How Is Thrust Calculated for a Jet Engine in a Lab Test?
In summary: The force on the exiting gas must be equal to the thrust on the rocket, according to Newton's third law of motion.
controlfreaks
A jet engine is being tested in the laboratory and it is found to consume 20 kg of air per second while using 0.2 kg of fuel per second. Given that the exit velocity of the gases is 500 m s-1, calculate the thrust generated by the engine.
F = M(V-U) where F is thrust, M is mass and V and U are final and initial velocities.
not sure what to be doing here as i don't know what's going in where. what goes in for U the initial velocity?
Hi, welcome to PF.
Can this equation be correct? The left hand side has the dimension of force while the right hand side has the dimension of momentum.
Let's do it in a very simple way.
In one second, how much mass is exiting the rocket? That is given.
So, what is the impulse on this mass?
We know that Impulse = Force X time.
What low should be used now?
Hi Shooting Star!
Thanks for the reply!
how do we know how much mass is exiting the rocket?
we know how much fuel and air it consumes and the exit veolcity of the gases but not the mass exiting do we?
controlfreaks said:
Hi Shooting Star!
In this case , "consumes" means that the fuel and the air mixes and combustion takes place and the end product exits as a hot gas , producing thrust on the docket . That is given in the very first sentence of the problem . Do you understand now ?
ok i get what you mean there! total mass is 20.2Kg
so why do we need the impulse? and as far as the thrust goes how do we now find what this would be. I don't need you to solve for me, just let me kno what's happening with it.
cheers!
bump!
can anyone help on this?
much appreciated!
cheers!
The fuel and air mixture exit the rocket after burning and therefore produces a reaction force on the rocket. The impulse on the existing gas has been given.The impulse is the change in momentum and the time is one second. Use the equation I have given you. The force on the exiting gas must be equal to the thrust on the rocket, according to Newton's third law of motion.
I think we're making this problem more difficult than it needs to be; and it seems that way because of a simple mistake. You are trying to use Conservation of Momentum for a fluid, but you forgot time rate.
[tex]
\begin{equation}
\begin{split}
F \neq m(V_2 - V_1) \\
F = \dot{m}(V_2-V_1)
\end{split}
\end{equation}
[/tex]
As shooting star mentioned, ALWAYS check your units. If you're not getting Newtons, then you're not calculating force. Also, there may be a pressure component that should be included, if not, then you haev mass flow rate and initial and final velocities. Plug and chug.
What is jet engine thrust?
Jet engine thrust is the force that propels an aircraft forward. It is produced by the reaction to the high-speed exhaust gases being pushed out of the back of the engine.
How is jet engine thrust measured?
Jet engine thrust is typically measured in pounds or newtons. It can be measured using a thrust stand, which measures the force produced by the engine, or by calculating the change in velocity of air passing through the engine.
What factors affect jet engine thrust?
There are several factors that can affect jet engine thrust, including the amount of air flowing through the engine, the temperature and pressure of the air, and the design and efficiency of the engine's components.
How does jet engine thrust relate to aircraft performance?
Jet engine thrust is a critical factor in determining an aircraft's performance, including its speed, acceleration, and ability to climb and maneuver. Greater thrust allows for faster speeds and better performance, while lower thrust may result in slower speeds and reduced maneuverability.
Can jet engine thrust be increased?
Jet engine thrust can be increased by increasing the amount of air flowing through the engine, increasing the temperature of the air, or improving the design and efficiency of the engine's components. This can be achieved through technological advancements and improvements in engine design.
  • Science Fiction and Fantasy Media
