On the Japanese original it says the KR-85 was found in the air sample. The liquid sample doesn't mention KR-85.
http://www.tepco.co.jp/nu/fukushima-np/images/handouts_110810_04-j.pdf
Gary7 is correct. In the English version both tables were accidentally labeled as "Liquid samples", but actually only the first table (that only mentions cesium and iodine) is about liquids ("ekitai"), the second is about gaseous ("kitai") samples.
  • #10,864
we only need steam at 300 degrees Fahrenheit
to make electricity; so, nuclear fission is
a magnificent way to boil water.
but, it is just a never ending mystery
to me why and how the engineers have
turned the whole thing into such an ordeal:
i mean, what the hell can be so difficult
about maintaining an atomic pile to boil
water to 300 degrees fahrenheit and keep
the whole process under control, huh?
<disparaging remark deleted>
  • #10,865
I would not go that far in a statement. I have known a few design engineers and they were highly intelligent. Smarter men than I, and I always stand in awe of how beautifully their brains work.
Nuclear plant designs are well thought out. Site designs are another thing.
When I look at Fukushima, I do not see a sea wall. That is a site engineering problem in a country that knows that the run up from a four meter tsunami can exceed 40 feet. They needed a sea wall built for that possibility and they did not do so.
In addition to not having a sea wall, they put their Diesel Generators in positions where they could be douched by a tsunami that they did not build a sea wall for.
In addition to that they had motor controllers (for cooling pumps that needed to be used in a meltdown like crisis) located where they, too, were douched by the tsunami that the did not build a sea wall for.
The list of site engineering screwups at Fukushima is endless, but site engineering is not nuclear engineering. It is obvious to me that the site engineers did not have a clue what they were building for and against.
  • #10,866
As has already been pointed out, this disaster arose because of poor site design rather than nuclear engineering.
Separately, a steam plant working at 300 degrees F will be quite inefficient, as basic thermodynamics limit the efficiency to the absolute temperature swing percentage, a little under 20% ( versus a bit over 30% for the Fukushima reactors) using 420 degrees Kelvin ( 300 * F) for the steam and 340 degrees Kelvin ( 150 * F) for the condenser. So for the same electric output, the reactor would need to be at least 50% bigger, which makes it correspondingly more challenging to keep cool in the event of a power failure. So a lower steam temperature may not help much in terms of risk reduction.
  • #10,867
Is it possible to build an efficient reactor that does not require large amounts of cooling when it's shut down?
I would guess the spacing required to fit enough "control rods" or "control media" to be inserted would impact efficiency badly.
  • #10,868
Nuclear Water Reactors are extremely wasteful of energy, but since there is so much of it waste conservation never was a real consideration. Reactor fuel rods will continue to give off heat for days after a scram. It is just the physics of the beast to do that.
IF you are talking about another means to generate electricity from radiation, most of them are experimental and are not being tried on a commercial basis that I know of.
  • #10,869
Nuclear reactors are built and designed to make money, or power, not for safety. Like the site design of having 6 reactors right next to each other. It was cheaper, not safer, to design like that.
  • #10,870
Then it's the design of the rods as well as the reactors that are responsible for heat production after a reactor is shut down since the rods themselves are producing heat the requires cooling even when not packed to the density level of a reactor.
I was implying in my question whether fuel rods and reactors are able to be designed such that they don't require cooling once they are shut down or whether the mechanism for a "non-cooling needed shut down" is even possible without making a reactor completely inefficient.
  • #10,871
It's not in the design of the reactor or the rods: it's in the physical process of nuclear fission, which splits a nucleus in two pieces, releasing energy as a result, but these pieces have always too many neutrons and are therefore radioactive (=produce heat). It is this radioactivity of the products of the very fission process that lead to the decay heat, and it can not be helped by any design considerations, as long as the fission reaction is used as the energy source.
  • #10,872
It is not a technical problem ...
The real problem is that NPPs are run by profit oriented organizations who try to make as much profit as possible out of their investment. Less safety means more profit and higher bonuses for the top management.
Fucushima is a typical example. The risks that eventually caused the disaster were all known for a long time and technical solutions were also known. It simply was an economical decision not to fix the deficiencies.
It was the same story with Chernobyl.
And I am convinced that economical reason will be the reason when the next NNP blows up. I don't know where this will happen but it will happen.
  • #10,873
Less safety may mean loss of profit.
In Tepco's case, they lost a multibillion dollar plant.
Chernobyl had nothing to do with profit. It was a incredibly bad experiment that took the plant outside the design basis. That was negligence.
  • #10,874
As rmattila indicated, the decay heat from fission products and transuranics is inherent in the fission process. There is no way to get around it.
Fuel rods (cores of the nuclear reactors) produce heat which is their principal purpose. The fission process can be shutdown, which is one mandatory functional requirement.
The other main mandatory functional requirement is to maintain core coolability during operation and after shutdown. This is the basic requirement in which TEPCO failed.
Related to those other requirements is another mandatory requirement to protect the plant and its safety systems, which include the emergency core cooling system(s) (ECCS). That is another area in which TEPCO failed.
TEPCO and the government did not forsee the possibility of a 14 m tsunami. Had they recognized this, then they would have ensured protection against such a natural event. Somehow, they convinced themselves that protection against a smaller tsunami (5.7 m seawall) was sufficient. Obviously it wasn't - and the rest is history.
  • #10,875
I suppose it's natural to lash out at the designers.
Anyone familiar with the "General Design Criteria" for nuclear plants recognizes the profoundly straight thinking and safety conciousness of the old timers (early 50's) who wrote them into US law.
""Criterion 2—Design bases for protection against natural phenomena. Structures, systems, and components important to safety shall be designed to withstand the effects of natural phenomena such as earthquakes, tornadoes, hurricanes, floods, tsunami, and seiches without loss of capability to perform their safety functions. The design bases for these structures, systems, and components shall reflect: (1) Appropriate consideration of the most severe of the natural phenomena that have been historically reported for the site and surrounding area, with sufficient margin for the limited accuracy, quantity, and period of time in which the historical data have been accumulated, (2) appropriate combinations of the effects of normal and accident conditions with the effects of the natural phenomena and (3) the importance of the safety functions to be performed."" emphasis mine - jh
http://www.nrc.gov/reading-rm/doc-collections/cfr/part050/part050-appa.html
Somebody somewhere wasn't quite diligent enough about that one. I'd hate to be him now.
old jim
  • #10,876
Dear Astronuc,
your answers are typical for an rational engineer. However top management thinks different.
Astronuc said:
Less safety may mean loss of profit. In Tepco's case, they lost a multibillion dollar plant.
... if an accident happens. But money spent on safety will impair the profit now. Top management is in charge for a few years at best. Do you think they care what happens afterwards? This thinking worked perfectly for generations of TEPCO CEOs. Bad luck for the present TEPCO CEO!
Wrong. The reactor design was chosen for economical reasons. It was an advancement of an existing design - this saved time and costs. The known design faults were ignored and concealed - for economical reasons. The test was shifted into the night and hence carried by an inexperienced team because the reactor was needed for power production during the day - a decision made because of economical reasons. And so on ...
  • #10,877
htf said:
Dear Astronuc,
I work with many utility managers, and they are always concerned about safety as well as cost.
I know of two cases where plants managers were sacked because of safety issues at their plants. In some cases, some managers can face criminal prosecution for safety violations.
Please provide the evidence to support this claim. I don't believe that there was concern about profit in the Soviet Union. They were certainly lax about safety and probably overconfident about their capabilities and technology. Note that they stopped construction or canceled additional RBMKs, as they had started building VVERs. The VVER-440 is not as safe as VVER-1000, and the EU and US have been encouraging the phase out of VVER-440s.
http://en.wikipedia.org/wiki/RBMK#Status
  • #10,878
old jim
The GDCs are what I had in mind.
EBASCO was a leader in the initial unit. Toshiba and Hitachi came in on the subsequent units.
I'd like to see their rationale behind the seismic and tsunami risk.
  • #10,879
rmattila said:
The detection of Kr-85 (if the results are correct) is interesting. As far as I am aware, Kr-85 is not produced in the long decay chains, so all of it has been around ever since the fissions stopped. If it is still found in the containment, my first impression is that either
(a) the containment has somehow been able to contain the noble gas Kr-85 ever since the fuel failures occurred in spite of the leaks and the suspected hydrogen explosion early on during the accident
(b) Kr-85 has been released to the containment atmosphere more recently, which means that some fuel rod claddings have lost their integrity only recently
Kr-85 has a long half-life (t1/2 = 3916 d), but Kr-85m (IT) has a short half-life (t1/2 = 4.48 hours).
http://www.nndc.bnl.gov/chart/reCenter.jsp?z=36&n=49 (Use Zoom 1)
http://www.chemicalelements.com/elements/kr.html (see isotopes)
I don't believe all of any of the cores melted, so it's possible some incipient failures ruptured. I do expect that a lot of the Zr-2 (and Zr-liner) reacted with steam, and much of it oxidized to powdery ZrO2. The UO2 would have oxidized to higher order oxides e.g., U4O9 and U3O8, and fission gas diffusivities are rather high compared to those of UO2.
  • #10,880
Reactors are not built for safety? Really? Did you really just type that?
  • #10,881
This is quite false. Reactor are designed for mandatory safety considerations. All engineered technology must involve safety considerations. However, there are sometimes deficiencies.
  • #10,882
"LFTR+online reprocessing" scheme comes to mind. In it, decay heat is seriously reduced.
  • #10,883
Safety would mean isolating each reactor, so that if a catastrophic failure occurs, you don't risk losing all the reactors.
  • #10,884
Virtually EVERY system, plant or single object is designed with profit versus safety considerations. Be it a nuke plant, a bomb, an airplane, your car or a toothbrush that balance will always exist. NPP are designed more toward safety than profit but NONE would ever be built if ONLY safety were considered. ALL ACTIVITY carries some risk and nukes are no exception. The trick is balancing ACCEPTABLE RISK against cost in such a manner that the plant CAN be built and operated. Why would it EVER be built if it could not even break even? Only governments do such foolish things as can be seen in ethanol as fuel or various "green" energy fiascos that can NEVER be economically viable and are directly subsidized because they are losers.
Every design by man has flaws. Either we learn from those flaws and improve - or else we cease to move forward at all. The BWR has gone through a series of improvements and will, hopefully, go through even more once the lessons of this accident are learned and understood. Standing still is not an option - we MUST improve, move forward. To stand still is to fall behind and FAIL. We are becoming far too risk averse which will stop ALL innovation and therefore progress. Stopping all progress does not serve humanity.
The strong anti-nuclear sentiment, often by those of questionable scientific or engineering background, has actually CAUSED increased risk in some ways. The defacto moratorium on new nukes in the USA has made it necessary to extend the operating lives of old, less advanced designs such as the early BWRs or Russia's AWFUL RBMK.
The Chernobyl accident had many facets - poor reactor design, poor operator training, a HORRIBLY flawed test, unbelievable violations of written safety criteria and POLITICS in the old USSR that covered up known flaws in design and operations. The only real surprise to me is they got away with it all for as long as they did! At least in US nuclear industry there is exchange of ideas, knowledge of other operator's findings and problems. In the old USSR such things were state secrets and they paid a terrible price for it.
Do not take the above as a defense of TEPCO or the many designers of Fukushima. I suspect design errors will become rather obvious as time goes by and hopefully result in improvements in existing plants and future plants. In hindsight, some of those errors may look rather foolish. I also hope all of the glaring management errors are corrected as well. Coverups are NEVER acceptable and should be harshly punished. I would hope, however, careful consideration is made of the facts, thorough NON POLITICAL investigations are made of every item involved in this event so REASONED action can be taken - neither cover-up and white wash nor kneejerk anti-nuclear hysteria. We must keep in mind too that this event was set off by a natural disaster of nearly unprecedented severity. Hind sight is always 20-20......
rant off
  • #10,885
While it is true that a catastrophe such as Fukushima would have been much less had the site only had one reactor, the offset is that the likelihood of more than one site getting hit in a large earthquake would be greatly increased.
I'm not sure that the effect of two or more reactors in trouble at widely separated sites would be any less damaging than what we have now. Also, it is not implausible that widely dispersed stand alone sites will dilute the available technical and human resources, possibly making accidents more likely.
That said, it may be that reactor design needs changing. Perhaps a site should comprise 50 much smaller reactors, each of which can be easily cooled, ganged together to power the turbines. That would allow for walkaway type shutdown. The question is whether such an approach would perform reliably or just guarantee 50x as many small nuclear incidents.
  • #10,886
Remember that the ability to use the power from unit 6:s EDG was what saved unit 5 at Fukushima.
  • #10,887
There was concern about profit in the Soviet Union. The disease was not called "shareholder value" but it was the race between capitalism and socialism.
There are many sources that analyse the real reasons of the accident. In the beginning the operators were blamed. This is what I call pilot error mechanism. This is the most convenient way to explain an accident.
There is a GRS report that summarizes the real reasons:
http://www.grs.de/sites/default/files/pdf/GRS-121_Deut.pdf
The summary of reasons for the accident:
Aus heutiger Sicht waren die Hauptursachen des Unfalls
- gravierende Mängel der reaktorphysikalischen Auslegung und der Auslegung der
Abschalteinrichtungen,
- ein politisches und organisatorisches System, welches nicht in der Lage war, diese
Mängel abzustellen, obwohl sie lange vor dem Unfall bekannt waren,
- ein sicherheitstechnisch unzureichend durchdachtes und geprüftes Versuchsprogramm,
- eine Betriebsführung und Bedienungseinrichtungen, die das Personal bei der
Wahrnehmung seiner Verantwortung für die Sicherheit überforderten.
In chapter 2.3 discusses the influence of the reactor condition:
Bestimmt und verschärft wurde der Unfallablauf durch:
- Ungünstige Wahl des Zeitpunktes - hoher Abbrand mit sehr großem positiven Voideffekt
von mindestens 5 b - für die Durchführung des Versuchs
- Nichtbeachtung der Erfordernisse der Reaktorsicherheit bei Aufstellung des Versuchsprogramms
- geringe Erfahrungen und unzureichende Beteiligung des Betriebspersonals an den
Vorbereitungen des Versuchs sowie Verstöße des Betriebspersonals gegen Betriebsvorschriften
The time line of the accident can be found in wikipedia:
Conditions prior to the accident
Schematic diagram of reactor
The conditions to run the test were established before the day shift of 25 April 1986. The day shift workers had been instructed in advance and were familiar with the established procedures. A special team of electrical engineers was present to test the new voltage regulating system.[20] As planned, a gradual reduction in the output of the power unit was begun at 01:06 on 25 April, and the power level had reached 50% of its nominal 3200 MW thermal level by the beginning of the day shift. At this point, another regional power station unexpectedly went off line, and the Kiev electrical grid controller requested that the further reduction of Chernobyl's output be postponed, as power was needed to satisfy the peak evening demand. The Chernobyl plant director agreed and postponed the test.
At 23:04, the Kiev grid controller allowed the reactor shut-down to resume. This delay had some serious consequences: the day shift had long since departed, the evening shift was also preparing to leave, and the night shift would not take over until midnight, well into the job. According to plan, the test should have been finished during the day shift, and the night shift would only have had to maintain decay heat cooling systems in an otherwise shut down plant. The night shift had very limited time to prepare for and carry out the experiment. A further rapid reduction in the power level from 50% was executed during the shift change-over. Alexander Akimov was chief of the night shift, and Leonid Toptunov was the operator responsible for the reactor's operational regimen, including the movement of the control rods. Toptunov was a young engineer who had worked independently as a senior engineer for approximately three months.[14]:36–8
  • #10,888
That brings up an interesting thought. It seems that even a reactor that isn't running, that is in cold shutdown, is also an extremely dangerous thing to even exists. The loss of cooling, for any reason, and the inability to restore it very quickly, means big trouble and lots of it.
There is little doubt that natural disasters will come, and this disastrous situation will happen again. It's built into the very nature of a reactor, or a spent fuel pond. With out capable trained people, a support system, water, electricity and constant attention, any reactor/fuel pond is just a disaster waiting to happen.
  • #10,889
htf are you fluent in the language of those gts.de links?
There's something I've wondered about for over twenty five years - Perhaps you'd know.
""A special team of electrical engineers was present to test the new voltage regulating system.[20] ""
Early reports said purpose of the "test" was to try and keep power to some new piece of equipment after turbine trip. To that end they disabled reactor trip when turbine trip occurs from low power... that left reactor making power with noplace to send the heat so it began to boil. In that obsolete RMBK (scaled up US 1940's design stolen by spies in Manhattan project), boiling causes runaway.
Do those articles say what was the piece of equipment they were testing? That line quoted above is first description I've ever seen. "Voltage regulating system..." - voltage for what ?? Main generator? Plant computer?
thanks, old jim
  • #10,890
Impact of one reactor/unit on other units is a consideration in NPP design.
If properly designed, one should have a catastrophic failure of a single unit. As pointed out earlier, there are mandatory General Design Criteria that quite clearly emphasize the safety aspects.
Standard Review Plan for the Review of Safety Analysis Reports for Nuclear Power Plants: LWR Edition
http://www.nrc.gov/reading-rm/doc-collections/nuregs/staff/sr0800/
http://www.nrc.gov/reading-rm/doc-collections/reg-guides/power-reactors/rg/
There are thousands of pages of rules and regulations all aiming to ensure safety of power reactors.
The expectation is that the emergency core cooling system is operable, even if there is loss of off-site power. However, this assumes that the ECCS systems are not placed in vulnerable locations, and that the primary system and ancillary cooling systems are more or less intact.
Had the seawall been 15 m, i.e., had the tsunami been prevented from inundating the Fukushima Daiichi site, or given that, that the oil tanks been buried underground, or perhaps located west of the units, and had the diesel generators and switch gear been located in a more secure locations, then the site would most likely have survived. Similarly, had the operators vented earlier, had the duct work to the stacks held, and/or had the secondary containment been of a more robust design, then the consequences of the accident wouldn't have been as bad they were.
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
471K
21K
  • · Replies 763 ·
284K
  • · Replies 38 ·
17K
12K
