Physics Experiment: Jerk & Inertia | Solving for dA/dt
The physics experiment demonstrates the difference in tension between two strings when subjected to gradual versus sudden force. When the thread is pulled gradually, the top string breaks due to increased tension, while a sudden jerk causes the bottom string to break instead. The discussion involves modeling the tension as a delta function to analyze the rate of change of acceleration (jerk) and its impact on the strings. The equations derived indicate that the mass undergoes simple harmonic motion after an impulse is applied, with maximum tension in the upper string being significantly lower than that in the lower string during a quick jerk. Ultimately, the analysis shows that steady pulling results in greater tension in the upper string, leading to its failure.
Pax
There is this experiment my high school teacher showed in physics class. You are probably aware of it
(from practicalphysics.org)
There is a video of a teacher actually doing the experiment here:
https://sites.google.com/site/haatscience/physics/221-the-effect-of-inertia
Gradually pull the thread and the top thread breaks, jerk the thread and the bottom one breaks.
I tried to set up a free body diagram to show how this works, and most specifically to solve for the rate of change of acceleration (jerk) that will be the threshold between the top string breaking and the bottom.
I am at a loss, how do you put dA/dt into the equations?
Any ideas?
Likes FactChecker
This one seems to be an experiment where you could model it as a tension that is applied. With a sudden jerk, the tension in the bottom string could be modeled as a delta function: ## T_1(t)=T_{10} \delta (t) ##. Because much of this is absorbed by the acceleration of the mass, the tension in the top string ## T_2 ## never reaches anywhere near the large value, basically infinite, of the ## T_1(t) ## with its delta function. ## \\ ## (In principle, you could limit ## T_1(t) ## to a finite value, by using some other function with characteristics similar to a delta function. For what gets transferred to the mass with a quick jerk, it is basically the impulse which is the integral ## I=\int T_1(t) \, dt ##).## \\ ## Meanwhile, elasticity equations are needed for the top string: ## T_2=k (x-L) ## where ## x ## is the position of the mass ## M ## (with origin ## x=0 ## at the top position of the attachment of the string), and ## L ## is the length of the string with no mass attached. ## \\ ## The mass ## M ## has ## Mg+T_ 1-T_2=M \ddot{x}=Mg+T_{10} \delta(t)-k(x-L) ## , with initial conditions that ## Mg= k(x_o-L) ##. ## \\ ## You can solve for ## x(t) ## , and then for ## T_2(t)=k(x-L) ##. ## \\ ## Anyway, I haven't solved these equations, but I think they would give the necessary result. ## \\ ## Edit, along with a correction to my first attempt at a solution here: ## \\ ## I get for ## t \leq 0 ##, that ## x(t)= \frac{Mg}{k}+L##, and ## T_2(t)=Mg ## , ## \\ ## and for ## t>0 ##, an impulse has been added to the mass ## M ##, giving it an initial velocity, but no immediate change in position occurs. After that mass ## M ## performs simple harmonic motion with this energy that it has acquired. You can compute the maximum ## x ## that occurs in the simple harmonic motion, and thereby compute ## T_{2 \, max}=k (x_{max}-L) ##. I get, with a quick calculation, that the simple harmonic motion (at frequency ## \omega=\sqrt{\frac{k}{M}} ## ) has amplitude ## \frac{T_{10}}{\sqrt{kM}} ##, so that ## \\ ## ## x_{max}-L=\frac{T_{10}}{\sqrt{kM}} +\frac{Mg}{k} ##, and that ## T_{2 \, max}=T_{10} \sqrt{ \frac{k}{M}}+Mg ##. ## \\ ## For most cases, with a quick jerk, ## T_{2 \, max} <<T_{1 \, max} ##. ## \\ ## Meanwhile, with a steady pull on ## T_1 ## the tension ## T_2=T_1+Mg ##, and ## T_2 ## (the tension in the upper string) is larger and the upper string breaks.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
10K
